Question about Canon PowerShot Pro1 Digital Camera
Hi.. Can you tell me as to what is the maximum CF memory card that can be used with Canon Powershot Pro1
  • 2,005 Answers
When this model came out a 1GB card was a large capacity card, so Canon's specifications stop there. I talked with a friend who has used a 4GB card in a Pro 1, and it's possible that it may work with capacities even larger than that. But I think you will be able to use a 4GB without problems.
Posted on May 07, 2010
My Canon Powershot Pro1 will not accept the memory card. The screen flashes "Memory Card Error" every time I turn it on.
Your camera uses a Compact Flash card so it's asking you to format the card.
Here is a diagram to show you were to go and the process for formatting the memory card
Diagram
I had one tough time finding a DPF manual for this camera. Looks like a feature rich camera cheers have fun
Jan 17, 2011 | Canon PowerShot Pro1 Digital Camera
I own a Canon Powershot pro 90 IS with 16 MB CF memory card. I want to upgrade the card. Can you tell me whats the maximum capacity the Camera can take.
The camera can take whichever capacity card your want. Type 1 and 2 CF cards up to and past 16GB are available. It is really what you can afford and how many frames you want to put on a single card before downloading it.
Aug 30, 2010 | Cameras
I get a memory card error even though it has a card installed
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
  3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
  4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  5. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Aug 03, 2010 | Canon PowerShot A70 Digital Camera
Canon A10 - "CF card error" with new 4GB card
You need to format new cards in the camera before using.
Apr 05, 2010 | Canon PowerShot A10 Digital Camera
My new CF card for my camera is reading card error. should I buy a new one?
Sounds like you bought a new compact flash card. They are making two different types of memory cards. One is the new SDHC which transfer 32 frames per second. The first set was only doing 16 frames per seconds. I beat that you have a new memory and your camera is not design to read the new memory
Nov 09, 2009 | Canon PowerShot Pro1 Digital Camera
It wont recognise memory cards
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, don't fret. Although professional repair would be more costly than the value of the camera, there is a very good chance that you can repair this yourself. Please see this link.
Oct 18, 2009 | Canon PowerShot Pro1 Digital Camera
Larger Memory Card for PowerShot 300
Use the camera to format the card. Press Menu button, select the tools menu, scrolll down to the selection showing the memory capacity of your card and select it. The "format card?" selection should pop up. Select "yes".
Aug 22, 2008 | Canon PowerShot A300 Digital Camera
CF Card Error
Check your memory card to see if its locked!
Jan 03, 2008 | Vivitar ViviCam 3915 Digital Camera
CF Card Error
Well there is a known problem witht eh CF memory design, i hope this is not your problem but it may be. Take your camera into a well lit area or get a small flash light. Open the memory door and peek down inside the camera and look at the pins inside the camera. Are they all uniform? does any look bent or out of place? there should be 2 uniform rows no pins should be missing or out of place. If they are you have a connection problem. This is one of the issues with this memory format and its why they have changed the design to SD. This is common with people who remove the cards alot and use a reader over time the card and the slot becomes warn and its very easy to bend pins because the card isnt sliding in smooth. If this is your problem (a few bent pins) you may have to take it in for service or try and fix it yourself. Ive read about people using a mechanical pencil. Remove the lead and the pin slips right into the top and you can carefuly move it back. Hope this helps!
Sep 14, 2005 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot Pro1 Digital Camera Logo
228 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
