Question about RCA 27R410T 27" TV
Tv stuck on one channel
Rca chassis # CTC203Cx1. hooked to cable box or not stuck on one channel.
2 Suggested Answers
demonicsaint
  • 160 Answers
SOURCE: Stuck on 1 channel
Get a cable box from the cable company it will be cheaper than repairing the tuner. Then you use the tuner from the cable box instead.
Posted on May 07, 2010
I have a RCA LCD TV model no. RLC3708A and when hooking it up when I took it out of box, I got to
I think you are confusing the channel on the tv and the channel of the cable company that is not something that you can pick up with the scan tv, scan tv is good for picking up local channel meaning air channel that we get with a antenna only not the cable chanel
Jun 24, 2012 | RCA Televison & Video
I have a magnavox sdtv tuner can I hook cable line that still has cable come threw the box
Yes. You may enter through the RF connections. Be sure your TV is on channel three or sometimes channel four.You must be in the same channel on the cable box. You will receive all channels the box is capable of receiving. If your TV has RCA connections in the back and the cable box also has RCA jacks...you can opt for an input in the TV. Inputs can generally give you a better picture and sound. Thanks for asking and show a few hands of support.
Feb 08, 2011 | RCA Televison & Video
I have just hooked up set top box to Sharp TV CX5182 and need to re-tune it? Can you send me instructions please as I can't find my operators manual. Many thanks.
By set top box do you mean a digital tuner box? If so and your tv is a newer flat panal than more than likely you wont need it anymore. That tuner will be built in. If this is the case than hook your anntena up to the new tv and go to the menu to do an auto channel search. That should do the trick. If it is an older tv and doesnt have the tuner then hook up the box the way you hooked it up before IE if you used cable than hook it up with cable if you used it with Composite cables(RCA) than use those the reason is some of those boxes you have to set that part up in the settings and that disabled the other output so if you had it set for cable than hooked it up with Composite(rca) nada, nothing would show. Once you hook it up and you see it on the screen then your good to go simple channel search from there. Also if you use cable then your tv needs to be on channel 3 or 4 if you use Composite(rca yellow red and white) then your tv has to be on the input channel that coencides with what input is hooked to.
Dec 13, 2010 | Televison & Video
Stuck on 1 channel
May 07, 2010 | RCA 27R410T 27" TV
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital...
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Feb 27, 2009 | RCA Televison & Video
Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Feb 01, 2009 | RCA DRC277 DVD Player
My rca tv
The remote control may only work for the cable box and you may have to manually put the TV on the correct input channel also you might double check that the cable to the TV is hooked to the antenna input. Here is the website for the manual TV if you think it might help.
http://tv.rca.com/RCATV/Assets/pdfs/27F520T_1641312E_IB_e-06.pdf
Sep 05, 2008 | RCA TruFlat 27F520T 27" TV
I have purchased the converter box to receive digital signals and my tv doesn't have the red/yellow/white connections. Is there a model of converter that will work on this tv which is an RCAModel F25423...
THE CONVERTER BOX HAS R.F. OUTPUT. JUST HOOK IT UP AND PUT THE T.V. ON CHANNEL 3.(OR WHAT EVER THE INSTRUCTIONS THAT CAM WITH THE BOX) YOU WILL NEED TO CHANGE THE CHANNELS WITH THE REMOTE THAT CAME WITH THE BOX. YOU MIGHT NEED TO SET UP THE BOX (SCAN FOR CHANNELS) THAT IS ALL IN THE INSTRUCTIONS THAT CAME WITH THE BOX.
DON.
Jun 15, 2008 | RCA Televison & Video
Rca vcr
there a a bunch of different ways. 1) if you don't have a cable box hooked up to this tv,plug the main cable wire into the vcr input then the vcr outout to the tv.2) if you do have a cable box, plug the main cable into the cable box input, then the output to the vcr input, then the vcr output to the tv. put both the tv & vcr on channel 3 for this connection. [ you must have the vcr on channel 3 to record from the cable box!] 3) if you have aux line/video or source inputs on the back of your tv,you can hook up rca cables [ red, white,& yellow ] from the rca outputs on the vcr to the tv inputs.
hope this helps
wg
Feb 04, 2008 | RCA VR637HF VHS VCR
Have cable.........but not working
The GE (actually RCA) 31GT659 has the notorious CTC187 chassis. This chassis developes cracks in the solder joints on the shields around the tuner and microprocessor, and can mess up the settings stored in the EPROM IC. This could result in channels going snowy, vertical collapse, loss of sound and/or total shut-down. The set should be resoldered and reprogrammed by someone experienced with this RCA chassis.
Jun 22, 2007 | GE 31GT659 31" TV
RCA 27R410T 27" TV Logo
52 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
