Question about Cub Cadet Street Sign- tractor lawn riding mower parts
1554 cub cadet stalls out when you turn mower deck on or when you step on pedal to move forward or reverse.
  • Anonymous Mar 19, 2014
    I have a cub cadet lt 1022 lawn tractorwhen i step on the pedal it hesitates to move forward or in reverse
    Scholar:
  • 110 Answers
Seat switch - or the wiring to it - is bad.
Posted on May 08, 2010
Why does my forward and back pedals on my cub cadet riding mower have so much play in them causing my mower not to move?
must have come disconnected from the trans. trace the linkage from the pedal back to the trans.
May 23, 2016 | Cub Cadet Garden
My Cub Cadet just got serviced for another 500 bucks and is doing the same thing as last year. Ran it all day then it starts to sputter and stalls. Model GT 1554 HELP!
Make sure the fuel filler cap breather hole is clear if its blocked it will create a vacuum in the tank which prevents the fuel flowing forward.
May 25, 2015 | Cub Cadet Garden
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
Wh;y does my cub cadet 1554 tractor mower lose power when engaged?
  • Does deck turn freely? Check and be sure mowing deck is not jammed or bad bearing etc. If nothing is wrong with deck, then check fuel filter, air cleaner element, dirty fuel system, bad gas, water in fuel, restricted fuel flow. Lack of fuel will cause engine to have lack power.
Aug 15, 2014 | Cub Cadet Garden
Cub cadet starts but won't move forward or reverse ? what should i try to do?
What model? I have a 1554, that I just took to the dealer, for repairs, for the same thing. The motor starts, the blades engage and cut, it just stopped moving forward, or reverse. If I remember, I'll get back on here and let you know, unless you already know?
Apr 12, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet engine runs but, also will not go in forward or reverse
you didnt say what model this is, but i assume its hydrostatic because it has a drive shaft. is the hydrostatic unit filled with oil¿ if its ok, check the linkage from the pedal to the rearend (hydrostatic drive) make sure its not broken or loose.. if that l@@ks ok, check both ends of the drive shaft making sure the couplers are not broke and the drive shaft is ok. hope this helps.
Jul 17, 2009 | Cub Cadet Street Sign- tractor lawn riding...
REMOVE PARKING BRAKE ENGINE STALLS
i have a cub cadet 2130 2000 seris but it quits when i rekwase the brake pedal
May 03, 2009 | Oregon Scientific Oregon Gator Mulcher...
Noisey Cub Cadet mower
If the noise is coming from the deck, locate the idle pulley on the deck. there should be 1 or 2 rubber "bumpers" at the opposite end of the pulley arm where it meets the "j" pin. If they are missing, it will make a loud metal to metal sound.
Apr 22, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
456 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
