Question about Honda Karcher G2400HH-R Pressure Washer
No water flow from pump discharge port
I'm trying to repair a pump from a troy-built, 2008 model 2.2 gpm washer. Unit worked fine last summer. This past week no flow from the discharge. Nada. Zip. One thread suggested the unloader was stuck. The pump's manual suggested pump had no prime. I disassembled poppet valves and they seemed OK. Ditto the unloader and it was kind of stiff, though no corrosion. I loosened it a bit so the plunger moved a little easier and put the pump back on. Same issue. Nothing comes out of the discharge side. This unit has been used maybe 3 times I didn't see a hint of corrosion or scale in the poppets or unloader,, it's pristine. Also noticed I cannot push air into input freely. Normally, if you connect hose shouldn't the hose pressure force water out the discharge port (with wand hose disconnected) even with the engine off ? Any advice appreciated. Thanks.
  • 97 Answers
SOURCE: Gas driven portable pressure washer no longer draws chemicals up
Picks up under low pressure conditions by adjusting wand or changing tip.
Posted on Mar 19, 2009
  • 3600 Answers
SOURCE: honda gx270 pressure washer. water is not coming out strong.
did you check the inline screen for dirt?
Posted on May 24, 2009
  • 66 Answers
SOURCE: not enough pressure
change the sparkplug
Posted on Jul 09, 2009
  • 3740 Answers
SOURCE: I have a honda 2600 pressure washer. After
This is a symptom caused by a sticking Unloader valve. The Unloader valve is inside the pump outlet body under the large black knob.
Example picture :
Before doing any dis-assembly try this procedure first. This may sound weird but it often works. We do this with a short piece of garden hose,,,,, Add 3 to 4 ounces of engine oil into the water inlet by pouring the oil into and old short / cut off garden hose with the end elevated but connected to the pump inlet.
Slowly pull the engine starter cord so as to pump the added oil into the pump and let it sit over night. Just keep pulling the starter cord "IGNITION OFF" until you note oil exiting the high the high pressure hose connection.
Then connect everything like you normally would the next day.
MAKE sure to purge the water supply hose of air at the pump connection before starting the engine.
Start the engine. NOTING that your going to shoot out the oil you put in the day before..... Pull the wand trigger every 3 to 4 seconds so you cause the Unloader / thermal relief valve to stroke within the pump body. Don't give up... you have to do this for an extended period of time so that you have HIGH pressure each time you pull the wand trigger.
With the engine still running.... let it run trigger off for about 1 minute at mid engine speed. Pull the trigger again and see if you have high pressure. Do another long pause... then use as you normally would.
IF the above lubrication process does not work....
The Unloader / thermal relief valve needs to be dis-assembled so that the springs and seals can be lubricated with Lubriplate #105 white grease. Make sure to also lubricate the casing of the pump body before putting everything back into the pump body.
Here is the white grease tube your looking for at any automotive parts supply.
This should get you going again. Just note that Unloader valves will notoriously stick after end of season storage upon the next use. It is important after an extended non-use period that the wand trigger is cycled every 3 - 4 seconds to exercise the Unloader valve springs and seals in the pump body. You only need to do this for about 45 seconds.
Thanks for choosing FixYa,
Posted on Jan 18, 2011
SOURCE: My Troy Bilt power washer (using Honda GCV160
I had a similar problem. Turns out I had left the hose disconnected and some sort of wasp built a paper type nest inside the washer tube that the hose connects to. I had to take the pump off and take apart and then cleaned it out with a screw driver. Not too easy to do but finally got it clean. Same thing happened with the hose.
So, if you haven't used it for awhile, check that there is no blockage in the hose or pump tubes. You might be able to blow it out with an air compressor.
Posted on Feb 11, 2011
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
How to fix power washer with no pressure with out have to buy the hole pump what can i do to fix it
Cover soap inlet and retry. Mine will not pressurize without soap or without inlet covered.
Jul 22, 2014 | Annovi Reverberi Garden
Why the water is running from detergent siphoning tube?
The siphoning mechanism on almost all power washers use "The Venturi" effect to suck up the detergent. Basically, there's no pump...the force of the water passing the siphon hose causes a vacuum which draws the detergent up the tube. There's a small ball that is supposed to fall and block the tube when the trigger is released so it sounds like it got jammed up in there somehow. You could it apart and free it up but I would recommend just purchasing an external detergent dispenser. Home Depot carries them for about 15 bucks. They allow you to use soap with high pressure and bypass the always problematic siphon system.
Jun 08, 2014 | Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure...
I have an AE125 - had it for a couple of years at the cottage. We got the water hooked up this spring and all was fine. Last weekend, the unit stopped working. I flipped the breakers a couple of times...
Can tankless electric water heater be repaired? Sure.
Is it worth the expense if problem is going to happen again? I can't answer, but can offer resources.
New tank-type electric water heater costs $207 and new tank-type gas costs $320 at local box store.
You can install new tank-type electric yourself in a couple hours. DIY repair on tankless is not easy since parts are not at local box store, and what part do you need, and tankless parts can easily cost more than new tank-type water heater.
Open following link for Bosch troubleshooting resources.
GENERALLY, Tankless require .4 gpm (gallons per minute) water flow to activate heating cycle, and then require .25 gmp flow to keep heating cycle going.
For example .4 gallon per minute means faucet can fill 1 gallon container in 2-1/2 minutes
Some tankless units require more water flow, for example .75 gpm
Tankless water heaters have flow sensor that tells computer chip when enough water is flowing to activate heating cycle.
If the sensor is clogged, or if water filter inside tankless unit become clogged with dirt or sediment from hard water, then the unit does not signal enough water flow and will not activate.
Home filtration system and water softener can also slow the flow of water.
Low water pressure and crossover problem on single-handled faucet and crossover on recirculation system check valve and high thermostat setting can also cause heat cycle to not activate.
Tankless cannot be exposed to water with more than 11 grains hardness or parts inside tankless will coat with sediment and not work. Within 2 years the unit will not work, with diminished efficiency from the beginning.
If water is hard, and you cannot soften the water, or if water is dirty and cannot be cleaned, then the best recommendation is to use tank-type heater instead of tankless.
All costs are energy. For average home: Tankless electric is NOT cheaper to operate than tank-type electric. Tankless gas saves $1-8 per month. However, cost of unit and installation, cost of potential repairs and cost of parts, difficulty of DIY repairs, required yearly-monthly maintenance, etc outweigh expected savings.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 31, 2011 | Bosch AE125 PowerStar 4 GPM Indoor...
I have the Troy-bilt 2550 psi pressure washer with a Briggs & Stratton engine (model# 020337). Originally, it would start and die immediately. I took the pump apart and cleaned out the unloader valve...
I would replace the internal part of the unloader valve, it is known as the unloader seat, I can order you one it would take 2-3 days, Part number is 193972 price is $45.06. If you are interested in ordering one send me a email at with the information that I just gave you.
Another thing that you can check is the outlet check valve, the tube that you screw your high pressure hose onto has a valve built into it, if that valve went bad or if there is something stuck in it you would also have this problem. If you take the tube off the valve will be right where you screw that pipe onto the pump, the valve is part number 190592, price on this is $8.16.
Nov 10, 2010 | Karcher 2500 PSI Pressure Washer
Troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Sep 04, 2009 | Karcher 2500 PSI Pressure Washer
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Matag top load washer model # LAT9604AAE filled but no agitation
If just getting the water out is your main goal, this can be accomplished using a shop vacuum.
Be sure to unplug the power cord before attempting any repair! Another way to drain a machine is to use a bucket. Put the discharge end of the drain hose from the washer into the bucket, making sure the hose end is higher than the level of the water in the washer, and slowly lower the hose and bucket until the water flows into the bucket. Raise the bucket and hose end back up above the level in the machine tub to stop the flow. Repeat until the machine is empty.
Give the machine a try after removing some of the water as you may have tripped a limit switch and the unit may just be overfilled
Dec 29, 2008 | Maytag PAV2300 Top Load Washer
Honda Karcher G2400HH-R Pressure Washer Logo
82 people viewed this question
Top Honda Garden Experts
John Trevino
Are you a Honda Garden Expert? Answer questions, earn points and help others
