Question about Refrigerators
Belling BI50 door hold of milk juice replacement
Need to find a replacement for the plastice door shelf that holds the milk /juice cartons on a
Model: Belling BI50 (sg)
Type : HZDI 2526
Made in Solvenia
  • 2 more comments
  • Anonymous May 22, 2008
    I am also looking for a replacement door shelf for a Belling BI50, HZDI 2526. Anyone know where I can get one ?
  • niamhod Aug 04, 2008
    i have the same requirement, the door hold of the milk juice compartment is missing.
  • dv8ed May 02, 2009
    I HAVE SAME PROBLEM ON BELLING BI50 HOLDER FOR MILK/JUICE ALSO I NEED 2XFREEZER COMPARTMENT DOORS FOR SAME MODEL
  • ronan Jul 30, 2013
    i am looking for the plastic holder inside the door that stores the milk and orange juice. where can i source this
3 Suggested Answers
SOURCE:
tech master
  • 120 Answers
SOURCE: Refrigerator
need model number cant help if we dont know what meodel it ios but if everything freezes repl the thermostat in refrigerator side
Posted on Oct 19, 2008
aasc
  • 1606 Answers
SOURCE: I get puddles of water
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Posted on Aug 16, 2010
How many cartons of apple juice needed to make 2 litres of apple juice?
That depends on the size of the cartons. If a carton is one litre, for example, then it you would need two cartons.
Oct 09, 2016 | Juicers
I need a new bottom door shelf, the milk just comes flying out when I open the door bit of plastic has gone from side of shelf making it weak
use a different shelf then . contact manufacturer and perhaps you can order one . we can not even tell you where to look as no MAKE or MODEL was included in the question .
Aug 09, 2015 | Refrigerators
Rear door on 06 jetta wont open
At a guess the outside handle has become detached from the linkage inside the door and you've got the child lock on as well.
Well to get the child lock off, you need a long fairly broad plastic strip, I've used the long side cut out of a plastic milk carton in the past.
Wind the window in the offending door down, then insert the plastic strip in the door gap underneath the handle, once in try the internal door handle, if it fails try again working your way down the door by widths of the plastic strip, trying the internal door handle as you go, with luck you'll have release the child lock by the 3-4th try.
Once open, its taking the inside door card off and re-attaching the linkage for the outside handle.
May 01, 2011 | Volkswagen Jetta Cars & Trucks
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
I get puddles of water under milk and juice cartons. Sometimes the whole top shelf is a puddle of water. It is a glass shelf.
Aug 16, 2010 | Refrigerators
Ice maker does not make much ice - what could be the problem. overnight only about a quarter of the tray is full - Ice compartment is never full no matter how long it is between using the ice. What can...
You can boost ice production by cleaning the fins below. The better air circulation around the compressor the better performance you get. The water filter may need replacing. The water valve may need replacing. I have the same ice box as you and have not noticed a problem with the shelves. You can adjust shelf heights you know.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 03, 2010 | Refrigerators
Belling 351 MK2AN Oven Door bracket back plate fallen inside!!
The only to do it, is to remove the side panel , and depending on the model number, you may have to remove the top also to gain access to the fixing screws.
Please rate my solution.
Thanks.
Nov 07, 2009 | Belling Ovens
GE Profile PSS25MGMB is too cold
After viewing the pictures of this part on this web-site - I took this part out of my refridge to see if the door was stuck closed or stuck open ( closed = fridge too warm and stuck open is too cold - my problem). The door within this part was broken off the hinge. I took this part apart - styrofoam and tape - and glued the door back together and in place with 2 part epoxy. I reassembled and everything seems OK now.
If this begins to happen again - I will probably just order a new part.
I think it is outrageous that a $700 fridge's performance is regulated by a cheap 50 cent piece of plastic. Spend another dime and make this piece glavanized aluminum? or other material that does not dry rot and holds up in cold dry environments.
Apr 08, 2009 | GE Refrigerators
I need a HE430TF door shelf.
Try screwing some long self-tapping screws in to hold the shelf on.
Mar 24, 2009 | Delfield Series 6000XL Remote Half Height...
Refrigerator
Aug 16, 2008 | Frigidaire FRS266ZDSB Side by Side...
Refrigerators Logo
502 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
