Question about Pioneer DJm 400 Professional DJ Mixer
My DJM 400 jst wont turn on for some reason. I was jst using it normally and then it just turns off, i dunno y but it jst did and its not workin now. whats wrong with it?
  • 5,603 Answers
The transformer is shown having a fuse in it or on it. I suspect that the fuse MAY have gone.
With the power switch on, verify there is relatively low resistance between the pins or the power cord, probably less than 200 ohms.
If you find a fuse is blown, suspect a bad electrolyric cap.
Posted on May 08, 2010
Voltage djm 400
You do not need to replace anything, buy or have a stepdown transformer
of at least 200 watts rating.
Step-down transformer specs:
220V input
110V output
However , there are other DJM400 versions that have a built in 220V
input. Have a tech to guide you.
Oct 22, 2012 | Pioneer DJm 400 Professional DJ Mixer
I have a djm 400 and it has started producing a buzzing sound through the speakers. I can take the same speaker cables from the djm 400 and hook them up to my backup mixer and the buzzing goes away. What...
Since it works with your other mixer, the DJM400 is probably fine. You have a ground loop.
Make sure ALL, and I do mean ALL... (re-read that if there is any confusion) interconnected equipment WILL BE powered from the same receptacle or source. If speakers or amps are powered from one place and the DJM is from the other end of the room you likely have a ground loop and you can ex[ect buzzing. Run extension cords alongside the audio leads if necessaryy to carry power from where the amps or speakers are plugged in back to the DJM400 and ANY pther connected equipment.
Jan 07, 2011 | Pioneer DJm 400 Professional DJ Mixer
Does it buzz through cans? (headphones). Try listening on headphones (turn off any amps and speakers) on cue to each channel you use and to the master output. is it stil there? if so it's an all round earthing fault. If it's all good through the cans (sorry...I mean headphones), try it with the amp/s on again. If the buzz is back it souds like the screen on the main audio output connecters has come off inside.
It's a quick fix, but if you have never used a solder iron, take to someone who has.
Hi, I have a DJM 400 Pioneer mixer, I'm having trouble with the output levels. It seems the left output is only putting out about half the sound of the right output.I have used different RCA cables,...
Please try a set of headphones. If it is balanced in the phones, then I suspect trouble might be in the muting circuits of the main output.
Next test is to verify the outputs using direct inputs to the CD input...
Dec 01, 2010 | Pioneer DJm 400 Professional DJ Mixer
I have a pioneer djm mixer 400,I hooked it up to 2cdj mk1002. I want to run them through my pioneer reciever.which is a vsx 1020.im having a problem.IT works okay,if i run the cd player directly to cd...
If your CD player works hooked up to the DJ board, then try hooking the line out of the board into a auxiliary in or line in in or record in on your receiver using the appropriate cables.Try the CD in first and if there is too much signal then use the CD/Tape in. You need to match the output signal of your board to the input signal of your amp. Hope this helps.
Oct 22, 2010 | Pioneer DJm 400 Professional DJ Mixer
DJM - 400 effects Button will not turn on
IF everything else (all buttons and functions) are working, then I would SUSPECT that the actual button switch has failed.
Probably the internal guts of the button have broken and what was random was actually the parts intermittently bouncing around giving false contacts.
OFTEN the replacement of the parts require dis-assembling the whole control panel which requires a bit of expertise AND patience.
IF the button is a little switch unit, that is an unsolder and solder in new switch.. If the buttons are conductive rubber type keyboard, then it probably requires cleaning... for that you use 99% isoprophyl alcohol and Q-Tips.
Unless you are adept at electronics I would recommend taking this to a shop. Care in dis-assembly and handling of the connecting cables is a must.
Apr 12, 2010 | Pioneer DJm 400 Professional DJ Mixer
DJM 400 Keep going into over on the channel and the master volume
To keep your levels down keep the TRIM don which is the gray knob. Also keep the hi, mid, and low knobs at the medium level. The control cables are for using the fader start function.
Jun 02, 2009 | Pioneer DJm 400 Professional DJ Mixer
How to connect my qqualizer to my djm pioneer 400 mixer
Use the stereo master outs from the DJM into the A and B Inputs of the EQ (you'll need 2 phono to Jack or 2 phono to XLR cables) then from the A and B Outputs of the EQ to the power amp/ speakers, etc (you'll need jack or XLR cables depending on what is powereing your speakers)
May 27, 2009 | Pioneer DJm 400 Professional DJ Mixer
One Output low on DJM 400
This may not be the correct solution, but have you checked the switches on the back of the DJM-400 to see if one output is set to "PHONO" mode?
Apr 17, 2009 | Pioneer DJm 400 Professional DJ Mixer
Pioneer DJM-400 mixer turns on, but channels aren't working
could be a few things , what have you tried to trouble shoot the problem ?
My steps would be ;
check all leads (even if you KNOW u pluged them in)
check the gain is set corectly .
check the line phono slectors are set to what ever you have you leads pluged into on the back of the mixer ( there is 4 red and white RCA plugs , 2 for phono,2 for line CDJs shold be using line )
if you are using digital cables to conect your CDJs , on the back on the mixer there is a small switch marked "CD or digital" make sure that is sleceted "digital " . if ur not using digital cables make sure it is on "CD" .
the info iv put here is based on the DJM-800 so your mixer my not have some of these featers as iv never used a 400 . hope this helps dued . check out www.djtutor.com for more tricks and tips . Pratices'N'enjoy !
Dec 28, 2008 | Pioneer DJm 400 Professional DJ Mixer
Pioneer DJm 400 Professional DJ Mixer Logo
287 people viewed this question
Top Pioneer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Pioneer Music Expert? Answer questions, earn points and help others
