Question about SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx
Hello, my hard drive starts up...runs for a bit, then turns off, whats the deal? it does it everytime now, whether it is hooked to the computer or not
    Brigadier General:
  • 10,406 Answers
It could be just "overheating", or it could be "near-death".
Make a good backup of it, while you still can.
Consider opening-up the case, removing the disk-drive, and buying and replacing the disk-drive.
Posted on May 07, 2010
Mine is doing the same thing and has been doing it since I bought it...
Posted on May 12, 2010
My external drive is broken, how do i open i up to fix it / recover my data?
Look for hidden screws under any labels or rubber feet. Otherwise it is likely friction fit together with tap and slot locks. Then you will need to pry it apart. Your best option is to open, remove the harddrive you find inside and install into a new external hard drive chassis. You can find good deals on ebay or Online Shopping for Cool Gadgets RC helicopter Quadcopter Mobile Phone...
Jul 09, 2016 | G-Technology G-DRIVE mobile with...
Computer doesn't recognize hard drive
Is the drive greater than 2TB and you are using a 32-bit operating system? If the drive is greater than 2TB, you need a 64-bit operating system to be able to access it as a single drive. Right click on My Computer. If it doesn't say, it is probably a 32-bit operating system.
Mar 31, 2014 | Seagate 3TB Expansion External Desktop USB...
Hello,Help,my Compaq Presario 6000 won't boot, turns -on starts it's POSTthen massage...WINDONS DID NOT START SUCCESSFULLY RECENT HARDWARE ,SOFTWARE CHANGE. no changes made. the screen goes black...
Hi Chas,
sounds like you have a piece of hardware that has a bad driver. If you connected something recently, try disconnecting it and then start your computer. If it starts, then you will need to find the correct driver for it before you attempt to hook it back up again.
If that does not solve the problem, try unhooking all hardware, except for the hard drive with the operating system on it. If it starts normally, then you can turn your PC off and hook up one piece of hardware... start the PC... turn it off again... hook up another... start the PC... etc. until you find the hardware that is causing the problem.
If it does not start with only the operating system hard drive attached... then, the hard drive may be defect. You can take it out and put it in a USB casing and hook it up per USB to another PC... if you see the data on it, it should be ok (just in case, this would be a good time to backup any data on it that you may need). If you do not see the hard drive in Windows explorer then it is probably defect and you will need to purchase a new one.
Hope that helps
Mar 14, 2013 | Compaq Presario 5000 PC Desktop
My External hard drive is not being recognized by the computer
Try hooking it up to another computer. What happens? This will narrow down whether the problem is with the drive or the computer ;)
Feb 20, 2011 | EDGE Tech Corp 160GB Diskgo Portable...
My book hard drive was hooked up to my new computer last thursday (64 bit Windows 7 professional) and worked great came to work today and computer will not recognize it no matter what I plug, unplug and...
This drive should work with Windows 7. Contact WD support and they can send you diagnostics to run.
You may try the drive in another computer, and try restarting the 7 system.
Feb 01, 2011 | Western Digital My Book Essential Edition...
My hard drive is "hanging up" and sometimes does not start. The computer will start, keyboard light momentarily lights but hard drive will not start. The only way I can seem to get it started...
There is a possibility your hard drive is failing.Go to the website of your hard drive manufacturer and download a diagnostic utility. Run the diagnostic utility to determine whether the hard drive is in good condition.
Nov 10, 2008 | HP Computers & Internet
Hard drive/memory/speed
music files and photo files take up a lot of memory/space on a hard drive. If you are using your flash dirve (external drive) to upload songs, phots etc to a website (i.e. Facebook;MySpace etc.) you can upload them directly from the external drive rather than loading them to your computer. I suggest, that if you have a cd/dvd burner, burn all music and photo files to dic, if your external drive is for temporary storage. Once you have done this, remove all music and photo files (except any you may want to use as start up theme music, background use for desktop etc.) then, degragment your hard drive, C:\. Once the degragmentation is complete, close all programs and reboot your computer. NOTE: while you can operate the computer while a defragmentatioin is in progress, any use slows this process, as degragmentations (or defrag's) can take some time to complete (i.e. 1 hour or more depending on the status of the computer and it's need for being defragmented) You can run an analasys to determine if it need to be defraged. This can be done under the Start Menu,All Programs, Accessories, System Tools,Disc Defragmenter: When Disc Defragmenter Opens, it will give you a list of the internal (hard drives,including the D:/ Partitioned Drive) Select C:\ and click on Analyze. This should only take a few minutes to complete. Once the Analysis is complete, it will tell you directly whether or not the computer (Drive C:\) needs to be defragged. In the event it does not, You can also run a Disc Cleanup: Go to Start Menu, All Programs, Accessories, System Tools, Disc Cleanup. Be careful doing this as you do not want to remove any programs that you use on a regular basis, or frequently, that the computer automatically may deem "seldom used". Here, you can remove, or uninstall programs and files that you or the computer do not need, and free up space. Freeing up memory or space will improve speed a little bit. Depending on the OS (operating system) and it's current grade (upgraded or not) - you may need to have more memory and RAM installed.
May 09, 2008 | Gateway 40G / 40GB for laptops /...
Winmail.exe message on my computer.
Winmail.exe can be a legitimate windoze component, but in this case it's probably a Virus. Scan your hard drives with your favorite updated Anti-Virus or install one (preferably up to date) and scan your hard drive/drives in safe mode (by pressing F8 on boot then once in safe mode scan them). That should tell you whether it is a virus or not. If not, you have repair options that can be explored. They will depend on the OS version you are running.
I hope this helps.
Jan 24, 2008 | Computers & Internet
SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx Logo
153 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
