Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
MY NEW 6500 WIRELESS ALL-IN-ONE PRINTER ONLY PRINTS IN BLACK AND
WHITE HOWEVER, THE COLOR CARTRIDGES ARE INSTALLED IN THE UNIT, WHAT CAN I DO TO MAKE THIS UNIT PRODUCE COLOR COPIES?
  • 79 Answers
When you give the print command did you check the properties if B&W is selected or Color
Posted on May 07, 2010
Is there any way to print while missing one of the ink cartridges?
You should be able to print in black and white by going into the "printing preferences" menu and then click on the "color" tab. Click " print in greyscale", then click "apply". Good Luck !
Mar 07, 2013 | HP Officejet 6500 Wireless All-in-One...
My HP 6500 only prints yellow and black. I refilled all three color cartridges and only the yellow is working. Any ideas?
This printer having four cartridges and two print heads.Each print head having two pens, black, yellow & magenta,cyan. As you said yellow & black are OK.. So replace Magenta & Cyan print head..
Oct 28, 2011 | HP Officejet 6500 Wireless All-in-One...
The priter goes through the motion as always for printing but a blank piece of paper comes out. I have cleaned the print head but It still does the same thing. Do you have any suggestions that I might...
If you are printing using a color (not "black cartridge only" ) driver, yes, the printer won't print because it uses a "process black" when you use a color driver.
In other words it creates black using the 3 colors, and doesn't actually touch the black cartridge.
You will need to change the default driver to one that you create.
go into control panel, hardware and sound, devices and printers (win7)
right click the officejet 6500 (not the fax driver) and click printer properties
click the advanced tab, and click printing defaults
click the fast economical printing template.
Change "print in gray scale" to Black Ink Only
Click "save as" and name the profile "black draft"
click the newly created "black draft" profile, and click APPLY and OK
This will now be your default, and it will print in black and white while the color cartridges are empty.
Jul 29, 2011 | HP Officejet 6500 Wireless All-in-One...
My HP Officejet 6500 Wireless printer won't print in black when trying to print from Microsoft Office Word and Microsoft Office Excel or PDF. The ink cartridge is new. I have turned the printer off and...
I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
May 17, 2011 | HP Officejet 6500 Wireless All-in-One...
I just installed a black ink cartridge and it will not print. All of the other ink colors are printing.
Make sure the plastic is removed from the cartridge and it is seated properly. make sure to use genuine cartridges. You may have just got a bad one.
Feb 28, 2011 | HP Officejet 6500 Wireless All-in-One...
Can I print black and white without having color cartridges?
You need to have color cartridges installed for your printer to function. You can however print black and white with empty color cartridges. If you do this you may damage the print head and not be able to print in color again. If you can live without color printing I recommend a monochrome laser printer. It will never print color, costs 1/2 as much to print with, won't dry out, and the cartridges last way longer than ink cartridges.
Sep 28, 2010 | HP Officejet 6500 Wireless All-in-One...
I replaced my black ink and now it wont print anything after printing a printer report it shows all colors but black why wont it print black
you may use non genuine or expired cartridge, or does not pick the sticky paper over the head nozzle (refer to cartridge installation manual)
Mar 30, 2010 | HP Officejet 6500 Wireless All-in-One...
Printer only won't print in black
My printer did that a few months ago. I tried everything to get it printing black but in the end I had to take the ink cartridge back and return a new one. Some ink cartridges dry out when they are being shipped if not stored in proper conditions.
Mar 14, 2010 | HP Officejet 6500 Wireless All-in-One...
How do I change ink cartridge on my HP inkjet 6500 wireless printer.
Hi, When using refilled print cartridges, the Estimated Ink level and the Printer Status Window may indicate that the print cartridge is out of ink. Either continue to use the print cartridge until print quality degrades, or replace the print cartridge with a new HP print cartridge.
The methods of replacing the ink cartridge of the printer follows here:
Open the printer cover
The printer ink carriage will automatically goes to center
Once the carriage is in the center, the printer was ready to replace the ink.
Pull the down slowly the ink tank off the carriage..
Remember the place where the color/black position.
Remove each tank one at a time, and replace the ink with a new one.
Close the printer cover and it now ready to printer.
HP Deskjet 6500 Series Printer - Setting Definitions
Hope the instructions provided helps.
Dec 03, 2009 | HP Officejet 6500 Wireless All-in-One...
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
start
control panel
printer and fax
right click your printer, choose properties
go tab by tab and look for print quality and then try
something like this
choose econo mode, or ink saving mode to start.
try to print in grayscale mode and use only the black ink cartridge.
that should be your new default, and you don~t have to change it from winthin other programs
Mar 30, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
183 people viewed this question
Seeker5211
Seeker5211
