Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
Tv wont turn on power button just keeps flashing and making a clicking noise but after 30 minutes it comes on
    Guru:
  • 416 Answers
Your power supply needs repaired. You have some bad capacitors on it. I published a tutorial in my Tips & Tricks which can help you identify and replace these parts. Have a look if you want to try to fix this TV yourself. Best wishes, I hope this was helpful.
Posted on May 07, 2010
  • Samsung Master
  • 3,866 Answers
The issue here is the power supply, Now what may have caused this issue is unknown I am not there to look at it.
if you know eletronics:
Now things to check:
1. Capacitors on poer supply
2. relay
3. transformer
Otherwise consult a local repair shop as soon as you open a TV your beyond what we call user friendly repair. when in doubt contact a local expert to have a peak.
thanks for using fixya.com please do leave your feedback and ratings for your free answer today.
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Jan 03, 2016 | Televison & Video
50PFP5332D Plasma tv. My tv sounds like its trying to turn on but the blue light flashes and a clicking noise keeps repeating and no picture.
I have the same problem with my TV. I haven't verified this yet, but someone I know who's a electronics genius told me that its the buttons on the TV (power, channel, volume, etc.) He said at the factory many of the "button boards" were tightened too much and cracked. When you turn the TV on, the clicking noise is a loose connection. He said it's easy to replace yourself, and about 30 bucks on ebay. No promises though.
May 20, 2010 | Philips 50PFP5332D 50 in. Plasma...
Tv wont turn on
I have a Philips 60" Rear Projection, and all of a sudden I have no picture or sound. I push the power button, and all it does is click. It will keep clicking until I turn it off. Anyone seen this problem?
May 15, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
My Magnavox plasma screen tv, model number: 42MF237S/37 makes a clicking sound when I try to turn it on. No sounds, no picture, just the clicking noise. Things I have tried so far: 1) Turning the TV off...
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Jan 03, 2010 | Philips Magnavox 27MS343S 27" TV
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Sony bravia tv
Solution is simple....
First, unplug power cable from the back of your TV. You will notice the flashing light is still flashing. Don't worry, go to the Second step.
Second, keep pressing on the POWER button, located on the panel at the top of your TV, to shut off your TV. This will stop the flashing light from appearing.
Third, Plug the power cable back onto your TV
Fourth, press the POWER botton ONCE, using the same button used in the Second step to turn your TV back on.
Fifth, you will see the POWER light comes on, as normal.
Sixth, using your remote control, press the green button to turn on. Your TV should work as normal.
Jun 08, 2008 | Televison & Video
TV wont power on, clicking noise and flashing standby led
Sounds pretty bad to me, I had a computer monitor that did a similar thing when plugged in after blowing, it's not a good thing. I didn't even bother to mess with it. You may have to replace the whole power board or at least have a whole handful of pieces to re-solder. It most likely isn't worth it unless your other tv's are under 30" and you don't have a lot of money ;)
- Dave
Dec 28, 2007 | JVC AV-32D305 32" TV
I heated up board with hair dryer through back of TV without taking back cover off. The heat was on high for approx. 5min. and was placed on right side of TV about 1/3 up from bottom.
Nov 20, 2007 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
349 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
