Question about Hobart A200 Stand Mixer
I need a repair manual and parts manual
The motor runs but the arm doesn't spin. This happened when the gears were changed while in operation. I opened the top to the gears and it looks like one of the brass gears fell apart as there is gold filings in the grease and bits of gold metal.
Am I over my head on this as the repair guy is $130/hr.
Ted
    Scholar:
  • 44 Answers
Once you're familiar with it, the A200 is OK to work on. Just pay close attention to the sequence in which the gears are removed and lay them out on a table in that sequence. You'd need to remove most of the gears from the center planetary shaft, which requires removal of the shift lever (right side, 4 screws). You shouldn't need to remove the planetary (lower end that holds the attachments and rotates). Eventually you'll be able to remove the smaller shafts as assemblies and replace the brass worm gear.
You'll want to scoop out the grease with brass shavings in it (replace all the grease to be thorough, especially if it has broken down and is very runny or very thick (the grease should be a little bit thinner than the consistency of peanut butter), spin the removed bearings by hand and listen for rough operation (particularly the smaller bearings on the upper end of the two small shafts (bearings in the upper bearing cover). Also check to see that the two brass bushings, which reside in two of the gears removed from the center planetary shaft, spin freely BOTH on the planetary shaft AND in the gear they reside in (if not, one of your speeds probably won't work).
For an experienced technician, the job would take approximately 1-1.5 hours unless the old grease is all cleaned out thoroughly to replace with all new grease (thorough cleaning requires the removal of planetary and planetary shaft), and thorough cleaning can be a time consuming process. Then you might get closer to 2.5 hours.
Posted on May 20, 2010
60 qt Hobart mixer H600T makes buzzing noise and won't spin. The hook seems blocked, can't spin it manually. Opened the top part and everything seems fine. What can it be and how to fix it? Thank you
call in an electrician as it may be the start/run capacitor for the motor ( indicated by motor humming but not running)
the gearing will make it very difficult to turn the blades by hand as the motor will be spinning at either 1400 rpms or 2400 rpms down to around 50 rpms for the blades
Jun 30, 2016 | Hobart Food Mixers
Motor spins but blade doesn't
If there is a shaft sleeve available from Kitchen Aid you will need to replace that and most likely the chopping blade if there is any damage up inside it.
May 01, 2013 | KitchenAid 3.5-Cup Food Chopper KFC3511
Kp2671 stops and starts
It is not going to be a problem with the motor. It is going to be a chipped/damaged gear, a bent planetary center shaft pin, or possibly the planetary itself.
The first thing you need to do is take the mixer apart. You are going to have to clean of all of the gears and inspect them very closely. I recommend using paper towels and wd-40. If there is any damage, the gear will need to be replaced, in some cases the pin that sits between the worm follower gear and bevel gear can become bent, if it is, it also needs to be replaced. If all of the gears, bearings, and the pin are in perfect shape inspect your planetary assembly. In some cases the center shaft, which is pressed into the planetary can become loose, so it will still spin under no load, but as soon as you put something in the bowl it stops spinning.
Here is a link to the KitchenAid service manual. This will walk you through how to take the mixer apart, and put it back together: http://lib.store.yahoo.net/lib/mendingshed/kitchenaid6qtservicemanual.pdf
Please let me know if you have any questions, or need help with the repair.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Feb 15, 2013 | KitchenAid KSM103 Professional 5 Series...
I can hear the motor running but the component doesn't turn. This happened when I was trying to make pasta.
There is a good chance that the Worm Gear Follower has been stripped
(i.e. all the teeth on the gear are damaged). Download a copy of the
Repair Part List from Kitchenaid.com for your particular model.
Depending on which model you have, it might be an absolute pain
to replace it without the proper knowledge and tools, especially the
Professional 6 Series.
Jun 16, 2011 | KitchenAid Food Mixers
My kitchaid stopped working. Is it worth getting
CARREN90 – You don’t provide a lot of information, which would be helpful in providing a rational answer to your question. What model KA mixer do you own? How old is it? Is it under warranty? What do you mean by stopped working? Do you mean the motor runs but the agitator doesn’t turn or the motor doesn’t run at all? The more information provided, the better the answer I can offer. That being said, if your KA mixer is less than 20 years old, it might be worth repairing.
First, there are only two reasons it stopped working - an electrical problem; the electric motor or one of it’s components has failed so it is not getting electricity (power) to run; or a mechanical problem – one (or more) of the transmission gears has failed, and although the electric motor may still run, the agitator is not turning in the bowl.
Either problem is fixable; depending on how intimately you wish to get acquainted with the internal workings of your mixer. If you are DITY type person and feel adventurous, and your mixer is not under warranty you can troubleshoot it yourself. Be sure you have the Parts List manual on hand. If you're lacking one, you can download it from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number select a file under Parts List and then check to see it this matches your mixer model. You can check the disassembly and reassembly of your mixer, along with all the parts. It can be messy but gratifying. Once apart you can check for any other unseemly wear and tear on the gears, etc.
If you feel troubleshooting and repairing is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can provide you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances (again the more information you provide the better their answers will be to you) and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping. If the estimates exceed the original purchase price, you might consider purchasing a new one, but that is a decision only you can make. Hey, Christmas is just around the corner!!
Good luck, I hope this helps! Howard – Burke, VA
If this solution has helped you, please rate it, thanks! hslincoln
Nov 28, 2009 | KitchenAid Food Mixers
Question regarding KitchAid mixer, Model K45ss. The vertical mixer shaft has play in the gearbox, it makes worn gear noises at all speeds. I adjusted the speed control to manual specs, the speed control...
Yes this indeed does sound like you have a problem. There could be a couple different cause of this noise. If your main drive or worm gear has been damaged, it is likely to not run at all or jam up. So i think this is not the problem. There is however a codder pin located inside the transmission gears this can be seen by removing the upper housing of the unit, and then exposing the oil and gears. clear away the oil surrounding the gears, and save this grease for later. After this you should be able to visually see this codder pin AND the gears, rotate the gears while inspecting them and the pin. If the pin is slightly bent or broken this will make the grinding noise that your are talking about, while still operating and driving the unit. part number for the codder pin is 9705444. If however the noise is coming from the motor area this could indicate a worn or faulty motor bearing. This can cause the motor to operate on an angle and can cause a rubbing noise from the cooling fan or the winding of the motor itself rubbing on the mixer housing. Part number for the braket and bearing is 3180526. both are relatively cheap and easy to replace. If you find and fix the problem be sure to inspect or change the oil as this can often have metal chunks and other particles. Hope this Helps
Thanks
Nov 02, 2009 | KitchenAid K45SS Classic Stand Mixer
Will not spin dry
If your washer won't spin, check these:
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Thanks for contacting Fixya.com
Aug 16, 2009 | Kenmore KSM100 Stand Mixer
MOTOR SPINS ON MY CLASSIC STAND MIXER BUT GEARS DON'T ENGAGE
Hi all. There is damage to the transmission caused by overloading the mixer with bread or cookie dough, or by dropping a spoon or measuring cup into the mixer while it was working.
Go to mendingshed.com and download their free kitchenaid repair manual. This manual has all you, or a repair person will need to repair your model's mixer. Mending Shed also sells needed parts.
If this solution has assisted you, please rate it. ricardok45
Mar 06, 2009 | KitchenAid K45SS Classic Stand Mixer
Hobart A200 Stand Mixer Logo
653 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
