Question about Mag Innovision InnoVision LT865s 18" Flat Panel LCD Monitor
My lt865b doesn't display anything and the display functions of the monitor do not respond at all i love the monitor and need help.After 3hrs use the display starting going all white then blacked out. I plugged in another monitor and its not the computer.I unplugged the power supply let it sit 30 min. plugged it back up and get the power light and the back light i can see but no display.
    President:
  • 1,561 Answers
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Posted on May 07, 2010
My Dell E173fp monitor display doesn't work with my macbook
The fine print says it should work. Real life might be different. Do you have a genius bar, found at Apple stores, anywhere close? If so, make an appointment and let them make the connection for you. The genius bar is a free service and I've never found anything that they haven't been able to fix...and fix it quickly...if it's fixable.
Apr 17, 2017 | Dell E173FP 17" LCD Monitor
What's your problem?Need help to fix my kurzweil pc 88 ... no function just powers on but no display...need help urgent
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 01, 2012 | Computers & Internet
Princeton Monitor Driver Pack R1.05 or any other driver which will work in order to get 1920x1200 resolution
NO driver will make a monitor do what you want, that is a function of the actual VIDEO card that is what makes a monitor display the high resolutions, NOT the monitor itself, a monitor doesn't really need a driver as such to work at any resolutions. So try a Video card driver upgrade this may help?
Oct 13, 2011 | Princeton Digital VL2418W LCD Monitor
Please help.. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds. cpu, disk drives and ram are working..
This is one of the serious problem that arises because if you set your monitor with a high resolution with high frequency, then the monitor doesn't display anything as it's frequency is out of the rang or limit of the monitor's actual resolution capacity. Each monitor will have a limit of max frequency that is said to be the Refresh rate (for each and every resolution setting the display is refreshed.) When high resolution is set with high frequency that is not supported by the monitor, it then display a message like "frequency out of range". If you press ESC key within the few seconds of this setting, it will revert back to its initial resolution. But if you continued with the setting of same High resolution with High frequency, the monitor is not going to display anything because its frequency is out of the range. Most of old monitors like CRT's etc doesn't support 1024×768 at a refresh rate greater than 60Hz.
Jun 20, 2011 | Asrock P4I45GV R5 Motherboard
No display on the monitor.
1) Ensure your computer is actually starting up.
2) There is a Fn -Special function combo that will switch the display from your LCD monitor to an external monitor. Try hitting that key combo several times to see if the display has been mistakenly sent to the external monitor.
3) Hook up an external monitor and hit the key combo to send the display to it. If this doesn't work, then you probably have a video/motherboard problem.
May 15, 2011 | Acer Aspire One PC Notebook
Hi, My Dell Studio 1735 Laptop doesnot display anything, i hear sounds of it getting rebooted and startedup but, wont display anything. I tried conencting to external monitor NO...
The video card most likely has failed. The computer will need to be serviced by a trained technician. The entire motherboard will need to be replaced.
Feb 28, 2011 | Dell STUDIO 1735 Motherboard - H274K
My ipod A1320 freezed and would not respond to anything.
Hi. My ipod nano (a1320) just stopped displaying anything. doesn't seem to charge or respond to plugging into computer.
Any idea what i can do?
Nov 05, 2010 | Apple iPod nano 2nd Generation MP3 Player
Hp 6735s was used last night and shut down properly but this morning turning it on the system continue booting without displaying anything on the screen which makes it blank / black........ Please I need...
If there is a display switch in the functions on the keyboard (most likely will look like a laptop monitor or a computer monitor on the keyboard). Press the function key and the button associated with that and wait 3 to 4 seconds (you may have to press it multiple times) If you have anything in the vga slot, then it may think a monitor is plugged in and won't display the laptop screen.
If none of the above work, then maybe your computer is having a systematic failure, or the screen connector is loose.
Jun 14, 2010 | HP Compaq 6735s Notebook
Mag Innovision InnoVision LT865s 18" Flat Panel LCD Monitor Logo
160 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
