Question about Oregon Scientific Complete Carburetor for Stihl 4122 Brush Cutter and 4226HS Hedge Trimmer
Stihl 011 av wont start
Im fixing a 011av for a guy. I put new plug,fuel pick up and cleaned carb. Also reset carb screws. Still wont run, has great spark and cylinder appears to be wet with gas.
  • 2,100 Answers
Flooded? Try a new plug, or get that one cleaned up. If it is sparking and wet, it should fire, even if it doesn't run, it should spark. Did you put the jets or the needle valves back to where they were? I think they start out at 1 1/4 turns out , then adjust the low and high. If it is fouling out with too much gas, the low speed jet is open too far.
Posted on May 08, 2010
Stihl 024 AV won't start. Replaced carb, plug, air filter, fuel line. Ran fine for 10 min then quit.
Fuel mixed properly and fresh?
if you put a few drops of fuel directly into carb, does it run for a few seconds?
have you checked the piston for scoring? (By removing muffler)
Apr 22, 2017 | Stihl Garden
Stihl chainsaw problems
Adjust the high speed screw on carb
Install a new spark plug
Use fresh fuel
Aug 05, 2014 | Stihl Garden
My stihl fs56 strimmer will not start,i have a spark & fuel new plug cleaned carb help please
if you have spark and fuel then id be looking at lack of compression.. damaged piston ring or damaged crank seal/gasket
Apr 15, 2014 | Stihl Garden
Stihl 038 super av starts hard, once started runs great till its warmed up then dies and wont start
check the seals on the crankshaft for a leak and the ignition module for a loss of spark as it warms up.
Dec 07, 2012 | Stihl 038av Case Buffers Caps / Plugs 2...
I have a stihl hs 45 hedge trimmer, It starts but wont run, idles on choke than as soon as i swap it to run it stalls, i start on run it fires and than stalls. I have changed the spark plug and dioframes...
Hi, re -check the fuel pickup line. To do this you need to stretch it at the ribbed section as they are renouned for perishing in this area between the ribs, especially if it is a black line. The new type is green. Hope this helps, regards Phil.
Aug 08, 2011 | Garden
Hi i have a 91 cbr1000f that i just picked up and it wont run. i have spark and fuel to the carbs but still wont run. it has no air box on it and i have to find one on ebay but u would think it would still...
No, it will run, but not good for it to run with out filters, also may run a little sluggish with out it. I think your problem is dirty carbs. If you put your hand over the carbs it will force pull fuel into the cyls and start on this fuel but you may not have throttle. Take the carbs off remove the bowls and have a good old time cleaning them do not mess with any adjustment screws. you might find just clean any small holes and vents with small wires and spray can brake cleaner. becareful with the gaskets new kits cost 20 or so for each carb. Ride careful. Have fun. .
Jul 04, 2009 | 1991 Honda CBR 1000 F
STIHL FS110R weedeater won't start, does not hit at all. Cleaned plug, spark arrester and air filter, what's up? Like new!
my son flooded out my stihl weedeater, I took it had a new filter put in and it started right up. he went to use it again and now it wont start! It sat overnight and i still can start it! Any suggestions please
Mar 11, 2009 | Garden
Stihl MS 260 Pro wont run wide open or idle.
Hi brandon First change the sparkplug with the same heat range,Check and clean the gas filter with compressed air.Remove the carb and very carefully disassembly entirely.Check the gaskets and the diafragms.At the fuel pump side there is a fine screen(clean it).Check the needle,the spring and lever.Unlock the screws L and H(note how many turns are they).Put the corp of the carb in a special clean solution for 12 hours and then clean it with compressed air(something is clogged there).Put all back together and try to start the engine. regards savumihai71
Feb 12, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Oregon Scientific Complete Carburetor for Stihl 4122 Brush Cutter and 4226HS Hedge Trimmer Logo
1,317 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
