Question about Tricity Bendix AW1200 Front Load Washer
Tricity bendix aw1001w has an unknown error code, the led labled end flashing 3 times, any ideas?
  • 269 Answers
It could be one of the E30 codes which would relate to the pressure switch or an earth fault on the heating element there could be a wiring fault or p.c.b. fault check wires off heater at bottom rear of machine,remove back plate 4 screws.Hope this helps.
Good Luck.
Posted on May 07, 2010
How to remove filter on tricity bendix 1000 washing machine?
tricity bendix aw1001w eco shower washing machine ...
? 1:11
www.youtube.com/watch?v=lJZrGLfYdtQ
Aug 19, 2009 - Uploaded by whichwasher2007
my aunt's old tricity bendix. it says aw1000w on the front, but check ... How do you clean out mold in the ...
Sep 29, 2015 | Tricity Bendix AW1000W Front Load Washer
Blocked drain pump
get a air compressor at the drain end and blow air up the hose to try unblock what ever could be over the sensor. OR get your garden hose and force water the other way to try unblock
Jan 05, 2013 | Tricity Bendix Washing Machines
Tricity Bendix AW1260W - drum won't turn - 5 beep error repeats
Washer motor control board failure is the likely problem, also check all connectors for signs of burning. Also test the washer motor.
Apr 24, 2017 | Tricity Bendix AW1260W Front Load Washer
Tricity bendix aw1001w banged then stopped working i changed the fuse in the plug and moved to another wall socket still not working what will it be please
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB. I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 18, 2011 | Tricity Bendix AW1000W Front Load Washer
Tricity bendix aw1001w door lock wiring...
If you have multimeter and can use / 1 wire = live feed 1 wire is switch, 3rd is a netural idea is door lock gets 240 volt live netural feed energises the lock which in turn switches feed over to other connection..look at interlock to get idea what wire goes where....
Oct 31, 2009 | Tricity Bendix AW1000W Front Load Washer
Error code tricity bendix aw1200w washing machine
I think this is a problem with the thermister (built in to the heating element assembly).
Feb 21, 2008 | Tricity Bendix AW1200 Front Load Washer
Tricity Bendix AW1001w
is the door locking if not replace it.
Nov 23, 2007 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
My tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1200 Front Load Washer Logo
344 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
