Question about Gateway GM5664 Desktop PC
GM5664 will not boot up, What can I do?
My Gateway GM5664 will not boot up, What can I do? This Screen appears twice:
Client Mac ADDR: 00 1E 90 74 BD 8B GUID: 00000000-0000-0000-0807-060504030201
PXE-E53: No Boot filename received
PXE-M0F: Exiting NVIDA Boot Agent
After the secod time the screen tells me to insert the systems disc and it return. All I have is the recovery disc, i made in the beginning, and the OS Disc
  • Gateway Master
  • 11,800 Answers
There's something very wrong with the boot order from your pc: apparently now it's set to boot from network - something that is done only in network servers.  This happens when the BIOS battery (or the BIOS chip itself) start failing - it's time to start saving for a new pc, this motherboard has started to show signs of old age.
Enter the BIOS and set a new order: put the cd first, then the hard disk second and finally disable all the others. Save, exit and it should boot just fine
Posted on May 07, 2010
Testimonial: " Thank You Very Much although I am a Little disheartened by the fact that the comp seems to be near it's end especially since I've had it for just over a year. Is there anything that can be done to extend it's life?"
  • Azrael SRL May 08, 2010
    Replace the power source with a better one - this is the first thing that fails in a pc and usually takes the entire pc with it. Something like
    http://www.tigerdirect.com/applications/...
    will offer great performances for a rock-bottom price. Also clean regularly the inside of the case by using a vacuum and a can of compressed aid, overheating accelerates the ageing process.
Black screen with white letters reading "REBOOT AND SELECT PROPER BOOT DEVICE"
Misty here is what I would do:
1.Start the computer in safe mode.
2. update drivers. I go into Slim Driver - a free prog. and scan the system to see if ok or need updates.
3. once updated, reboot the system normally - any change? GL
Feb 01, 2014 | Dell Inspiron M5030 Laptop
Intel UNDI, PXE-2.0 (build 082) Copyright (C) 1997-2000 Intel Corporation
As soon as you power on your PC, start pressing the F2 key. This should bring up the BIOS (Basic Input Output Systems) screen. Make sure your Hard Drive is listed in the Boot order. Usually a CD drive is listed first, then the Hard Drive as a second boot device. If you do not see the Hard Drive listed, then it probably is bad and needs replacing. If it is listed correctly in the boot order, your Operating System has crashed, and you will need the recovery disks or the instalation disk for your Operating System (XP, Win7,etc.)
Aug 11, 2012 | Acer Computers & Internet
Broadcom UNDI PXE-2.1 v12.20 copyright(c) 200 - 2009 broadcom corporation copyright(c) 1997- 2000 intel corporation all rights reserved client MAC ADDR: 88 AE 1D 6F 5A 3A GUID: 478ADE06 B852 67B5 10E7...
From the description it is the hard drive, remove hardware and reseat back into position, sometimes this will restart the hard drive, if no change chances are you will need it replaced, but I would suggest getting it tested first.
May 26, 2012 | Acer Aspire Computers & Internet
How do i fix a black screen when i can't log on to my dell n 4030 notebook
your harddrive (hd) isnt working properly or not fitted in hd-place right.
many hd's have really low life expectancy.
Mar 27, 2012 | Dell Computers & Internet
How do i fix my laptop if it don't start and it says intel UNDI , PXE-2.1 (build 082) copyright (c) 1997-2000 intel corporation for atheros PCIE ethernet controller v2.0.0.4(03/03/09) client mac...
Your laptop can't find an operating system, check the operating system as it installed properly. If its is then you need to check the hard disk drive of your laptop because it is missing from the motherboard.
Jul 21, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I have Dell Studio 1555, Vista but later intalled XP on drive D, I have problem my CD/DVD drive does not read the Data, CD does not revolve in high speed make the tak tak sound as it try to read bit after...
Your message indicates that Pxe Boot is enabled (boot from lan card), go to bios settings and from the list of first boot options, please select the hard disk (hdd) or Cd-rom as the first boot device, reboot your system and check whether this helps or not.
It is also necessary to disconnect and reconnect your dvd/cd rom's power cable and data cable.
If you don't know how to do, then just reset the bios settings to "load default" ...
Good luck.
Thanks for using FixYa.
Jun 24, 2010 | Computers & Internet
Receiving PXE-E61 media test failure/PXE-M0F exiting intel PXE RO
If you get this error in a black screen before windows xp can boot up....
CLIENT MAC ADDR: xxxxxxx GUID: xxxxxxxxxx
PXE-E53: no boot filename recived
PXE-MOF: exiting intel PXE Rom
Your network card's settings in bios have somehow been changed. PXE means Pre-Execution Enviroment. In other words, it allows your network card to connect to a network server to pull operating system images off the network and other files without having an operating system installed.
The Fix,
Go into BIOS press F2 or F12 whatever your PC's screen at bootup says. In Bios, reset your bios settings to the default bios settings, or original settings. This fixed my problem with the above error. Nothing else fixed it. Windows Recovery cd will not fix it, because you cannot boot windows if this error is still occuring, Your network card will keep prompting DHCP to search for a network.
Its a bios function not a windows function.
Jan 21, 2009 | Toshiba Satellite A135-S2276 Notebook
Open Questions:
Gateway GM5664 Desktop PC Logo
549 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
