Question about Magnavox DP100MW8B Player
Magnavox dvd dp100mw8b stuck in progressive scan already tried holding the stop button for 5 seconds, I can hear the video, but not see it clear
  • demonicsaint
    demonicsaint May 11, 2010
    Are you holding the stop button on the player instead of the remote.
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: I'm trying to connect a
You meed manuals...
http://www.retrevo.com/support/Sony-STR-DG520-Receivers-manual/id/13748dj478/t/2/
http://dl.owneriq.net/f/f39f9a46-b9dd-4fd7-aeb0-4a46c566a44a.pdf
Posted on Feb 06, 2011
Testimonial: "I appreciate your attempt to help. But I needed the manual for the Magnavox DVD player more than I did the Sony. I already had the Sony Manual. Tks"
muntejaya
  • 10421 Answers
SOURCE: I am looking for an unlock code for my Magnavox
Please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__
Posted on Feb 27, 2011
Stuck on progressive scan
This is a common issue with this brand of player. While the unit is on, and without any discs inserted, press and hold STOP button on the front panel (not the remote) for 10 seconds, then release. This should turn the progressive scan function off and revert the video output of the player back to normal interlace.
Zenith, Samsung, Magnavox, and Goldstar DVD players are notorious for progressive scan headaches, but it's easy to correct.
Apr 16, 2011 | Zenith Televison & Video
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Dvd player stuck in progressive mode
ok i got a solutioN!!!
ok go to ur actual dvd/vcr player (not the remote) and press and hole the STOP botton for like 5-10 seconds.
thank goodnesss!!!!!!!!!!!!
your welcome! :]]
Jun 11, 2008 | Zenith XBV243 DVD Player/VCR
Stuck in Progressive Mode
Had the same problem; here's what i did. Take DVD out of Receiver, close door to receiver and hold down stop button on receiver itself for five(5) seconds. changes should take effect and progressive scan screen should revert back to sanyo screen.
May 06, 2008 | Dual DWM-3900 System
SD-K530SU - Turning Off Progressive Scan Mode
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Nov 06, 2007 | Insignia NS-DVDR1 DVD Recorder
Magnavox DVD/VCR player stuck in progressive scan mode
Right, mine was stuck for a couple of weeks and i tried lots of different things. What worked for me was plugging it out and in again. Press the power switch and then just before the tv switches from normal mode to dvd recorder press the eject button. However, I pressed it a few time so not exactly sure which one worked.
The burned DVD is now in a thousand pieces at the bottom of my bin!
Good Luck!
Oct 20, 2007 | Emerson EWD2202 DVD Player/VCR
How do I turn off Progressive scan?
Hi, follow the steps it may help !! Press STOP button. ? If playing a disc, press the STOP button twice so that ?STOP?, appears on the display. Press and hold P.SCAN button on the remote control for over 5 seconds. ? Pressing and holding the button for over 5 seconds will select "Progressive Scan" and "Interlace Scan" alternately. ? When you select P.SCAN, "P.SCAN" will appear on the display. ? To set P.Scan mode for DivX discs, press the P.SCAN button on the remote control for more than 5 seconds with no disc in the unit (?'NO DISC" on the display), then load the DivX disc and play. regards sreejith
Jul 17, 2007 | Progressive DVHE210 210 DVD Player
Locked into progressive scan AND Setup is Unavailable
The key is to make sure you REMOVE all DVDs and VCRs from the player, then hold the stop button on the unit down for 5 seconds.
Oct 23, 2006 | Zenith XBV442 DVD Player/VCR
Progressive Scan
SOLUTION #1
you'll need to reset. press stop to stop any playing disc, and press stop again holding it for 5 seconds to reset the system.
SOLUTION #2
works with remote only
SOULTION #3
While Disc is Running,
By using remote control,
Press Stop Button once to stop the disc (Stop in Memory Mode)
Press Stop Button once again to go into Full Stop
Then, Press & Hold Stop Button for 5 Second or So.
GOOD LUCK!
koreanainusa
Jan 21, 2006 | Zenith XBS444 System
Magnavox DP100MW8B Player Logo
83 people viewed this question
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
