Question about Geha Primo 2700 (Cross-Cut) Shredder
The fiber gear driven by thde motor is stripped.
The fiber gear driven by the motor is stripped. Motor works fine but does nothing, as expected with this problem. Where can I get a replacement gear?
    Guru:
  • 1,049 Answers
Nearly impossible to find at a price that will make it worth it unless your planning to buy them in bulk from a distributor and do this type of repair often.
Posted on May 07, 2010
My whirlpool 6th sense azb7570 has stopped turning?
If it is belt driven, the belt has come off, stretched out, or has broken. If it motor/gear driven, the gears are stripped or the motor has died..
Aug 04, 2016 | Whirlpool Dryers
My microwave is rotating clockwise and is making a loud clicking sound. It was working ok until last week.
most modern units the table is driven by a gear unit with a motor, likely you have some problem with the gear drive---stripped gears etc.
Not in many models easy to get at or even get the parts.
Dec 20, 2012 | Microwave Ovens
Windows wont roll up or down
window regulator. no clue without looking at it if you have a cable driven one or a gear driven one though.
if cable driven, sounds like the cable has snapped. if gear driven (most likely) then the plastic gears inside the window motor on the regulator have finally worn and stripped out.
Jun 17, 2011 | 2002 Ford F350 Super Duty DRW Reg. Cab
Blades do not rotate, motor runs
Something is stripped. Most shredders are gear driven from the motor to the driver shaft and onto the driven shaft. Check that the motor has not come loose from its mountings, the drive gear has not come off the motor or the gear has stripped. You will have to split the shredder housings to do this.
Feb 22, 2011 | Fellowes Office Equipment & Supplies
1991 HARLEY DAVIDSON SOFT TAIL NO SPARK FROM IGNITION VALVES NOT OPENING OR CLOSING MOTOR DOES TURN OVER
Using all caps makes it sound like you"re shouting...
It sounds like you have either lost your camshaft drive (broken timing chain, or belt, or broken gear(s)), or your camshaft has broken right where the driven end is. In any event, your cam is not turning.
I worked on a Ford van once with gear to gear drive for the cam, but the cam gear was a fiber/resin gear (for quiet running). There was a crank-shaft-gear shaped scoop carved out of the cam gear. Had I not seen that, I would have thought gear-to-gear drives can never fail. Apparently not.
Jun 15, 2010 | 2004 Harley Davidson FXSTS - FXSTSI...
Motor works but the rear window wont go down
This is a cable driven system and the cable may have a worn opening that is causing it to slip. The other posibility is that the drive motor gear itself has stripped. Thank you, Dana
Mar 30, 2010 | 1997 Lincoln Town Car
Officemax OM96580 has a stripped gear tooth on the nylon gear that meshed to the motor pinion gear
If you expect to repair this, expect to spend weeks waiting for parts if you can get them at all, at least an hour to do the work and expect to spend 2/3 the price of a new one for the parts.
My advice, my friend, save the collection can, discard the shredder. On your new shredder, dont over feed it.
Thanks
Oct 14, 2009 | OfficeMax 0M96431 Shredder
I have a kenmore beltless upright the beater brush dosetn spin
If it is direct drive then the motor or the wireing to the motor are bad. If it is gear driven then the gears are probally stripped.
Apr 11, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
Globe Meat Slicer Model # 500 motor runs blade not turning
Fiber gear on blade hub stripped. deep socket required to remove hub. DON'T CUT YOURSELF!! remove motor, used food safe solvent to clean grease out of housing. Fiber gear held on with snap ring. Replace gear, repack housing, put hub and motor back and start slicing. Routinely check to make sure gear is lubed.
Oct 30, 2008 | Berkel 827E Gravity Feed Deli Meat Slicer
Geha Primo 2700 (Cross-Cut) Shredder Logo
154 people viewed this question
Top Geha Primo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Geha Primo Office Equipment and Supply Expert? Answer questions, earn points and help others
