Question about Samsung X640 Pink Color Cellular Mobile Phone
Samsung phone my buttons on my phone wont work if i press menu or ok it wont do anythink so i cant get in to my messages or anythink else this has happened befour nd it got repared but ive had it over a year now please help
  • Anonymous May 22, 2008
    i need the driver samsung SGH-C170
I have the same problem as a many people with this phone. After the incorect code, my phone is frozen, and ask me to enter some password which I don`t know. I tried 00000000, 12345678 and 987654321, but that isn`t working. so please if somebodey know how can I solve this problem. Thanks to all
Goce,
my e-mail is: g_goce@yahoo.com
Posted on May 11, 2008
I have a motorola back flip and my daughter was playing with my phone and got a passcode on it now it wont let me in my phone i need a reset password
If a password is forgotten, perform a master reset to restore the device to original factory specifications.
http://www.wireless.att.com/answer-center/solutionDisplay.jsp?solutionId=KB114093
Hard Reset
You undertake using this procedure at your own risk.
You are responsible for any data loss or any expenses incurred by using this procedure.
You may suffer the loss of the use of your phone and the ability to use it for emergencies.
Perform these steps at your own risk.
1. Power off phone.
2. Hold camera button and power on phone at the same time.
3. Release the camera button when prompted to.
4. You will see a message screen telling you to press the up or down volume button
5. Press the down volume key (ignore message 'Volume Up Key Pressed') - This is fixed after updating to 2.1 and the proper message shows
6. When triangle and phone screen appears
7. Press on the screen just above the back key
8. You will now see the "Motorola system recovery" menu
At this point you will have three choices:
1. reboot system now [Menu+Back] 2. apply ssdcard:update.zip [Alt+S] 3. wipedata/factory reset [Alt+W]
You can simply tap an item to select it.
At the bottom of the screen you can select OK to apply your choice from the menu.
There is also an opportunity to select Hide on the bottom left, I don't know what that does (I tried it and nothing happened).
Selecting Wipe data/factory reset and tapping Ok and the screen changes to a box and a phone (Get it - out of the box) and you see what is happening on the phone.
pick 2 -- Wiping data...
Formatting DATA:...
Formatting CACHE:...
Data Wipe Complete.
Press Menu+Back to reboot
pressing Menu+Back did nothing for me so I tapped 'reboot system now' on the menu and Ok.
The phone restarted and took me through the setup prompts.
May 06, 2011 | Motorola Mobility Backflip Smartphone
I need to master reset may Motorola Blur
To Hard Reset the Motorola BLUR MB300 quite differs from other Motorola ANDROID phones.
Do back up all your data stored on your device before doing this procedure, this process will delete all the data on the phone but does not delete the data stored on the microSD memory card.
To hard reset Motorola BLUR MB300
1. Power off phone.
5. Press and HOLD the down volume key (ignore message 'Volume Up Key Pressed')
2. apply ssdcrad:update.zip [Alt+S]
pick 2
-- Wiping data...
Formatting DATA:...
Data Wipe Complete.
The phone restart then will restore back to its factory default state.
Mar 20, 2011 | Motorola Cell Phones
Cant remember my code for Master Reset and Clear what must I do
Pleas e do the following step
Code to lock keys. Press together *7
Note: [] (pause) means the * key held in until box appears.
Select phone line - (use this to write things below the provider name):
[] [] [] 0 0 8 [] 1 []
Add phonebook to main menu:
[] [] [] 1 0 5 [] 1 []
Add messages to main menu:
[] [] [] 1 0 7 [] 1 []
Copy SIM memory (phonebook menu):
[] [] [] 1 0 8 [] 1 []
Eng Field options (main menu):
[] [] [] 1 1 3 [] 1 []
Slow (Frequency of search menu):
[] [] [] 1 0 1 [] 1 []
Medium (Frequency of search menu):
[] [] [] 1 0 2 [] 1 []
Fast (Frequency of search menu):
[] [] [] 1 0 3 [] 1 []
Enable EFR:
[] [] [] 1 1 9 [] 1 []
Function :
[] [] [] # # # [] 1 []
Change pin:
[] [] [] 0 0 4 [] 1 []
Unblocking using the "puk" number:
[] [] [] 0 0 5 [] 1 []
You can change GSM frequencies to 900/1800 by entering the enginnering model.
Following the below steps:
enter menu and press 048263* quickly,
then you will enter the secret engineering menu under "Opcode"
input 10*0*3 for GSM 900
10*0*4 for GSM 1800
10*0*5 for GSM 1900
10*0*6 for dual band GSM 900/1800
10*0*7 for dual band GSM 850/1900
To add extra message space 4 your Motorola C350 C450 C550 or C650,
press menu button, press 048263* quickly, then on the popup menu enter 47 press ok.
press 50 and ok.press 1 ok.press 64 ok.press 1 ok.press 186 and ok.
You will receive an extra 50 msgs memory space.Switch phone off and back on.
Hope this helps.
Thanks for using fixya .
Jan 26, 2011 | Motorola Mobility V360 Cellular Phone
How to reset the lg rumor
If you have forgot the codes for your mobile you can unlock it by using the last four digits of your phone number or four zeros. If these codes are not working you can contact your network service provider to get the unlock codes.
If you need to reset your mobile then press the "Menu" button,from main menu scroll to "Settings/Tools" and select the option by pressing the center "Menu/OK" button.Scroll to "Settings" and select.Scroll and select "More". Scroll to "Security" and press your "Menu/OK" button.Enter in your phone's security code when prompted. Select "Reset/Erase", then "Reset". A warning message will appear. Press the "Menu/OK" button, then highlight and select "Yes" to confirm the reset.
Thank you !!D
Oct 30, 2010 | LG RUMOR Cellular Phone
I need to reset a LG rumor touch to factory settings. Forgot lock code. Is not last four of phone # or 0000. Is there a programming code to re set it?
Thank you !!
Jun 10, 2010 | LG RUMOR Cellular Phone
Cant get the phone off pulse when dialing model#EM6113-BK
Tone/Pulse
You can switch the dial mode. In most situations the TONE option should be selected.
Press the "Menu OK" button. Select BASE using "
May 30, 2010 | Emerson EMSEM2646WH Phone
Env3 internal screen broken
dude this JUST happened to me. im so mad.
Dec 24, 2009 | LG enV3 VX9200 Cell Phone
Cant delete text messages, etc
that happens to me all the time. what i do is i take the battery out & restart it & it works just fine (:
Mar 18, 2008 | LG enV VX9900 Cellular Phone
Infuriating Inbox Motorola V620
i cannot undeerstand ur problam ok sorrry!!!!!!!!!!!!!!!!!!!
Feb 22, 2008 | Motorola Mobility V620 Cellular Phone
Samsung X640 Pink Color Cellular Mobile Phone Logo
67 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
