Question about Keurig B60 Coffee Maker
Water doesn't go thru the machine
Pump makes a noise but no water goes thru to make the beverage
    Problem Solver:
  • 5 Answers
My Brewer did the same thing then shut itself off. It pissed me off so much that I hit it on the top. Like "The Fonze" starting up the jukebox, and Bingo. It worked. But after about a week of hitting the brewer everyday, I called Keurig and without hesitation they sent a replacement. After the replacement came I started playing with the old one and tried running vinegar thru it and so far it works without hitting it. So there's a few things you can try.. Either Hit it on the top. or Put Vinegar in the tank and clean it out several times. I did it about 20 times. and you may have to hit it to get it to pump the vinegar. Or when all else fails just call keurig. P.S., With the new brewer they will give you 2 free boxes of k-cups of your choice. A great customer service department ck!by the way. Good lu
Posted on May 08, 2010
The light goes on. I can feel the water is heated. Machine makes a lot of noise, but water doesn't pass from resivoir thru to frother wand or thru coffee filter. I am just running water to te
It needs to be descaled. After that, turn and try to make coffe but without the cofee. Turn on the steamer nozzle at the same time, that will draw the water to the coffee area, in fact try that first.
Dec 09, 2014 | Cuisinart EM-100 1000-Watt 15-Bar Espresso...
Frigidaire front load washer that will not start . it just buzzes. when it does start it stops after washing and leaves water in clothes asn buzzes.
it could either be a bad door switch or something stuck in the pump or a bad pump.if you set it to drain/spin will it drain out the water or does it buzz there?if it does drain i'd have to say you have a bad door switch.the model number you sent doesn't come up,you can unplug the machine,remove the hose that goes to the pump or run it before you unplug it and see if it's the pump making the sound or if the center of the pump can be removed to clean out the pump and check the pump for coins and junk,use a shop vac and vac out all the water in the tub and then lossen the hose or center of pump until water starts to leak out and vac it up as it comes out,check the pump and put it back together,add some water with a bucket or something and see if it drains out,if it doesn't drain and it sounds like the pump is making the noise you have a bad pump,if it buzzes and it's not the pump change out the door switch.the buzzing is electrical,things that could make this sound are the motor,the solenoids on the water valve or the door switch,if you can do some checks like see if it drains or try to find where the noise is coming from would be helpful.good luck and i hope this helps you out.
Oct 29, 2011 | Frigidaire ATF6000ES Front Load Washer
Euro Pro X 1750 psi Pressure washer won't start. It's plugged in and water is attached. it was fine last time i used it.Now it makes a short noise like it wants to start, but doesn't.
Check the nozzle to see if is plugged. If water can" pass thru , it won't read a water pressure drop and turn on the pump motor.
Aug 26, 2011 | Garden
My mother-in-law called and her dishwasher is making a loud noise when the motor runs. sounds like a bad bearing somewhere? the noise stops when it drains (motor not running?). does that sound like the...
There is only one motor -- it runs a water pump for recirculating the water when it's washing and runs a water pump when it's draining.
It sounds like the spray arm is making the noise -- this is the part thru which the motor / pump forces the water during the wash cycle -- the pumped water causes the arm to rotate -- a warn or loose spray arm or mount is likely the problem.
Or, it could be just some utensil stuck in the bottom of the dishwasher which the spray arm is rubbing.
More info, let me know.
Charlie
Jul 16, 2011 | Kenmore Dishwashers
My B40 is not pumping water through, and has been used twice.......Help please........ I purchased it online off of ebay......cannot return, but would like it fixed
mcdevito75 here, your coffee maker may need cleaning, with a clean or new paper filter in the machine, fill the resovoir with WHITE VINEGAR and let it cycle thru 3 times, 1/2 way thru the either 3rd or 4th time, stop 1/2 way thru shut machine off for 30 minutes, then resume, Now cycle plain water thru the machine 3--4 times to clean out the vinegar. If this doesn"t help, see any appliance repair outlet in your area, the pump could be bad.
Jul 11, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Makes noise but water doesn't come out
you should consider cleaning calc from your boiler( descaling ), and checking the pump presure. i think it will work ok after that.
Apr 02, 2009 | Hamilton Beach BrewStation 47665
Loud noise
it sounds like you have something stuck under the agitator thats causing a rubbing noise when it goes to spin or agitate.maybe a penny or something like that
Dec 28, 2008 | Frigidaire GLTF2940ES Front Load Washer
Maytag Netune Mah4000AWW
Makes a loud humming noise. Does the machine go thru its cycles ? Is the humm ther all the time ?
Jan 06, 2008 | Maytag MAH6500 Neptune Front Loading...
Keurig B60 Coffee Maker Logo
1,350 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
