To reset the control use this key dance within 5 seconds press:
HEATED
DRY, NORMAL, HEATED DRY, NORMAL
The clean light blinks as it ran a cycle and the water did not heat properly. I have put together a page showing what might cause this. Take a look at the link and let me know if you have problems or questions.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
Try unplugging it for 5 minutes, While unplugged, press and hold one of the bottons for 5 full seconds. Then let go, wait a couple more minutes and plug back in. It should reset.
Also check all your drains for an clogging
the dishwasher is built in and I have no way to get to the plug in - and I believe its hard wired anyways. any other suggestions?
I'M STILL WAITING FOR ANOTHER SOLUTION. DO I NEED TO GET A REPAIR GUY OUT HERE OR WHAT?:
I HAVE A WHIRLPOOL QUIET PARTNER II THAT THE CLEAN LITE KEEPS FLASHING. THIS UNIT IS HARD WIRED AND BUILT IN SO IT CANNOT BE UNPLUGGED. ANY SUGGESTIONS? DO I NEED TO GET A REPAIR GUY OUT HERE TO FIX IT?
thank you so much! I will try this solution. also have the guy come back who moved it as it may not be even (just had kitchen remodeled and wondered about the water not heating up afterwards!)
