Question about Whirlpool LSR8433K Top Load Washer
The central piece doesn't move when the washer is working only in the spinning mode
  • 64 Answers
Have someone help you look under the washer. Tilt it up and back and look underneath. Do you see one belt or two? Is it worn? If the motor and belt is good then transmission is bad. Call places with you make and model for an estimate. P.S. Have you noticed grease stain on your clothes after washing?
Posted on May 07, 2010
Washer does not spin. Makes noise but drum doesn’t move
replace the rubber drive belt, unplug the machine remove the back panel to reach it as they do get worn and will wash but as the load sits at the bottom of the drum in spin mode the drum becomes heavier when the washing is sitting in the bottom its harder to start the rotation eric
Jan 18, 2018 | Washing Machines
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
Washer doesn't spin
posted in wrong section... probably the plastic piece connecting motor to drive unit
Jul 20, 2012 | Computers & Internet
What is error code F11 on a Kenmore washer
F11 is a Serial Communication error.
Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears.
Press Cancell, then by pressing the drain spin button once on the left side then move to the spin speed button the the right.
Press this button until no-spin lights.
Press the prewash button 4 times. C00 should appear in the display.
Let it run it's tests, there will be 8 of them and end up on C08.
If this doesn't work, it's best you wait for the service tech.
Keep us updated.
May 04, 2011 | Hotpoint VWSR4160GWW Top Load Washer
Maytag lat6914aae top load washer shakes violently in spin cycle
A washer can have self leveling legs at the back. If they are rusty or clogged and not free to move, they will not self level and the machine will rock when working. Check the leveling apparatus, it's a bunch of metal pieces going across the lower back of the machine. Spray them with a lubricant and move them to make sure they are free.
Apr 27, 2009 | Kenmore 22422 Top Load Washer
Whirlpool ht duet washer throwing codes. f11,f dl, f0
Serial Communication ErrorSerial Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)Check the Drive system for any worn or failed componenCheck Wire HarnessCheck MCUCheck CCU Check MotorCheck Wire Harness good luck
shaun
Mar 26, 2009 | Whirlpool GHW9400 Duet Washer
Kenmore 80 series washer
drum is stationary in wash and moves only in spin
Aug 19, 2008 | Kenmore 24032\24036 Top Load Washer
Loud spin, doesn't fill, dial doesn't move.
yes you do have to remove the top off the washer and the washer should come with a mounting kit that must be used when stacking this unit. as far as your filling and draining problem i have had this problem several times before you have to replace your speed control board or sometimes called the speed control unit in the lower right hand corner of your washer
Sep 08, 2007 | Kenmore 43142 Front Load Washer
Whirlpool LSR8433K Top Load Washer Logo
Sal De
Gerry Harvey
Gerry Harvey
