Question about Whirlpool 6.5 Cu. Ft. Super Capacity Gas Dryer
Need to replace drum belt
Have proper belt. do not see how slack in belt is taken up to bring it tight against drum and drive wheel of motor
    Novelist:
  • 145 Answers
Most dryers have a tensioner pulley that the belt needs to go around to keep it tight. The belt goes around the motor pulley and the drum, but it goes around the tensioner pulley in a way that would keep it tight (you also need to release the tension on the tensioner to get the belt around it) If there's not a tensioner pulley there has to be some other means of putting tension on that belt, look around the the other pulleys that the belt goes around.
Posted on May 08, 2010
How do i get the belt around the motor pully wheel on a white knite cl637wv
If you can't push the tensioner pulley back far enough to allow the belt to go around it, disconnect the tensioner spring, route the belt, then reconnect the spring. If it's a question of having adequate strength to push against the spring and still have a hand free to route the belt, find something to jam against the tensioner to hold a bit of slack in the pulley. Make sure the jamming tool (large screwdriver, block of wood, etc.) is sturdy enough to hold securely, and well-braced. An ill-timed slip could cause severe hand injury.
If your dryer does not have a belt tensioner mechanism, the motor bracket probably has belt adjustment slots in it. In that case, loosen (but do not remove) the motor mounting bolts that go through the slots, push the motor over a bit to give you the slack you need,route the belt, then pull the motor back to tighten the belt and retighten the motor bolts. Sometimes a tight belt can be rolled onto the pulley by starting it on one side of the pulley and turning the pulley by hand while pushing the belt along in the direction of the turn, but it is better to mount the belt with slack in it; excess stretching causes premature failure.
Nov 30, 2014 | Dryers
Belt has come off from drive pully to drum wheel. when trying to refit, belt runs off drive pully when i turn drum wheel by hand. machine not that old and belt in good condition (checked it against new...
I always recommend the purchase of a new belt anyway- but you appear to have one!
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 07, 2011 | Washing Machines
I'm installing a drive belt on a Whirlpool LEW0050PQ dryer. I've opened the back of the unit to expose the drum and drive motor. The new belt, part # 8182481, will have to stretch at least 3" to...
if it is a rubber belt like a big "O" ring it is necessary to warm up the rubber by stretching it (like you are building up your abs)
it will be tight to fit but it will go on
Jul 02, 2017 | Whirlpool LEW0050P Electric Dryer
Diagram for setting up belt on drum tenion
Replacing the Belt
  • Step 1 Put the dryer door-side down on the floor. This allows easier access to the back.
  • Step 2 Locate the center pivot suspending the dryer drum. If held by a clamp, removed any nuts or screws retaining the pivot axle.
  • Step 3 Move the pivot out of the bracket and slide the new belt inside the bracket.
  • Step 4 Replace the drum pivot in the bracket and reassemble the bracket.
    Looping the Belt
  • Step 1 Flip the dryer up so it is once again sitting upright.
  • Step 2 Locate the groove or wear mark the previous belt left in in the circumference of the drum.
  • Step 3 Wrap the belt around the drum in this groove or wear mark, with available slack at the bottom of the drum.
  • Step 4 Wrap the belt around the drive wheel located on the drive motor in the lower corner of the dryer.
  • Step 5 Insure the belt is snug but not biting the drive wheel. This indicates the proper size belt is installed.
    Reassembly
  • Step 1 Reattach any clips or wires to the back cover.
  • Step 2 Reattach the back cover using the six-sided sheet metal screws removed earlier.
  • Step 3 Reattach the top cover. Close tightly so clips secure the cover.
  • Step 4 Plug in the dryer and turn it on to test the belt repair.
  • Step 5 Reattach the dryer vent conduit
  • Feb 06, 2010 | GE Dryers
    The Maytag washer doesn't spin and had a burning rubber smell. Motor operates, but the drum does not spin. Belts have slack, motor pulley show evidence of belt turning which caused the burning rubber...
    You should have a tensioner pully (a small wheel on a piece of spring steel) that hold the belt tight.
    If that spring steel is broken or weak, then you will have to take the broken one to your local appliance repair parts shop and obtain a new one.
    That should keep the belt tight and keep the drum spinning.... -Jim
    Oct 23, 2009 | Washing Machines
    Cannot put the drum belt on
    make sure the bracket is properly cliped to the base and the iderl wheel is twords the tub
    pull the bel together under the tub, take the loop, pull it under the pully, lift the pully slighltly, place the loop on the motor
    Oct 14, 2009 | Kenmore 74602 Gas Dryer
    Need belt diagram for Performa PDET920AYW dryer
    Flat side of the belt goes agaist the drum. The diagram is on the new belt
    Aug 08, 2009 | Maytag PYE2300AY Electric Dryer
    Fitting tumble dryer drive belt
    Looking from rear of dryer,one spring on motor is for tension,therefore put belt around drum(groove to the drum surface).Then rotate the motor firmly clockwise tensioning the spring,take belt from right of drum over tension wheel then put grooves of belt on shaft of motor.Release motor to tension spring,job done !!!!!
    Mar 28, 2008 | Dryers
    Changing drive belt
    ensure that the tensioner pulley wheel is also part of the belt loop and that it is properly sprung to take up slack. sometimes, this pulley looks good mounted in reverse, giving no tension to belt. try it the other way, against the spring force.
    Sep 23, 2007 | Dryers
    Drive belt out of alignment
    check pulley is fully bolted home. also fault could be due to the bearing spider (on the drum) being broken or cracked on one leg. if this was so, would expect spin with clothes to be very noisy. get gack to me if you want. the belt is a stretchy belt ie no adjustment for tightness
    May 13, 2007 | Zanussi F1245W Front Load Washer
    Whirlpool 6.5 Cu. Ft. Super Capacity Gas Dryer Logo
    185 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
