Question about ACR Maylong Group FD-220 Car GPS Receiver
Charged the gps but still won't turn on.
Hi. I have charged my gps. The light on it is green which I assume means that the gps is fully charged. However, when I hold and release the power button, the unit will not turn on. Please Help!!!!!!!!
How do you know when the afterglow bluetooth is fully charged?
my charging light is white i would assume it would turn blue,green,i would assume any color but white how did you get yours to connect mines charging but i cannot figure out how to connect it
May 22, 2012 | Radio Communications
My battery indicator won't turn green when it is fully charged.what is this issue?
It is possible one of the battery cells has degraded enough the battery is not showing a full charge, or there is an issue with the green light, but this is minor provided everything is working.
Mar 07, 2012 | Acer Aspire One D250 16GHz Intel Atom...
Hi i have an experia ant the littli led light on the top stays on red all the time
Hi.
The little red light means your battery requires charging.
Plug in the charger and allow it to charge.
It should change colour to orange when it has over 15% charge in it and then turns green when it is 90% charged.
If it still stays red dispite being fully charged. Try removing the battery for a few seconds and then replace it again.
I hope this helps.
If your phone is fully charged and it still has a red light, then take it back to the shop you acquired it and get a replacement.
It means you have a hardware fault.
Mar 09, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Do not know if chair is taking a charge lights just keep moving across armrest .how do u tell when fully charged?
hi let me see if i can help ,
When the lights go back and forth on your joystick that means the chair knows its pluged in .Now the chair itself has a built in charger that is mounted on the back of your chair .The back of the chair ,there is a opening a cutout in the frame .when you plug in your chair there will be a red light and a yellow ,yellow means the chair is charging, wait till it turns green,this means fully charged.When you plug in the chair youll see the lights through that hole.Look for the lights.
I recommend my customers to leave there chair charging over night look at the light it will be green when you turn the chair on the joystick should show fully charge.
Good luck hope i was of some help.
Jan 20, 2011 | Invacare Supply Group Invacare Pronto M51...
On a vector jump start system, does the green light have to stay on to indicate that is charged> what if only the 2-3 red light go on when i press the test button?, when the green is flashing while...
2 - 3 red lights indicate not fully charged. Green light = fully charged.
Not fully charged does not mean it will not function. For best results, your device should be fully charged. If you have an emergency and are not fully charged, it will not hurt to try to help with a partial charged device IMHO
Thanks for posting at FixYa.com
Dec 13, 2009 | JUMP START SYSTEM
Wont charge or turn on
not sure how long you have had this, but if the unit was completely turned off or battery completely dead, you have to hold the power button for about 15 seconds for the 3000t to start up...assuming the charge light at the top right is orange (that means its charging) no light means its not charging, green light means fully charged. if there is no power light on at the top right of unit, either the charger is bad or the port on the board is bad (which i do have) good luck and hope this helps. bill
Jul 05, 2009 | Magellan RoadMate 3000T GPS Receiver
Peg perego 12v charger question
The green light means it is ready to use. If the battery is bad though, the light will still be green.
Mar 07, 2009 | Peg Perego 12 Volt Rechargeable Battery
Green light stays on my evesham nav cam 7700 sat nav
did you try the reset buttom and see if that works
Feb 03, 2009 | Evesham Nav-Cam 7700 GPS Receiver
Charging the battery the amber light comes on, but then after a while the amber light flashes. Does this mean the battery is charged? It used to turn to green with the battery that came with my...
if it turns green that means that it is charged, but it then if it turns amber that means that it is going bad
thanks
hope this works for you
Aug 27, 2008 | Acer Computers & Internet
Charging Garmin 350 battery
I guess it should be fully green, it takes several hours, and you wont kill it if you let it charge overnight.
May 14, 2008 | Garmin nuvi 350 GPS Receiver
ACR Maylong Group FD-220 Car GPS Receiver Logo
66 people viewed this question
Top ACR GPS Experts
Are you an ACR GPS Expert? Answer questions, earn points and help others
