Question about Canon VIXIA HF100 Flash Media Camcorder
Canon HF100 zoom by itself, without touching the zoom button
  • chesbrougha May 07, 2010
    I'll give it a go when I get it back from the canon repair place. They wanted 265 to fix this problem, what a joke
I own an HF100 and i had the same zoom issue. I purchased a replacement zoom key assembly directly from canon (phone 732-521-7230 cost is about 25 dollars), and installed it myself. This has fixed the issue for me, and i am very glad i didnt have to pay to have it serviced. You can buy the part yourself and install it if you feel confident in your ability to disassemble/reassemble the camera correctly, or shop around for a local camera shop that can swap it out for you.
Posted on Jul 29, 2011
  • lindgrencoop Aug 09, 2011
    How would you rate the difficulty for doing this? You state that I should be confident that it can be reassembled, but I don't know what to expect when I open it up. Do I need to remove and reassemble alot? or would you say it the part is pretty accessible and fairly easy to fix?
    This appears to be a well know problem by Canon and they won't address the issue!
  • mattsn Aug 09, 2011
    I did not find it difficult, but if someone has never taken electronics apart, i suppose it would seem challenging. There are around 25 screws that you have to keep track of, and make sure they go back in the right place. The top bezel is slightly tricky to get off, since it snaps into place. There are 2 ribbon cables that need to be disconnected, one would have to know how to disconnect these, and have a little dexterity to connect them correctly. If this seems straightforward to you, then i'd say give it a go. If you have doubts maybe give it a shot and if you run into trouble then find a local repair shop to finish it up.
    As for canon's responsibility - when you take the zoom key assembly apart - its pretty obvious why the issue is so widespread. The part is cheaply made, and obviously has a limited life span. It is designed to be irreparable too, since it is held together by plastic - you have to destroy it to get to the metal contacts so cleaning or refurbing it is not an option. Pretty disappointing. Anyway, good luck.
  • 74 Answers
You have to whack it on the bottom this will fix the problem (seriously!) bang it down on a hard surface (not too hard!!!) and then see if its fixed. do it a couple of times and it should work fine.
Posted on May 07, 2010
  • 3 more comments
  • dj LaPlaya
    dj LaPlaya May 07, 2010
    cool, good luck! should save you quite a bit then! (dont bang it too hard though!)
  • mattsn Jul 29, 2011
    I see mattsn's comments on replacing the zoom key. How would you rate the difficulty for doing this? You state that I should be confident that it can be reassembled, but I don't know what to expect when I open it up.
  • Theresa Davido Dec 14, 2011
    Whacking worked!!! My HF100 was stuck in high zoom and I could not get it to focus. THANK YOU SO MUCH!
    Whacking worked!!! My zoom was stuck in high zoom and I couldn't get it to focus! THANK YOU SO MUCH!
Just purchased the zoom key assembly from Canon for about $35 ( incl. tax and shipping). I also purchased a good set of StanleyPrecision Screwdrivers from my local hardware store for about $6. The job was done in less than an hour. It's fiddly work, but not impossible. Just don't go crazy disassembling EVERY screw you see. First remove the battery, then the hand strap. Basically you work your way from bottom right to top left of the camera. Once the top housing is off and the zoom key assembly is loose you disconnect the ribbon cable. And voila! The pice is out. Finally you just work your way back in the reverse direction. If your worried about what goes where, then take photos as you go.
Posted on Jun 18, 2012
    New Friend:
My Friends! Do you know any shop with worldwide shipping or shipping to Russia? It looks really hard to find zoom key in my country.
Posted on Nov 20, 2012
Tip
Convert Canon HF100 MTS to MP4 for Play on iPhone/iPad-Remux MTS to MKV for WDTV
Lossless Convert and Export MTS to Various Video Formats for Watching on Various Devices <br />Transcode Canon HF100 MTS to Different Video Formats(MP4,MKV) for Various Devices Simultaneously <br />MTS to Various Video Formats for Different Devices-Convert Canon HF100 MTS to MP4 and MKV Meanwhile <br /> <br />Are you still being troubled by how to <b>Convert MTS files from Canon HF100 to Different Formats</b> that can Play on your iPhone and iPad and WDTV Live at home? Aunsoft Final Mate -<b><a href="http://canon-videoconverter.com/2011/07/transcode-canon-hf100-mts-to-different-video-formatsmp4mkv-for-various-devices-simultaneously/">Best Canon Video Formats Converter Tool</a></b> will help you. Its latest version has a new function- that is setting format of each movie separately and exporting at the same time. If you want to learn how to do it, just follow my guidance. <br /><br />How to <b><a href="http://www.aunsoft.com/final-mate/">Transcode Canon HF100 MTS to Multiple Video Formats</a></b> and Watching and Playing on iPhone/iPad or WDTV? <br /><br />1. Import MTS files from Canon HF100 to Aunsoft Final Mate. <br />Just connect HF100 to the computer via a USB cable. Follow the wizard and you can import the videos easily. <br /><br />2. Create New Movies for Conversion and Lossless Output. <br />Right click the mouse in the Movies Tab and choose "Create A Movie For Conversion", repeat the action and another movie is created. Then create a movie for lossless output. Just right click the mouse again and choose "Create A Movie For Lossless Output". Drag and drop the movie or movies you like to watch on iPhone and iPad from the Camcorder Tab to the blank movies for conversion and those you would like to watch on WDTV Live to the movie for lossless output. Then comes the Key Process before Export<b>: </b>Click the icon on the right side of the new movies and choose output formats separately. You can choose "iPhone MPEG-4 video(*mp4) under iPhone for both iPhone and iPad and choose "MKV format" for playing on WDTV Live. After this, it can <b><a href="http://www.aunsoft.com/final-mate/">Export Canon HF100 MTS to MP4 and MKV</a></b>. <br /> <br />3. <b>Export Movies with Different Formats</b>. <br />After the formats are set, just click the "Export" button. Aunsoft Final Mate will <b><a href="http://www.aunsoft.com/final-mate/">Lossless Convert and Export Movies Simultaneously</a></b>. What you should do next is to wait for the completion of the export. <br /><br />Finally, you can <b><a href="http://www.aunsoft.com/final-mate/">Enjoy MP4 on iPhone and iPad</a></b>or <b><a href="http://www.aunsoft.com/final-mate/">Watch MKV on WDTV Live</a></b> with your Family or Friends.
on Jul 22, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Replacing zoom switch on Canon Vixia HF100 camcorder.
I have had success finding such parts on Ebay though admittedly some must be shipped from overseas. You might also check Craigslist or Canon video forums for people selling this model for parts.
Nov 27, 2014 | Canon Cameras
Replacement of zoom switch assembly
Is the auto zoom set. Anyways, too hard to answer without the camera model
Nov 26, 2014 | Video Cameras
My Canon HF100 camcorder recently started to zoom or creep by itself. It really makes it difficult to record special moments in life cause you never know if it will zoom in by itself ruining the moment. ...
The problem is indeed athe zoom rocker switch and will require major disassembly to repair. This can be done fairly inexpensively but it's not really a user serviceable problem.
Below is a link to a repair facility which should be able to help you.
www.discountcamerarepair.com
Nov 07, 2011 | Video Cameras
Canon HF100 zooms in when not pressed down.
This is most likely a defective zoom rocker switch assembly. This will require major disassembly to repair and can usually be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Sep 21, 2011 | Canon VIXIA HF100 Flash Media Camcorder
My canon HF100 kept on zooming in by itself. I would turn it on and leave it alone for 30 to 40 seconds, suddenly it'll just zoom in to the middle. I am able to use the zoom, it only happen when I am not...
This is most likely a defective zoom rocker switch assembly and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Apr 19, 2011 | Canon VIXIA HF100 Flash Media Camcorder
Can you fix the zoom toggle on my Canon Vixia HF10? It's the "automatic zoom problem"
Yes. The zoom rocker switch problem can be fixed and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Nov 08, 2010 | Canon VIXIA HF100 Flash Media Camcorder
My Canon S3IS shuts down during zooming. What's the solution ?
It could be the batteries running low. The mechanical zoom consumes battery power and at a certain point the camera will turn itself off. If you wait a minute and turn it back on it seems OK, until you try the zoom again. If you are using non-Canon batteries the camera doesn't always detect the battery level accurately and may flash "low battery" when there is still power remaining, or just turn itself off without warning. So I suggest changing the batteries and check that the battery terminals are not dirty or loose.
Mar 25, 2010 | Canon Cameras
HF10 zoom goes without any explicit request
My HF10 started to mysteriously autozoom as well, and I had made no setup changes. I don't have exactly the same symptoms as you describe except that it would begin to zoom when I didn't want it to. I noticed the [I.AF] (Instant AutoFocus) icon, so I went into the menu (Camera Setup - AF Mode) and turned the "Instant AF" to "Normal AF". After that, the autozoom seemed to have stopped. I set it back to "Instant AF" and it did not autozoom again. I wouldn't know how to turn the autozoom back on again even if I wanted to, but thankfully it appears to be gone now. Hopefully it will stay in manual zoom mode. Hope that helps.
Dec 22, 2009 | Canon VIXIA HF10 HDV Camcorder
Open Questions:
Canon VIXIA HF100 Flash Media Camcorder Logo
2,299 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
