Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman LT-1000 lawn tractor. After running for 10 minuted, it coughs and shuts off. I leave it sit for 15 min. Then I get another 10 minutes, before it shuts down. I suspect the chock is having a problems. I need instructions on fixing the chock.
  • myoest1
    myoest1 May 08, 2010
    The engine is a Briggs and Stratton 18 HP OHV Intek. The engines model number is: 5BSXS.5012VP 276016 .
    When running the lawn tractor yesterday, without the engine cover or air filter, that puffs of smoke came out of the Air Intake. Could this indicate that that the engine is flooding???
  • 952 Answers
Thanks for using FixYa.
All you need to do is to have the fuel system cleaned. Replace the fuel filter and you should be good to go.
I hope this helps. Thanks and good day.
HotRatchet
Posted on May 08, 2010
    Guru:
  • 415 Answers
It is usually easier to obtain these instructions through the manufacturer of the engine in your tractor. You will need the make and model number of the engine. Do you have a make and model number of the engine?
Posted on May 07, 2010
  • laura Newman May 09, 2010
    Thanks for the engine information, Myoest1. Here is a copy of the Operator's Manual for you tractor with choke/throttle adjustment instructions found on page 28.
    Happy Mother's Day! :-)
I have a 2002, 6.75 craftsman presswasher when I start it, it runs for 10 min's then it quits. why and what can I do about it?
10 minutes exactly like you can time it each time after it sits for 15 minutes with out starting it? If it shuts off exactly each time after sitting for 15 minutes with out starting it's the gas cap. Leave it a little loose so air can get in the fuel tank and see if it keeps running if so just buy another gas cap. Get the part number from searsdirect.com and buy it on Ebay cheeper. MJ
Sep 24, 2015 | Craftsman Garden
Craftsman LT 1000 mower I am having problems with
I have a LT 1000. I drilled out the holes in the gas cap. If they plug, you will notice the gas tank gets sucked in from the vacuum.
Gary
Sep 20, 2011 | Craftsman Garden
Instructions for fixing the choke on a Craftsman LT-1000 lawn tra
I have been hearing alot of this problem. Well it is gravity flow. I just bought a 2002 lt1000 17 hp without a carb the guy was having the same problem so he sent the carb away to get checked out and low and behold it got lost. He waited the summer to see if it would show up but it did not. He got mad and bought a new bigger one. Any ways i am waiting on a new one. Now in my reading these problems i discovered that the fuel line coming out of the tank to the carb is lower. Might be somthing to look at. JIM
May 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
May 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
2 year old craftsman 42" deck tractor runs fine for 15 minutes then sputters and dies. Will start, run 2-3 minutes, die again. Leave sit will run for 20 minutes.
if it restarts immediately, check the vent in the gas cap for restriction. also, the solenoid on the bottom of the carburetor may be sticking or getting weak. if you have to let it sit for awhile before it retarts, the ignition module may be breaking down when it heats up. i'd bet on the gas cap or solenoid though
Sep 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Lawn mower
First ncheck for a dirty fuel filter, if its dirty enough it will starve the engine for fuel after a few minutes, then slowly let the fuel system refill as it sits.
Aug 27, 2009 | Garden
Walk behind craftsman lawn mower. starts but shuts off after 15 minutes then will restart after it sits for 10 or 20 minutes
not sure what model but it sounds like it runs hot? make sure the fuel/oil mixture is correct, exhaust is not clogged, sparkplug is in good condition. hope this helps.
Jul 12, 2009 | Garden
Engine coughs and stops after about 15 min. of cutting
check the vacuum line from pump to crank case fo leaks
Apr 25, 2009 | Garden
Possible carburetor problem? Mower runs for
i have a lt 1000 2005 when i start it with cold engine it boggs for a minute then it starts to run smoothly please help me
Apr 19, 2009 | Craftsman Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
228 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
