Question about Ryobi Cultivator
Need to replace primer bulb and fuel lines, is there a digram that shows the connections?
    Sniper:
  • 53 Answers
Posted on May 10, 2010
Testimonial: "This was super helpful. I was replacing the primer bulb and when I removed the casing covering the carburetor I found all of the fuel lines had rotted and crumbled. I just needed to make sure I got the connections to the carburetor right. This done the trick. Thanks!"
Digram of fuel lines for craftsman chainsaw model 358.350180
There are two lines inside the tank. The short line with no fuel filter on the end of it goes to the inlet, (suction) side of the primer bulb. The long line inside the tank, with the filter on the end goes directly to the fitting on the side of the carburetor. The line, inside the air box from the outlet side of the primer goes to the remaining fuel line fitting on the carburetor. (This is not my post)
Mar 09, 2012 | Craftsman Garden
Need to replace fuel lines....does the prime bulb connected to return fuel line or the supply fuel line
Hi stglass900...
Normally the big line will be the line the fuel filter is connected to inside of the tank, and is connected to the primer bulb.
The smaller of the two lines is the return line to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Please take time to rate me
Aug 16, 2011 | Craftsman 25cc Gas Line Trimmer
Ryobi cultivator #RY60511A : Need diagram or text to show the fuel lines from the tank to the primer and the carburetor.
here is a manual,Tim:
http://lawnandgarden.manualsonline.com/mdownloads/38dcb043-331f-461b-a08c-072d67fc76c0.pdf
here is a diagram:
http://photos.hobbytalk.com/showphoto.php/photo/34693
in a nutshell:
1 connect top carburetor line to short nipple on primer bulb.
2 bottom carburetor line to fuel line with filter (inside tank).
3 connect remaining fuel line that comes out of fuel tank to the large nipple on primer bulb.
Hopes this helped Tim
May 29, 2011 | Garden
Need diagram for fuel line in tank fuel filter
The small diameter fuel line that has the fuel filter in the tank on it goes directly to the carburetor (with the built-in primer or externally mounted primer). IF the carb has the external primer, the small line goes to the nipple on the carburetor opposite the end with the hole in the cover. If it has the built-in primer on it, it goes to the carb body on the nipple furthest from the bulb. The large diameter line is the fuel return line and if the carb has the bulb on it, this line connects on the nipple closest to primer bulb.. With the externally mounted primer, this line connects on the longest nipple coming out of the primer and goes to the fuel tank (not the filter though). There is a nylon connector inside the tank that holds this larger line in place. The shorter nipple on primer bulb has a smaller diameter fuel line connected to it and connects to the nipple on the carb closest to the end with the hole in the cover. Built in primer has 2 fuel lines...externally mounted has 3.
Jul 31, 2010 | Craftsman 25cc Gas Line Trimmer
I am replacing a primer bulb in a chainsaw and the lines are gone so i need to find out which line goes where
Leave both primer ports open, then attach the fuel line that feeds the carburetor from the fuel filter to one of the primer ports--pump the primer and if you guessed correctly, it should pump fuel into the primer bulb. That is the primer port that goes to the carburetor output connection. The other primer port connects to a short line that goes back into the fuel tank with no filter. Return the original feed line back to the upper carburetor port. Connect the open primer port to a short line that connects to the carburetor lower port. Be sure to use original rubber lines, not plastic. Hope this helps!
Jun 22, 2010 | Garden
Not getting fuel replaced primer and hoses and not
It's easy to mess this up as I've done it in the past. If the unit has an external purge bulb, the fuel line from the fuel tank that has the fuel filter on it goes directly to the carburetor...near the part of the carb that holds the fuel pump and has the grooved cover (where an inbuilt purge bulb would be). The other line coming out of the fuel tank goes to the purge bulb. The side of the carburetor that has the diaphragm and metering lever cover has the line going to the purge bulb. Remember, this is not really a primer...the purge bulb pulls air and old fuel out of the carb and when it does this, fresh fuel flows into it...and then the bulb pushes that air and old fuel back into the fuel tank. Hope this helps.
Jun 13, 2010 | Craftsman 25cc Gas Line Trimmer
Fuel line digram
Fuel systen components part numbers and a little detial can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
A helpful video, a few of my suggestions and a typical fuel system follow:
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
HTH Lou
Nov 18, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a poulan 2150 chainsaw. I replaced the
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb refills).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Oct 25, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I had to replace the primer bulb and fuel tubing. The primer bulb just disappeared, presumably blew off. I have installed the new bulb and replaced the fuel tubing, but I need to know where the tubes...
The line with the fuel filter in the end comes out of the tank and it goes to the bottom fitting on the carburator. The other line comes out of the tank and goes to the bottom fitting on the primer bulb, and the third section goes from the top fitting on primer bulb to top fitting on carburator. Got it? lol Hope this helped and best wishes.
Aug 25, 2009 | Garden
Need digram to install fuel lines
First, you sould have one with a filter in the tank going to carb. Next run one from tank to primer bulb and from one from primer bulb to carb.
May 18, 2009 | Garden
Ryobi Cultivator Logo
1,040 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
