Question about Brother IntelliFAX 2800 Laser Fax
Is not receiving faxes...
The screen reads SLEEPING.....then the time thenb TAD...what is this TAD?..could this be the problem?..please advise
5 Suggested Answers
SOURCE: Problem receiving faxes
your fax is in tad mode (telephone answering device) press the receive button (next to the start button) until you see fax only on the display this will correct the problem.if you have faxes in memory press the report key for reports, then opt.1 for help list
look for print fax
Posted on Aug 18, 2008
  • 16 Answers
SOURCE: Can't receive fax when on
this fax works on one mode at a time either TAD (Telephone Answering device) or F/T (Fax/Tel). so you can't use both at a time. Thanks
Posted on Aug 24, 2009
FixinFax
  • 3085 Answers
SOURCE: I am trying to recieve fax on brother vax 1360. I
Fax only.
Posted on Sep 30, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: My intellifax 775 has a code TAD...what does this
This means your receive mode is set to TAD or telephone answering device. If you have a dedicated phone line it should be in Auto or automatic receive. There is a button on the panel to change the mode to auto.
Posted on Oct 20, 2009
I can't receive a fax i can send one but cant receive
Hi there!
You can try checking on these steps to resolve your issue:
1. Make sure that you have the normal screen on the LCD ex. date/time FAX (Receive modes can be TAD, MANUAL, FAX/TEL) Please take note of the display.
2. Just to double check press Hook to verify if you have a dial tone.
3. Make sure you have the correct Receive mode on your screen
4. To change the Receive mode to the correct receive mode just press Menu 0,1 then press the arrow keys to select the correct Receive Mode press OK to choose your selection & press the STOP/EXIT key to go back to the main screen.
Hope this helps!
Rate if it works
Thanks!
Mar 31, 2011 | Brother MFC 240C All-In-One InkJet Printer
TAD error
Change the RECEIVE MODE to FAX ONLY. TAD stands for telephone answering device which is used if one of this device is attached the EXT port.
Dec 08, 2009 | Brother IntelliFAX 560 Plain Paper Fax
Can't receive fax when on "TAD" but answering machine works and when on "F/T" can get fax but answering machine won't work
Aug 08, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Sends faxes fine, but will not receive. Message "FAD" on screen
Could the message be reading "TAD"? If you have an answering machine hooked up anywhere on the same line as the fax, you need to refer to page 16 of your manual. Set your answering machine to 2 rings and de-activate the toll saver mode. If you have a dedicated fax line without the TAD, set your fax recieving mode to fax only by pressing the MODE button under the LCD display untill fax only isindicated
Jul 07, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
look for print fax
Jul 15, 2008 | Brother IntelliFAX 2800 Laser Fax
Set up to receive fax
To select or change your Receive Mode
If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 0, 1.
3 Press ▲ or ▼ to select Fax Only,
Fax/Tel, External TAD or
Manual.
Press Menu/Set.
4 Press Stop/Exit.
Setting the Ring Delay
The Ring Delay sets the number of times the MFC rings before it
answers in Fax Only or Fax/Tel mode. If you have extension
phones on the same line as the MFC or subscribe to the telephone
company’s Distinctive Ring service, keep the Ring Delay setting of 4.
(See Operation from extension telephones on page A-7 and Easy
Receive
on page 4-4.)
1 If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many
times the line rings before the MFC
answers (00, 01, 02, 03 or 04).
Press Menu/Set.
(If you select 00, the line won’t ring at all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Apr 02, 2008 | Samsung CLX 3160fn All-In-One Printer
Receive faxes
In the receive mode choose tad. The fax will then distinguish between a fax and a call.
Feb 16, 2008 | Brother FAX-575 Plain Paper Thermal
To recieve fax on brother
Press the 'RECEIVE MODE' button on the right side of the control panel, its next to the large 'FAX START' button. Here are your options :
Select Receive Mode
MANUAL
—You must answer all calls yourself. If you hear fax tones, press
Fax Start
to begin receiving the fax, then hang up. You can use this mode with
Distinctive Ringing. (See
Distinctive Ring
, page 8-1.)
FAX ONLY
—The fax machine automatically answers every call as a fax call. You
cannot receive a voice call, but you can dial out and make a voice call.
FAX/TEL
—The fax machine automatically answers every call. If the call is a fax, it
prints the fax. If the call is not a fax, it signals you with a double-ring (ring-ring),
different from the phone company ringing, to alert you to pick up the call. If you select
this setting, you’ll need to set the Ring Delay and F/T Ring Time features (on the
following pages). If you have extension phones on the same line as the fax machine,
set Ring Delay to 4. (See
For FAX/TEL Mode Only
, page 5-5.)
TAD:ANSWER MACH.
—This is the only setting in which you can use an external
answering machine. Your telephone answering device is connected to your fax
machine, and answers every call. Once the TAD answers, the fax machine listens for
fax tones. If it detects fax tones, it prints the fax.
The TAD setting works
only
with an external telephone answering device (TAD); it
does not work with telephone company Voice Mail. Ring Delay and F/T Ring Time
do
not
work in this setting.
Nov 27, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
External TAD
You ought to be able to set the receive mode to tad or something like that. that way you can receive faxes without being there. Lawrence
Oct 10, 2007 | Brother FAX-575 Plain Paper Thermal
What does "TAD" mean when it appears on the screen?
TAD is Telephone Answering Device. TAD mode is the only mode that can be used with an external telephone answering device (unless you are using a distinctive ring number for receiving faxes). Your telephone answering device must be connected to the jack on the fax machine (labeled "EXT" for USA). When someone dials your telephone/fax number (to send a fax or to speak to you), all the telephones (including the FAX) will ring according to the number of rings you set on the TAD. The Ring Delay setting is not recognized in the TAD mode. If you do not answer the call, the TAD will answer. As your outgoing message is playing, the Fax is in the background, silently listening for fax tones. If the FAX hears fax tones, it will automatically go into the receive mode. If the FAX does not hear fax tones, it remains silent, allowing the caller to leave a message. The above information is correct for a Brother fax machine. Is your fax automatically picking up the call or do you have to push a panel button to start the receive fax process? Perhaps the fax is already "in" your fax machine's memory and only needs a manual printout. Check the fax call log.
Aug 16, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
15 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
