Our washer trips the breaker now and is full of water each time we attempt to run a load. It is a dedicated breaker in our home for that outlet. I have a friend that is an electrician that suggested that I run an extension cord to a different outlet to test if the root of the problem is the outlet our the washer. The end result was the same: tripped breaker and a washer full of water...AGAIN! I have gone on-line and gotten every response from "just go buy a new washer if yours is 5 years old now" to it is the internal electrical in the house simply going bad". Do you have any other more realistic suggestions please? Willing to break things down but to be honest this is all new territory for me in the home repair area. Thanks... Chris
  • oldguy5 May 11, 2010
    Sorry about that, See the following: https://secured.whirlpool.com/Service/Sr...$FILE/L-55.pdf
    Without knowing what kind / model of washer, I can only suggest a couple of things. 1. Have you tried another appliance in the outlet that is tripping?? If something else works well, it's likely not the House circuits and/or breaker. 2. Assuming that this is a basic Whirlpool / Kenmore top load, direct drive washer, see the Whirlpool Service Manual for these washers. It has troubleshooting and testing procedures.
  • 64 Answers
Chris; My GUESS is that the transmission (the machineary which moves the adgitator) is binding up. This is causing your motor to pull more current and thus trips the breaker. If you have no experience call around to repair places and ask them to estimate replacing a transmission and if it is available. Make sure they give a price for the parts and the labor seperately. *Mark*
Posted on May 07, 2010
Frigidaire Gallery Series front load washer and dryer. Last Friday the dryer started sparking and tripped the breaker. We had an appliance man come and he could not figure out what caused it.
The washer tripped the breaker once and OR after the breaker was reset it ran additional loads with no problem then it tripped the breaker again.
Intermittent problems are always difficult to diagnose because the problem usually doesn't occur when you're making the checks.
If the washer ran additional loads the problem will not be an electrical short with one of the washer parts. If the lid switch had a short it wouldn't run additional loads.
if the additional loads used the same cycle as previously. A timer can have an internal short that might trip the breaker in heavy duty cycle but not the permanent press cycle.
If you have access to a clamp on amp meter, see the image below, then you can check the amp draw of the washer. The washer normally will draw about 10-15 amps at start up and about 5-8 amps while running. The house breaker for you washer should be rated at 20 amps.
If the washer is running and drawing less than 20 amps and the breaker trips then if can be a weak house breaker.
Mid cycle the washer is most likely draining or spinning and if the bearing or pump locks up then the washer may draw additional amps to try to start and trip the breaker.
The key to this problem is what the amp draw of the washer is when the house breaker trips.
To narrow this problem down, there are three places that could be causing the ( outlet) GFCI to trip, a malfunction in the washing machine, a problem with the downstream wiring (aka load side of the GFCI-other items connected on same circuit), or the GFCI outlet itself. If there isn't anything downstream, then plugging the washing machine into another GFCI outlet, or simply swapping out the outlet for a known good GFCI outlet, will identify if the outlet itself is faulty.
If the outlet trips when the washing machine isn't running and isn't even plugged in, then there's a fault in the wiring on the load side of the GFCI outlet.
If the issue is neither of the above, then running the washing machine and monitoring to see which step is occurring when the trip happens will isolate what part of the washing machine may be leaking current to a ground. It could be a certain water level, a motor being engaged, a transition step in the controller, etc
Beware some techs believe that most Washing machines or any other motor should not be on a GFCI! Should be a dedicated single receptacle. If there are other outlets on the washer GFCI, replace that GFCI with a single receptacle and put the GFCI on the next jump in order to protect other outlets.
Another item to check is ur lid switch which may have gotten moister inside and created a short_ or broken open and the rubber seal dried out over time, and the switch assembly will be exposed. water can splash onto the assembly, somehow causing the GFCI to trip. In any event, if you are having trouble with your washing machine stopping mid-cycle for any reason, test and replacing the lid switchis probably a worthwhile idea, as it is cheap and easy to replace.
By the way my advice is free cuz God is good!
Jan 11, 2017 | Frigidaire Washing Machines
Hi lg washer dryer combo trips safety switch as soon as plugged in and wall turned on
Jan 03, 2017 | LG Washing Machines
This washer intermittently trips the breaker about once a week. I have tried another circuit and it trips that breaker too. What is the most likely cause?
May 28, 2015 | Washing Machines
Admiral washer. Did load of laundry, breaker tripped, and is still full of water. Reset breaker, and hear a small click after I pull knob to restart washer. Breaker trips. No leak, and outlet is good
If the washer ran additional loads the problem will not be an electrical short with one of the washer parts. If the lid switch had a short it wouldn't run the additional loads.
You don't say if the additional loads used the same cycle as previously. A timer can have an internal short that might trip the breaker in heavy duty cycle but not the permanent press cycle.
May 22, 2015 | Admiral Washing Machines
When put on a wash it trips the electric
May 10, 2015 | Miele Washing Machines
Es-f800ks washing machine is power supply problem..That means is when i plug in the power then just 3 second only comming..after that no power..I try it many time ..It's same things..
Mar 29, 2015 | Washing Machines
Deawoo washing machin when start spin timer will triped elecricity
The washer tripped the breaker once and after the breaker was reset it ran additional loads with no problem then it tripped the breaker again.
Mar 28, 2015 | Daewoo Dryers
Ground fault keeps tripping
Mar 17, 2015 | Washing Machines
I got 2 wascomat gen5 that trips breakers only on rinse cycle
LG Tromm washer tripped breaker, now won't come on at all
Jan 06, 2014 | LG WM0642H Front Load
Washing Machines Logo
82 people viewed this question
Top Washing Machines Experts
