Question about Homelite Garden
What type of gas do you use for PS33(UT10788) chainsaw ?
    President:
  • 2,220 Answers
This is a current Homelite product although not your saw. This clearly recommends 50:1 as do I. I find no OM for your saw, a "PS33 Chain Saw UT-10788"
http://www.homelite.com/product_manual/file_url/66/UT10540_60_80_QSG.pdf
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1 and have for a number of years.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
I suggest you contact Homelite and request an OM for your saw.
Homelite/Ryobi.com (Contact Us)
https://register.homelite.com/contact_us/new
Please ask they prove a link to a site where ALL homelite product OMs may be accessed.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 07, 2010
Homelite chain saw csp 3314 will start if i tip petrol in spark plug home but wont stay running
There could be a problem with either the fuel line going to the carb or the impulse line that's connected from the cylinder base that generates the 'pulsing' action that operates the diaphragm fuel pump. Today's alcohol rich gasoline has a tendency to weaken or even rot the rubber lines causing fuel delivery issues.
If you don't use your saw for extended periods, dump the tank empty then start the engine and run the residual gasoline from the line. This will help extend the life of the fuel lines.
Another possibility could be a blocked fuel filter, but that is remote.
Feb 22, 2015 | Homelite 12" Oregon Chain Saw Repl. Chain...
What type of petrol do I get for the chainsaw
What make and model of chainsaw do you have?
Chainsaws take the same gas you put in your vehicles, however the gas must be mixed with 2 cycle oil. The ratio of gas and oil depends on the make and model.
Reply back and I will look up the gas/oil ratio for you.
Thanks,
Handie Andie
Apr 21, 2011 | Garden
Where can i find a service center to purhase a chain adjusting assembly for a poulan 2055 chain saw in the tampa area
Poulan Service Locater
http://www.poulan.com/node6604.aspx
An example of an IPL for a "2055 Gas Chain Saw Type 7" follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2055-Gas-Chain-Saw-Type-7/75.2055-Gas-Chain-Saw-Type-7.1.59.1.html
See the "Handle, Bar and Chassis Assembly" print, item 29, $2.53
If not your saw, yours can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type. HTH
Lou
Feb 24, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 221 pro 40cc chainsaw that needs a fuel kit, the primer, gas hose, and more
A typical fuel system and a couple of tips can be found here:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
Poulan PP221 Gas Chain Saw Type 4 IPL link (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP221-Gas-Chain-Saw-Type-4/75.PP221-Gas-Chain-Saw-Type-4.1.59.1.html
All fuel components are listed.
If not your saw yours can be found here:
Poulan.com
If you need additional help or have questions please reply below and I will get back to you. HTH
Lou
Feb 18, 2010 | Poulan Garden
I need to replace all of the gas lines. Do I have
There is no reason to disassemble your saw, Please stop.
You can find a typical fuel system and a couple of suggestions here:
An IPL for a Poulan “PP3816 Gas Saw Type 2” can be found here - There are slightly different models. Please ensure this applies to your saw:
http://www.ordertree.com/modelinfo/PWE/PP3816-Gas-Saw-Type-2/75.PP3816-Gas-Saw-Type-2.1.59.1.html
The small hose goes between the filter and carburetor and from the IPL the carburetor and primer.
The large hose between the primer and fuel tank (return).
If the above is not the correct model it can be found here:
Poulan.com
Hose can be purchased at any chainsaw outlet, Inquire about how much hose they recommend. I have not found a good hose stretcher and I have been looking. Good luck with your project. Any additional questions you may have can be asked below. I hope you found this most helpful.
Lou
Jan 31, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
How do you replace the fuel lines
This should help. Snap a photo then a small sample of each to your local chainsaw seller.
The link is a Poulan 2375 Gas Saw Type 7 IPL.
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
http://www.ordertree.com/modelinfo/PWE/2375-Gas-Saw-Type-7/75.2375-Gas-Saw-Type-7.1.59.1.html
If not your saw you can find the correct one here:
Poulan.com
If you have more questions you can reply below. I hope this is helpful.
Lou
Jan 23, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
790 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
