Question about HP M2727NF Laserjet Printer
My HP M2727nf scanner pulls more than one page through at a time causing paper jams and interrupting the scan function. How do I diagnose the cause?
  • 223 Answers
Hi this is a typical symptom of the firmware being out of date. Go to the hp website and download the latest firmware upgrade utility. If the firmware is updated and the problem continues it could be a problem with either the dc controller of the formatter board.
Al
Posted on Aug 31, 2010
HP Laserjet M2727nf 's scanner
If the problem is ALWAYS, can be caused by an error in the configuration of the white paper size. That is, the printer has a conflict of comparing the original document size and the size of the white paper.
If the paper has left marks from objects obstructing the paper path. This alone can resolve the paper feeding disarm until you check that the sensors are free of obstructions.
You can also clean and well make sure they are free of any problems and ensure that the paper path goes smoothly.
Try also check the good condition of the rubber paper feed, paper separation and drag.
Feb 08, 2012 | HP Laserjet M2727nf Multifunction Printer
Scanner error 5
Scanner error 5 is caused by a bad formatter that in turn destroys the scan axis motor in the scanner itself. The formatter is covered under a warranty extension by HP but last time I checked they were no longer covering the scanner motor. Contact HP at 1-800-invent
Oct 13, 2011 | HP Laserjet M2727nf Multifunction Printer
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
I cannot scan a few pages and save them all in one file. so i have to scan every page and save it as a page. Printer HP LaserJet M2727nf
If you use the HP Solution Center and tell it to scan a document, after each page you need to place the next page on the scanner and then click on "Add Page". Also set the document type as PDF.
Dec 23, 2010 | HP Laserjet M2727nf Multifunction Printer
The scanner keeps jamming. i try to scan form the document feeder &the papers keep getting stuck. It will not complete a scan!what do i do?
In summary: * Very unintuitive, convoluted and unpleasant to use (same on Win2K as XP) - sometimes the SW hangs during scan and needs a reboot - sometimes the SW crashes with a dialogue "try reinstalling HP software", and needs a reboot - sometimes it scans and after conversion to pdf
Advantages: I cannot see any advantages with this product
Disadvantages: Software is convoluted and unreliable, paper jams are difficult to clear
function showHideReviewText( sType ) { if ( sType == 'more' ) { document.getElementById( 'review_text_full' ).style.display = 'block'; document.getElementById( 'review_text_short' ).style.display = 'none'; document.getElementById( 'review_title_link' ).onclick = function() { showHideReviewText('less'); }; } else { document.getElementById( 'review_text_full' ).style.display = 'none'; document.getElementById( 'review_text_short' ).style.display = 'block'; document.getElementById( 'review_title_link' ).onclick = function() { showHideReviewText('more'); }; } } ...with a dialogue "try reinstalling HP software", and needs a reboot
- sometimes it scans and after conversion to pdf every page is blank
- very occasionally it scans a document properly
*If the sheet-feeder jams is says to refer to the documentation to clear it, which doesn't exist. There is no way to clear the jam except to pull hard & hope. No levers to release it like one would expect.
*Frequently has error ...
...cycled to work again.
Everything has to be started by pressing a button on an application called "HP Director". There are 4 apps started from this:
1) Scan Picture
2) Scan Document
3) Make Copies
4) View & Print
also Help
also Settings (which are used in conjunction with settings found in (1) and (2)!)
- Each application has to be exited to return to "HP Director"
its a worst scanner
and prone to jamming problem
Jun 09, 2010 | HP Scanjet 5590 Flatbed Scanner
HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Jan 27, 2010 | HP LaserJet P3005n Printer
Hi, My HP m2727 AIO is not working properly. Specifically, there seems to be a problem with the scanner function. Each time I key in "Scan" I receive a "cannot detect" message.
Hi Cheryl,
If you are scanning from your pc and seeing this error message it could mean that your scan drivers are disassociated. If you have multiple multi function printers or scanners that could be causing the problem as it creates a conflict with the software framework. I would recommend uninstalling the software as well as any other multifunction and reinstalling the software as well as the additional product software.
If you are scanning from the printer it may not be set up and you would have to set up scan destinations.
Al
Eliteprintersolutions@gmail.com
Aug 06, 2009 | HP Laserjet M2727nf Multifunction Printer
Paper jam
I had the same problem. What I did : I placed a thicker paper in the tray and when the scanner starts pulling the sheet, push the paper a bit forward so it will remove any debris that may causing the problem. It worked for me. Try a few times. Hope it helps you.
Feb 09, 2009 | HP Scanjet 5590 Flatbed Scanner
Paper jam
It seems youre facing an issue with the scanner consumables - pad and pick roller. It is a goos idea to replace both of them at the same time. Also check the feed and exit rollers (the two rollers on the upper part of the scanner) as the get sticky causing problems like the one you describe.
Sep 27, 2017 | Fujitsu ScanPartner fi-5120C Pass-Through...
HP M2727NF Laserjet Printer Logo
147 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
