Question about Garmin nuvi 260W GPS Receiver
Unit will not load. it starts to then shuts off. does this over and over
    President:
  • 1,851 Answers
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
Posted on May 08, 2010
When my unit won't start and has a code 20
If that refrig trailer is loaded then you need to call thermo king for help ASAP. You don't want to loose the load.
Retired VP OPerations Trucking. Mike
Feb 12, 2016 | Cars & Trucks
Load disc, unit tries to load & play, unit shuts off. Turn power on to set time,etc,machine shuts off.
Laser pickup unit fault. The unit alongwith its flat connecting cable should be replaced. Contact any service technician. Electro help
Feb 23, 2015 | Samsung DVD-V2500 DVD Player
Not used for 2 years. It will not start.
Engine will
not start
1. Low on fuel or oil. 1. Add fuel or oil.
2. Ignition switch in "Off"position. 2. Turn to "ON" position
3. Faulty spark plug. 3. Replace spark plug.
4. Choke in wrong position. 4. Adjust choke accordingly.
5. Fuel shut-off valve in closed position 5. Open fuel shut-off valve.
6. Unit loaded during start-up. 6. Remove load from unit.
7. Spark plug wire loose. 7. Attach wire to spark plug.
Apr 23, 2011 | Porter Cable 5,500 Watt Portable Generator...
Compressor UP6 25 125, runs all the time but is only under load for a short time, should it shut down between loads?
This unit will shut down if unloaded for a set period of time. Usually 5 to 10 minutes. This time could be longer if some one has changed it from the factory setting. There is a timer in the control box that starts counting down when the unit unloads. If it stays unloaded long enough for the timer to count down the unit will stop until the air pressure drops to the low set point on the pressure switch. It will then start up. If the unit loads before the counter counts down the timer starts from the beginning when it unloads again. This cycle continues until you manually shut it down or you stop using air long enough for the timer to reach Zero and shut down.
Apr 22, 2011 | Ingersoll Rand UP6-25-125 120 Gallon...
Started a new wash, started to fill with water then shut down. Now it sometimes turns on but shuts down after about 30 seconnds.
it sounds like there may be a problem with either the control board or the drain pump itself... is it giving you any fault codes at all... you may want to check drain pump on this unit which is located on the front side and requires removing lower panel of unit...check for any obstructions as if unit cannot drain or pump will shut down control assembly... if that looks good then the control board may be faulty unplug unit for a couple of minutes and plug back in sometimes this will reset controller.... repost if anymore questions one of us will be glad to help you out....
Jan 08, 2011 | LG WM-0532HW Front Load Washer
WHEN U TURN ON THE TRUCK THE IN-DASH TURNS ON AND LOADS UP AND AFTER A COUPLE SECONDS IT SHUTS OFF.... BUT YOU CAN STILL HEAR IT THAT ITS ON.ITS THE PIONEER IN-DASH NAVIGATION AVIC-F90BT.
F900BT?
IF yes then this is normal because the unit is slow to shut off when you turn the key to the start position since there is a surge in amps. from your alternator and starter working at the same time the power surge causes the unit to shut off/ reset its self. this is just to protect the unit it is just to protect the unit.
Mar 02, 2010 | Pioneer AVIC-F900BT Car GPS Receiver
My front load wash machine is full of water. i try to drain and spin. it just shuts back off.
First thing i would recommend, is lower pipe and drain water out of unit.Get to the point where you can eventually remove drain pump from unit as im sure it is blocked. (Microprocessor is confused by the still full signal and is instructed to shut down) Once completed, if you have a reset fascility on your unit, reset it. If not retest by starting wash cycle from the beginning.Please let me know if not the answere. .
Sep 23, 2009 | GE WSXH208A Front Load Washer
DVD Player stopped working... will not LOAD/PLAY dvds
DVDs will not load / play... problem just started... TV approx 14 months old. Recently DVD was working and the TV just "SHUTOFF"?
Mar 03, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Screen goes blank
Maybe the setting of your video display was change to higher setting, and your screen cannot handle the said setting.
When a "safe mode" message appears during opeing, select that options, then at the desktop right click your mouse, chose properties, then setting, then change the screen resolution to lower range.
Dec 05, 2007 | GPS
Garmin nuvi 260W GPS Receiver Logo
233 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
