Question about GE GSL25JFR Brushed Steel Side by Side Refrigerator
No water comes out of door densper
But have water coming out after solenoid to door bottom after water despensor pushed
  • jmp8 Mar 31, 2008
    When the knob is pressed for water, water does not come. Removed the tube in the blue connector loop below the freezer door to test the water pump and circuit. Now when the knob is pressed water comes out of the removed tube. So pump is good and circuit is good too. So water is not able to climb from below the freezer door to the dispenser area? Any idea.
Used the hair dryer on back of freezer door that was in yuor post its thanks
Posted on Mar 28, 2008
SOURCE:
I have a 2008 bottom freezer refrigerator 795.7854 with water on left side of refrig door and water is not flowing. Changed filter and checked water supply and they are ok. What else can I do?
There is usually a solenoid where the supply water hooks up. Need to check it. Pull off hose going from solenoid to freezer and see if water comes out of solenoid when water is pushed on door. If it comes out there, then the line may be frozen.
Mar 01, 2014 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
HAVE A KENMORE FRIDGE M.#106.74253400 WATER DESPENSOR STOPPED WORKING AN CAN HEAR IT HUMMING AN ALSO THE ICE MAKER WORKS SO I NO ITS GETTING WATER? THANKS
my kenmore did the same thing, It had a duel water solenoid on it and one that let water into the door water dispenser went bad. also my ice cube started to get smaller, the rubber in the other side of the water solenoid was dry rotting and eventually ruined the ice maker. I replaced the duel solenoid and ice maker and had no more problems.The solenoid is on the back of the fridge, it is what the main water supply connects to.
Dec 31, 2011 | Refrigerators
GE Profile side by side. Water flow at door dispenser is slooooow. Replaced filter - no joy, replaced solenoid, still slow. Now I have narrowed the problem down to the feed/return lines to/from & the...
Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
Sep 25, 2010 | GE Refrigerators
Water not coming out of front dispenser
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 02, 2010 | Hotpoint Refrigerators
No water flow through door . Both ice functions are normal. Change of filter did not help
Dec 30, 2009 | Kenmore Refrigerators
Water dispenser just stopped dispensing water? Have changed filter only 3-4 weeks ago - any suggestions
Nov 18, 2009 | Whirlpool Refrigerators
Water will not come through my dispenser on my refrigerator, it is not frozen in the lines cause i checked this. It worked when i first hooked it up.
Without the model number I will only be able to tell you what makes most models work. When you push the lever for water, there is a micro-switch behind it that's activated. This sends a signal to the water valve at the lower back of your unit. It opens and allows water to flow. There is one connection between the micro-switch and the valve. It's located at the door hinge. It could be either the top one or the bottom. Make sue it's plugged in real good. While pushing the water lever, wiggle the plug. If it makes water come out, disconnect the plug and re-connect. If no difference, I would say the most likely problem is the water valve at the back of the fridge. You can apply 110 volts to the side that had the larger tube (On most, this is the valve for the water in door) When you connect 110 to it, if water comes out on the door, you have a bad micro-switch. If no water, you have a bad water valve. You will need to replace at least the solenoid on top. I suggest you replace the whole valve. Good luck
Nov 17, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Water in door suddly quite. have replaced the water filter but still notthing
If you do hear it Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
Nov 03, 2009 | Maytag Refrigerators
Water not working but ice is
If you do hear it Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it doesleave the door open till it thaws.
Sep 30, 2009 | Refrigerators
GE GSL25JFR Brushed Steel Side by Side Refrigerator Logo
83 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
