Question about JVC RV-B90 Boombox
I have a JvC Rvb90 and it does not read the cds, well when i put an original cd it turns but doesnt play anything, when i put a cd i made it shows 00000 on the screen and it doesnt turn!
silly girl
  • 513 Answers
SOURCE: tray error
I saw on another JVC systems manual that its an error message that shows when the tray isn't fully open due to an obstruction. If you can locate a manual eject button(usualy you'll need to insert some tip into it) it will help you eject the tray and look for any obstructions, anything looking out of the ordinary there. at least that way you'll be able to take your cds out... You can also try disconnecting the system from all power sources for a few days(including an internal battery), maybe the reset will jog it back to working order. If you're out of warranty and know your way around those things, try taking it apart, cleaning as much as you can, and look for anything out of the ordinary, like broken gears or pins, bent parts, a cog, etc. Good luck
Posted on Feb 13, 2006
fairlane
  • 50 Answers
SOURCE: CD Player Does Not Read CDs
Hi As you describe the problem, there are three likely possiblities, either the laser lense is dirty, the laser is beginning to fail, or there is a dead spot developing in the spin motor. Cleaning is the first step, and the least expensive...If you have some electronics experience, they are not difficult to clean, but you must expose the laser to do it, and I don't want to advise someone to do that, and forget to unplug the unit. It's free laser eye surgery, but I doubt you would be happy with the results. I would advise you to call around to local repair shops, and see what they charge to check it out and/or clean it, and then descide if it is worth proceeding. Hopr this helps, good luck!
Posted on May 02, 2007
  • 883 Answers
SOURCE: CD WONT PLAY
guessing that your laser diode or drive motor or laser sled has stopped working...need more info...
Posted on Jun 01, 2007
SOURCE: CD,s will not play
Read the Manual on Page 2 or get it from:
http://de.jvc-service.net/public/document.cfm?prog=InstrBook.cfm&Model=KD-G321
Just make a reset with a pen or something else.
This should solve the problem.
Best regards
Dirk
Posted on Jan 25, 2008
SOURCE: Unable to play MP3 CDs on JVC KD-G140
I had this same problem and realized after reading the manual that this model does not play mp3's. They use the same manual for the g140 and the g240 (the model which plays mp3s).
Posted on Jul 09, 2008
KD-HDR40 will not play any CDs, only displays a "CD reading" message.
Sounds like CD mechanism failure. Did some sticker or anything went inside? Any way, need service.
Mar 03, 2012 | JVC Kd-hdr40 Car CD/ MP3 Player
Jvc ch-x350 12 disc cd changer. Loads cd but will not play it. reads: no disc and moves to the next cd and repeats. ??
If you are inserting non original cds, cds you make from your pc or cd copies sometimes they dont read, another reason is to make sure that you are inserting the disk with the correct side up, it will show you in the cd changer magazine slots. If none of this solves your problem then you have a defective cd mechanism and you need to replace or repair the changer. Very common problem with JVC Cd Changers, I used to replace them all the time and they tend to skip alot as well, get yourself a Pioneer if money is ok if not then follow my steps.
Good luck and dont forget to rate and vote for me if I helped you.
Thanks.
Jun 13, 2010 | JVC CH-X350 12-Disc CD Changer
It doesnt open and cant read the cds inside.
Remove the cover lid and look inside for anything jamming disk tray, problem may be very simple once you look at this. change out some of the cds.
Apr 09, 2010 | JVC XL-F254BK 5-Disc CD Changer
JVC Boomblaster RVB90 has problems to start after shut down.
If you have a cassette tape in the Kaboom take it out close the casstte door and lock it. See if the problem continues. The cassette circuitry has been known to cause alot of prolems like yours. I think it has to do with sensors.
Feb 26, 2010 | JVC RV-B90 Boombox
Car cd player won't read cds
I have a Dual xdvd8180 dvds multimedia reciever 7" digital touchscreen in my car and it worked fine for the longest time but now it wont read any of my cds.. burnt or original discs.. nor will it read dvds.. i tried cleaning it with a disk cleaning kit and it wouldn't even play that without skipping..idk whats wrong.. any help??
Jan 04, 2010 | JVC AM FM CD DET FACE CAR STEREO
Jvc kd-sx770 car stereo--radio works, but cd player doesn't
Hello beeswing70,
The player is recognizing that a CD has been inserted but is not able to read it.
Sometimes the lens assembly becomes contaminated and obscures the laser. I'd try using a commercial "lens cleaning CD" two or three times and then try a CD again. These lens cleaning CD's are widely available. If cleaning does not help, the player need professional service.
Hope this helps.
May 25, 2009 | JVC KD-SX770 CD Player
Doesn t reading the cd
hey,
also mention how old are ur CDJ and does it play original cds. Did you get any error code.
thx
djajay
Jan 23, 2009 | Pioneer CDJ-1000 CD Player
Car cd changer not working!
try pulling the fuse and resetting it, make shure its the +12v cont wire
Don
Dec 29, 2007 | JVC KD-S680 CD Player
CDs won't play
Maybe you should fix the cds or clean them or try to fix the disc reader in the radio.
Nov 09, 2007 | JVC MX-KB30 CD Shelf System
JVC RV-B90 Boombox Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
