Question about Accurian AVR-5048 Receiver
The error message flashes "protector" then it shuts off.
Hi
I bought this receiver about 1.5 yrs ago and have used it 10 hours max and never over an hour at a time. When I turned it on today it played fine. Then after 10 or so min's it flashed "protector" then shut off. So I turned it back on again and it flashes again and shuts off. It just keeps doing this over and over. I tried unpluging it. I tried unpluging all the speakers and nothing helps. Any advice you can offer will be much appreciated. Oh ! and there is nothing mentioned in the manual about a protector error. Thanks
2 Suggested Answers
SOURCE: Accurian 6.1 Receiver flashing PROTECTOR
I been reading a lot, dont have much experience but this is what I have seen.... if your speakers are 4 ohm then your impedance on these speaker will be too low and should cause the receiver to overheat, this is a natural occurance as the extra power has to go somewhere, in this case the form of heat, this particular receiver is meant for 6 ohm speakers, so i would recoommend either 6 or 8 ohm speaker systems (too high is okay, just not as loud), was it getting really hot before it couldnt turn on anymore? I mean burning hot... if it really got that hot it's possible that some loose solder points may have disconnected, if you fried your board... good luck... cant help ya there... maybe take it to a radioshack?
Posted on Dec 11, 2008
Why did amp indicate error and turn off?
SONY ' eSupport - PROTECT or PROTECTOR is flashing in ...
https://us.en.kb.sony.com/.../protect-or-protector-is-flashing-in-the-displa...
Aug 15, 2015 - Turn off the home audio device, and remove all speaker wires from ... If a cord is frayed or in contact with another terminal, an error will occur.
How to get my receiver to stop flashing protected - Sony's ...
https://community.sony.com/t5/Home...to...receiver...stop.../182577
Sep 15, 2013 - intermittent video ... How to get my receiver to stop flashing protected ... is below the rated impedance range indicated on the rear of the home audio ... D.If the home audio device still displays a PROTECT error or does not turn ...
My AV receiver says OVERLOAD and shuts off, what should ...
Dec 26, 2015 | Pioneer Audio Players & Recorders
When I turn on my Home Theater Sony Model hcd-hdx576wf this message appears, "protector, push power". what I can do?
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
1. Check the speaker wires and speakers for proper connections.
2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
Dec 17, 2010 | Sony Televison & Video
Failed software download error messages 02 and 10
My version is actually DTR 67500T but I did not realise that you had recorded a different model !! until too late.The shop replaced it with another box
Nov 10, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
We bought a LG WD(M)-14341(6)FD washing machine approx 3 yrs ago and served us well. 2 weeks ago it developed a fault when the message FE flashed up on the LCD panel. We called a repair man in and he duly...
The errors indicate the water valve or water sensor failure.
The washing machine have a water sensor to prevent overfilling. If you change the sensor, the washer will be work again.
FE error mean washer overfilling
PE error mean water sensor fault
I hope to be usefull !
Apr 15, 2017 | LG Washing Machines
I can't send text messages with my Cricket Motorola Q
Hey, I just bought the same phone from ebay, and it was preflashed for cricket too. My phone had the same exact problem. I called cricket technical support at 1-800-274-2538 and they refreshed my flashing while i was on the phone with them. As soon as I got off the phone with them my phone worked perfectly. I hope this helps! - Alyssa
Apr 14, 2009 | Motorola Mobility Moto Q
Flashing message on my reciever
PROTECT, PROTECTOR or the letter P is flashing in the display of the A/V receiver. Solution
sp.gif sp.gif Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
  2. Reduce the volume level. IMPORTANT: Ifthe receiver is played back at maximum volume level it may enter theprotect mode. Maximum volume listening will cause the receiver to runvery hot and may drain the output capacitors.
  5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Somereceivers provide compatibility with the higher sampling frequenciesthrough alternate connections. Consult the owners manual for specificinformation.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Dec 15, 2008 | Sony STR-DE545 Receiver
1 red light: Error E 74
try the x-clamp fix, also try a different av cable as yours can be damaged
Oct 25, 2007 | Microsoft Xbox 360 Console
" unknown disc, check disc" message
3 out of 10 will record 30-40 min and say DISK FULL..
2+ out of 10 I'll record 2- 1 hour shows then I'll
get a " disc unknown " error...
www.govideo.com site NOR customerservice@govideio.com works..
did they go out of business ?
who bought them ? where's the support ?
joe_wht@msn.com
Dec 14, 2006 | GoVideo VR3840 DVD Recorder/VCR
Accurian AVR-5048 Receiver Logo
Top Accurian Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Accurian Audio Player and Recorder Expert? Answer questions, earn points and help others
