Question about Maytag MAH6700AWW Neptune Front-Load Washer
Belt keeps coming off
We have put the belt back on twice and if comes back off. The first time there was a red ribbon looking thing that we can not figure out belongs there or not.
  • 269 Answers
Was the machine noisy on spin cycle last time the belt did stay on,because that could be a sign that the bearings are on the way out.Also check that there are no wires wrapped around the pulley on the motor.When you said ribbon looking thing that sent alarms ringing be careful but check for damage to wiring.Hope I helped.
Good Luck.
Posted on May 07, 2010
Have a 2003 chevy trailblazer xlz my husband has put the serpentine belt back on the power steering pulley twice and it keeps coming off
I can think of three things to check. Proper belt-- proper belt tension--pulleys line-up.
Make sure the belt is clean.
Mar 08, 2016 | Cars & Trucks
My girlfriends 2003 dodge stratus died suddenly. she tried to start it and it cranked over then stopped. good battery. what possible things should i check and start?`
Timing belt is most likely cause of sudden shut down. The Stratus has a noninterference engine so no damage occurs and the belt change is an easy fix.Open the area. Remove the belt tensioner at the 7 o'clock position compress it and put a pin in the small hole to hold it, Line up the timing marks put the new belt on and pull the pin. Some times it;s the bearing on the crank pulley that fails. If you change it be sure to put the flange to the front, thats what keeps the belt from coming off.
Nov 03, 2014 | 2003 Dodge Stratus
Serpentine belt keeps coming off
With the belt on. Look at it inline with it. Every pulley should be inline/straight. If one is slanted just a little it will throw the belt. The only other thing would be the tensioner is bad.
Aug 06, 2014 | 2006 Ford Fusion
Lt4600 huskie riding mower :the belt that drives the blades keeps comming off .The authorized repair shop has replaced this belt twice the first year and it still comes off !.It's 2 years old . I
Sounds like you either have a bad bearing in the pullys or pully or the guides that keep that belt in place are not doing their job. Any repair shop can change out a belt. However, fixing it is another thing. I had a customer who said every since he had his lawn tractor the belt wouldn't last long enough to get a summer out of it. I found the spring missing of the tensioner pully for the belt when it's engaged and also the guide for the belt was on backwards and therefore cutting the face of the belt.
Oct 20, 2017 | Mtd Garden
The print head doesn't appear to be connected to the belt drive on my Epson C62. Is there a clip that has come undone that I can re-attach?  Prior to this I was experiencing a clanking noise when the...
if the carriage still moves, it's not the belt that has come undone. the best thing to do is remove the top cover (4 screws: two inside the front door, two on the back of the printer) and carefully remove the transparent ribbon that runs through the back of the ink carriage and clean this ribbon. it is used to measure the carriage's movement. be carefull not to stretch out the torsion spring. while you re-mount the ribbon, you can check if the drive belt is well fixed within the back of the carriage.
Mar 09, 2010 | Epson Stylus C62 InkJet Printer
The drum belt keeps coming off
Whenever you install a new belt, it is also a good idea to replace the idler pulley.
Nov 24, 2009 | Cars & Trucks
Windtunnel belt
I've successfully used a compatible belt - Royal 104425001 .It's still new, but for the time being at least - it works.
Jul 29, 2009 | Hoover S3765-040 WindTunnel Bagless...
Vacumm Belt keeps coming off.
stick a little bit of tape on the inner half of the spindle, this will put an angle on the belt and should prevent it slipping off.
Dec 23, 2008 | Hoover Vacuums
Maytag MAH6700AWW Neptune Front-Load Washer Logo
109 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
