Question about Eiki EIP-200 SVGA DLP Projector Multimedia Projector
The lamp will stop all of a sudden. If we wait long enough, it will come up again. It was hard to get the lamp to start originally.
    Guru:
  • 1,049 Answers
You have a ventilation issue, probably a clogged filter or a faulty fan. The projector shuts down when it gets too hot or things it may damage the bulb by doing so.
Posted on May 07, 2010
My corolla 2000 suddenly stop , have to wait then start again like nothing happen,
There may be something floating around in the fuel tank that blocks the fuel sock. Stopping allows it to move gain so the engine will start again.
Jul 29, 2014 | 2000 Toyota Corolla
Van won,t start montanasv6 did a diagnostic on it the c305 came up
Could be fuel pump or fuel relay, sound like you're not getting enough gas.
Nov 24, 2013 | 2005 Pontiac Montana SV6
NEC vt800 projector troubleshooting
That is a problem with the lamp. Replace it with a known good one.
Feb 27, 2013 | NEC VT800 LCD Projector
516 Cdi sprinter sudden blue smoking for few minutes and after OK
somthing in the ignition is causing a weak spark--or fuel inject circuit is running to rich----------all causes improper burning---------get a computer diagnostic done
Apr 07, 2012 | Cars & Trucks
My NEC VT650 runs for about 15 mins then intensity of picture starts to reduce then comes back to full brilliance and does so for a few seconds and then the lamp switches off. Fan stays running. If I...
It could be the wrong lamp. Make sure that the lamp is original factory made. It may also be the lamp ballast which starts the lamp & keeps it burning steady.
Good luck,
Jim
Apr 15, 2011 | NEC VT650 OWIZ136606624901
My hard drive suddenly started beeping and stopped working
Your drive has failed. to try to get back some of your items put the drive in the freezer for a day. the chill will make the heads condense enough for about 3 hours of use for emergency backup.
Nov 07, 2009 | Hitachi 500GB External USB 2.0 Hard Drive
1999 Altima has a buzzing noise that starts when I
you have a short in the headlight wire trace it back and look for cracked or worn wire
Oct 06, 2009 | 1999 Nissan Altima
KDF-60XS955 Powers off and on every minute
The lamp light will not come on especially if it lights up during bootup from a cold start. The lamp only lights up on Sony when the lamp shatters in its housing and the system can't ignite the lamp from a cold startup, Sometimes it does'nt light up then. So if it lights when u first cut it on the sysem thinks its ok... But lets verify if the lamp is the problem.
With the tv off using your original remote, Press Display button-----channel 5 button----and Volume up button then Power button within 5 secs of pushing the first button, Screen should come on with a diagnostic screen, Look at the lamp driver option and see if its recorded any numbers to the right of it, if so then this is telling you that the lamp has stopped or tried to ignite that number of times..
Push the number 8 key then enter to reset the numbers back to zero.Turn off power now turn on the television and wait until it happens again, at this point go back to diagnostic as explained eariler and see what it has recorded. If it has recorded a 1 on the lamp driver then replace your lamp. Reminder: Once you have replaced the lamp go to diagnostic screen again and reset the numbers back to zero.
Hope this helps...Thank you
Delhielectronics@live.com
Sep 04, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
My garmin 340 suddenly stopped working
Ummmmm "Low battery"....... not too hard to figure out. You need to charge it for several hours. If the battery is low it WILL go out on you and during that time, the battery may recover enough to come on briefly then go off again. Please charge your battery!
- Jim
Sep 13, 2008 | GPS
Eiki EIP-200 SVGA DLP Projector Multimedia Projector Logo
73 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
Jaime Hernandez
color wheel light...
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
