Question about Kenmore 24032\24036 Top Load Washer
What can i do to solve this problem.
My washing machine is not washing at all, its fills halfway with water then it drians out, i have to physically add more water for it to begin washing, it does the same with rinse also.
  • Kenmore Master
  • 8,220 Answers
That must be a bad water valve. This video shows how t access it for replacement
Posted on May 07, 2010
WFL2400AU fills with water then stops
probably just the carbon brushes on the motor the only way to get at to check is to remove the motor and they can be a arkward to get off
Mar 03, 2014 | Bosch Washing Machines
My kenmore washer fills but wont pump the water out. it washes and spins, but i have to **** the water out with my shopvac. the drian hose is not clogged or kinked. could it be the water pump?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 14, 2011 | Washing Machines
Washing will not hold water. it fills and agitates while it slowly drains
check the drian hose to see if it is to fare down the drian often it only needs to be six inches if any more it will sifion its self out
Jan 23, 2010 | GE 3.2 cu. ft. Washer
The water keeps running in and out. It never fills up, seems like the valve does not close
sounds like the machine is on drian and not fill check the knobes to make sure it not out of place
Oct 31, 2009 | Whirlpool Inglis IP4400 Washer
Dish washer fills and then drians without washing
If you're sure it is heating the water, then it sounds like the wash motor/pump has failed. If you've worked on washing machines and/or dish washers before, this is potentialy a DIY job - the Haynes Dishwasher manual is very good, and parts can be found on the internet.
The reason for cheking it is actually heating the water is that the symptoms sound very similar to those of a failed heater = fill, pause, empty, stop usually accompanied wth an error code. Error code will be presented by a number of flashes of a lamp, or a number on a display panle depending whch machine you've got.
Sep 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
LG WM1832CW water leaking
your valve is not closing or your cycle isn't reading correctly. there should have been a diagnostic read process that should have came with the machine. if not you may have to end up buying a new drian assembly
Jan 15, 2009 | LG WM-1832C Front Load Washer
Washing machine trouble
You need to replace the water level selector switch. You can check the part at repairclinic.com
Jun 27, 2008 | Washing Machines
Halp
Hello it could be your lint filter or a hose is blocked by an object. May be even in the pump. Had a similar problem with our Maytag. Cheers.
Mar 08, 2008 | Washing Machines
Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
42 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
