Question about HP DeskJet 1280 InkJet Printer
My hp deskjet 1280 printer is not coming on
Morning, i was using my hp deskjet 1280 printer last night and a paper got jammed, i succeded in removing the paper with care but when i tried to put the printer back on, it refused to come on, what happens is that when you switch on the sorce of power and switch it back on and press the printer on botton, the indicator for on comes on but immediately goes off again, however the ink indicator shows light when i press it or hold down the button, what can i do to solve this, urgent
  • 2 more comments
  • spela Apr 10, 2008
    Hy!
    I have the same problem with my printer. But the bigest problem is that even after reinstaling the s/w it does not respond. The lights(the buttons)respond in the same non working way as they did before i reinstaled the s/w.
    It is as if the printer was completely dead.
    Powerless
    What to do?
  • Anonymous Apr 23, 2008
    none
    none
  • Alex Kibadac Jun 02, 2008
    Know our office printer has the same problem.
    And we ejct the paper after we turn off the printer
    What must we do?
Maybe the back door (for removing paper jams) is not closed.
Rotating door knob needs to be pushed to the end - even if it seems to be hard, there is some more space to the end. Printer won't work if the back door is open.
Posted on Jun 11, 2008
Its rear panel sensors problem of the printer remove it and then closed
after that the problem is not solved
dont turn of the main switch push rear panel up when it closed push printers on off button
Posted on May 29, 2008
The printer donot switch on
Posted on Mar 31, 2008
    Genius:
  • 3,587 Answers
Well..sometimes when a paper jam occurs, it shuts the whole system down..
you may wish to remove the s/w for that printer through control panel
go here for updates drivers
re install the s/w
run test page, calibrate and clean cycles.
Posted on Mar 27, 2008
Our printer HP 1280 we can print 1 page only then trouble will occur paper jam even theres no paper clog inside the roller..
clean your printer from inside carefully and use orginal HP inks then you will not face any problem
Feb 19, 2012 | HP Deskjet 1280
Paper jam hp deskjet 1280
Hi syarief03120,
Actually you can manually remove the paper from the printer. It can be pulled out from the feed area.
And to clear the paper jam message: You have to take the back cover off, there is a reset switch in the top left hand lock hole. Use an object to push in the pin hole. After that put back the cover on. This should help you fix the problem.
Hope it helps.
Thank you for using Fixya.
Apr 15, 2011 | HP DeskJet 1280 InkJet Printer
Carriage jam problem/1280 printer
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
Sep 06, 2010 | HP DeskJet 1280 InkJet Printer
Hp 1280 stops printing after paper jam
one of the gears are dislocated. open the printer carefully and check for loose gears, or you take it to a technician.
Nov 20, 2009 | HP DeskJet 1280 InkJet Printer
HP deskjet 1280 paper jam
Yes you can manually remove the paper. It can be pulled out from the feed area (pulled out backwards).
To clear the jam status....
Take the back cover off, there is a reset switch in the top left hand lock hole. Push a pen (or similar) into this hole, the switch will give slightly and be the same depth as the others.
put the cover back on, all should be well
Sep 11, 2009 | HP DeskJet 1280 InkJet Printer
HP DESKJET 1280
I had this problem too and found that the rear cover (the one that you remove to clear a paper jam) was not correctly fitted and locked. After resetting the vover and fully locking it worked! Try it.
Aug 23, 2008 | HP DeskJet 1280 InkJet Printer
HP Deskjet 3940 (Paper Jam)
I have a HP Deskjet 3940 printer. And similarly to this problem here I had a paper jam that would not clear, despite removing all the paper that was stuck in it, and following all 4 steps stated on the HP website. Such as taking the back cover off and blowing dust away and turning it off and on, etc.
None of these steps worked for me and consequently I couldnt get any new jobs to print - kept saying 'paper jam'. I was about to head down the shop to buy a new printer when i tried one last thing, which HAS fixed the problem!
I put in a large stack of paper onto the feeder. and then pushed it forcefully in and out repeatedly. To my amazement this has solved the paper jam. As a very last resort, might be worth trying this?
Jul 25, 2008 | HP DeskJet 3940 InkJet Photo Printer
HP 1280 PRINTER TROUBLE SHOOT
are u sure that power supply is burnt n gone ,because i just want to share that if the back side door is not fixed properly ,the printer will not power on,so pls try if u have not
do revert
thnx
Jan 28, 2008 | HP DeskJet 1280 InkJet Printer
Power problem
I'ts because there are a paper jam
I have the same problem and I solved it myself
-.... look into the lock behind the printer remove it then put it back again >>>>>>>>
Dec 17, 2007 | HP DeskJet 1280 InkJet Printer
Paper jam
Carefully pull it out. Try not to rip the paper, because you may get some stuck inside. It may be necessary to open the printer up and even remove part of the cover to get it all out.
Feb 13, 2007 | HP DeskJet 1280 InkJet Printer
HP DeskJet 1280 InkJet Printer Logo
183 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
