Question about Toshiba Portege M700-S7002 Tablet PC
My dvd drive won't open and the icon for optical drive power says off. How do i turn it on_
  • kimberlywarn May 07, 2010
    On the bottom "toolbar" of my computer where it has several icons telling you about your battery power, your internet connection, etc.
  • Jose Cada
    Jose Cada May 11, 2010
    jsut want to clarify whre did you saw the notifcation the says the optical drive is power off?
  • Toshiba Master
  • 7,993 Answers
If the optical drive On/Off utility icon says OFF you cannot open the drive. You will have to turn it ON.
Point to the icon with the mouse cursor and right click. You will have the option to turn power to drive ON. Verify it by pressing Fn-TAB.
Posted on Aug 19, 2011
Remove dvd drive
Get a paper clip and straighten half of it out. Now look for a small hole in the face of the DVD drive.
If the drive is Trayless then there should still be a small hole in the dvd location..If the DVD has a tray make sure that the laptop is powered down, insert the Paper clip in to this hole and the DVD tray will pop open.. If the DVD inserts in to the drive(Trayless), Then make sure the laptop is on and insert in to the hole that will be in this same area.
Thank you for your visit to Fixya.com
Dec 08, 2010 | Averatec C3500 Tablet PC
I have a Lenovo 3000 Y530 and the DVD drive is not being detected?
Hi. I think you could try updating the drivers2_bing.gif for your DVD drive or by deleting the upper and lower filters on the registry2_bing.gif so that we could verify if this a hardware or software issue. follow this instruction on deleting the upper and lower filters on the registry:
  1. Click the Start button and click in the Start Search box2_bing.gif.
  2. Type regedit, and then press the <Enter> key.
    Note: The User Account Control window may appear. If so, click Continue. The Registry2_bing.gif Editor window appears.
  3. Click the arrow next to HKEY_LOCAL_MACHINE.
  4. Click the arrow next to SYSTEM.
  5. Click the arrow next to CurrentControlSet.
  6. Click the arrow next to Control.
  7. Click the arrow next to Class.
  8. Click {4D36E965-E325-11CE-BFC1-08002BE10318}.
  9. In the right-hand pane of the window, click UpperFilters.
  10. Click Edit on the menu bar.
  11. Click Delete. The Confirm Value Delete window appears.
  12. Click Yes.
  13. In the right-hand pane of the window, click LowerFilters.
  14. Click Edit on the menu bar.
  15. Click Delete. The Confirm Value Delete window appears.
  16. Click Yes.
  17. Click File, and then click Exit.
  18. Click the Start button.
  19. Click the arrow to the right of the lock icon.
  20. Select Restart.
If this doesnt fix the issue this might be a already a hardware issue and consider replacing your Optical Drive. Hope this helps
Jun 08, 2010 | Tablets & eReaders
Blue screen c0o00021a fatal system error, even in safe mode. cant get the DVD drive to open; it clicks when the latch is depressed, but doesn't open (to try to boot from a repair disk). How do I overcome...
Should be a small hole in DVD drive lid.
Turn off computer and carefully insert a straightened paper clip.
Gently push & the lid should pop out
May 03, 2010 | ASUS R1F Tablet PC
No icons or taskbar after booting.
Have you tried a safe mode boot (press F8 just before the win start screen and choose safe mode) to see what happens and check for the installed programs. Also try in safe mode with network, update yor antivirus and do a full scan.
Stelios.
Feb 20, 2010 | Fujitsu Siemens Stylistic 3400 Tablet PC
CD DVD drives
try antoher cd-rom to see whether it's the optical drive or the pc>>>
May 25, 2009 | Tablets & eReaders
The cd rom on my tablet pc will not respond.
what you can do is to remove the optical drive (since I believe that is removable) then put it back again.
Then come back to me so we can find out the real problem.
Feb 24, 2009 | Gateway (tabletpc)
"D:\ is not accessible" message
If the cd is in the drive then you have a problem with the drive itself. It might work on a cd but won;t on a dvd. That indicates the heads have gone out of alignment.
Usually means you need to replace the drive.
Jan 06, 2009 | Toshiba Satellite R25-S3503 Tablet PC
IBM ThinkPad X41
Afternoon,
I hope this helps?
To recover the hard disk to it's original contents, do the following:
Note:
1. If the optical drive is not attached to your ThinkPad computer during recovery, DVD software and CD-recording software will not be installed. To ensure that they will be installed correctly, attach your ThinkPad computer to the X4 Dock and install the optical drive in the Ultrabay Slim before performing a recovery ioperation.
2. The recovery process might take up to 2 hours.
Attention: All of the files on the primary hard disk partition (usually drive C) will be lost in the recovry process. However, before any data is overwritten you will be give the opportunity to save one or more files to other media.
Power the computer using the AC adapter and ensure a fully charged battery is installed before proceeding.
1. If possible, save all your files and shutdown your operating system.
2. Turn off the computer for at least 5 secounds.
3. Turn on your computer. Watch the display carefully. While the message. "To inturrupt normal startup, press the blue Access IBM button" is displayed at the lower left of the screen, press the Access IBM button. The Rescue and Recovery workspace opens.
4. Click Restore your system.
5. Click Restore my hard drive to the original factory state and then click Next.
6. Follow the instructions on the screen.
7. When the recovery process finishes, press the Enter key. Your computer will restart with the pre-installed operating system, drive, and software.
Dec 02, 2008 | IBM ThinkPad X41 Tablet PC
Toshiba Portege M700-S7002  Tablet PC Logo
347 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
