The charger will not work at all now but when it did the laptop would not start up
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 135 Answers
Try to use a good known ac adapter first because it could be the ac adapter port that is causing the problem
Posted on May 08, 2010
Start up on the Acer Aspire One 722
Power the charger, plug it in and press power on the laptop.
Nov 21, 2015 | Acer Computers & Internet
Cannot open my netbook samsung after pressing the hibernate button ,theres no power at all even pressing the start button..
Try following things with the below order:
1. connect the charger to the laptop, wait 2 minutes and then press the start button.(for 2 sec)
If above does not work:
2. Remove the battery of the laptop and connect the charger. Then press the start button (for 2 sec)
3. Check the output of the charger with a voltometer and see if the voltage is the one that it's written on the charger.
If the charger's output is OK then:
3. your Laptop's motherboard is possibly damaged. You have to call Samsung.
If the charger does not have any voltage:
- change the cable of the charger (that is the most often "damage" that chargers have)
Aug 03, 2011 | Samsung N150 (36725723009) Netbook
My laptop charger to acer 5930 stopped working in the middle of the night. The green light on the power supply lights up clearly when I insert it into the outlet. But as soon as i plug in the charger to my...
Remove the battery and try again.
If the laptop works ok with the charger connected (with battery taken out), then the battery needs to be replaced.
Refer to user guide on how to remove the battery.
Jun 24, 2011 | Acer Aspire 5930 Laptop Charger...
My laptop charging port is not working properly. My Charger is running properly but the charging port of the laptop is not working.It is not getting charged.Now the laptop is totally off and now i cant...
There are three possible parts of the computer which cause the problem.
1. ac adapter or charger
2. battery
3. motherboard
The charger is working fine which leaves the battery and the motherboard to be the possible reasons for that certain problem. What you need to do is to check which one is really the part that's causing the problem.
Here's what you need to do:
1. Remove the battery from the laptop.
2. Turn the computer by using the charger alone. If it turns on then, the battery needs to be replaced. If it doesn't then it's a motherboard problem which is a very complicated situation. You need to see a computer technician for a motherboard problem.
Apr 19, 2011 | Compaq Presario CQ40 Series Laptop Charger...
Laptop only turns on every now and then, charger pluged in but charger light not on, when trying to turn on fan kicks in, charger light flashes, then nothing, please help?
It sounds like you have a bad charger cord. Does it do the same when powered off the battery? Like it is tryin to start up. An d also make sure battery is plugged in good to the laptop,
Oct 31, 2010 | HP Compaq nx5000 Notebook
Hi i have a ph pavilion dv6 laptop and my charger has stopped working it has done this many timews befor but it started working but this time its not. Its not our electrisaty. Can you help me please
Hi
The problem you are experiencing with your charger might be from the charging port of your laptop.What you need to do is to look inside the mouth of the charger and check if the pin inside is broken,or the charger might have burnt due to high current.All you need to do then is to try and get the type of your laptop charger and test it with your laptop then if it works,your charger might need to be replaced.
BEST OF LUCK
Jul 02, 2010 | HP Pavilion dv6000z Notebook
Charger would not work computer started smoking
The Charger isnt the right volts for that laptop i recommend getting another charger,, the power cable maybe blew from too much use..
Jun 04, 2010 | Dell Studio 17 Laptop
Targus COMPACT laptop charger isn't working
Your battery sounds like its buggered. I would suggest buying a new battery
May 20, 2010 | Lenovo 3000 G530 Notebook
Charger was plugged in and working fine, went into
OK unplug power supply from back of laptop, remove battery, insert power supply, if NO light, on laptop, power supply is broken..Replace. IF it is OK, hold power button ON for a while, or until, the PC starts, if/when it starts, shutdown, with power ON key, and then take out power supply, replace battery, replace power supply, turn laptop on, now should be OK.
Mar 01, 2010 | Toshiba Satellite A70-S249 Notebook
Laptop stopped working and now not starting up. I think the battrey is dead and charger not working. it is HP laptop
If the charger has a light on it when it's plugged in and it's not on when you plug it in, then yes your charger is bad. if the light is green then you have issues with the laptop. If no light, check the voltage with a volt meter to see if the charger has power. good luck.
Sep 05, 2009 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
