Question about Smeg DWI614 Built-in Dishwasher
Smeg type 12034 dwi 710 i cannot get the door open?
E1 message on smeg DWI 614
see this causes and fix it. God bless you
E1--Leakage error--Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection (sink drain hose) is not over 20". Impeller of the washing pump is worn away
Sep 28, 2012 | Dishwashers
Door and handle problems. Smeg fa311x
sounds like your door is sprung. take door off and lay flat on a table outside of the door down. loosen screws on door liner . screws are hidden under door seal. when all loose not removed make sure door is flat on table. tighten the screws being careful not to move door. reinstall door and it should be ok. this is usually cause be either someone leaning or hanging on the door when it is open. or putting to heavy of items in the door trays.
May 26, 2012 | Smeg FA311X Top Freezer Refrigerator
SMEG DWI410 TRIPS CIRCUIT LATE IN WASHING CYCLE
just possibly
take the kick panel off. On some smeg, there is a small suppressor capacitor on the lhs tucked in the wiring. this breaks down. snip it off - no need to replace
Jul 18, 2008 | Smeg 18 in. DWI410 Built-in Dishwasher
I have a smeg dishwasher which keeps displaying error code 8. I know this has something to do with the water supply to the baskets but have checked and there does not seem to be a blockage. Any help...
Hi
I saw your post today and see your fault was dated back in July 2008. Well its a year late and I had the same problem coming up on my machine SMEG DWI 614, error E8 to be exact. After 6 hours of trying to resolve this cleaning PCB, etc. (one can see its the recession and money is scarce) I finally pulled out the diverter valve, dismantled it and left it in some boiling water with limescale remover. I made sure the plastic teeth in the mechanism could spin properly and inserted back into the machine....
And finally the machine works once again. It was 6 hours of my time but probably saved me +/- £150.
Later
Jul 12, 2008 | Dishwashers
The oven door won't close properly, it just hangs slackly about 2 cm from the seal. it's a smeg wall oven.
the clips on these oven are canyilver type they can move out of position if opened abruptly .to refit correctly lift door upwards while pushing the bottom of the door inwards.you should feeel a strong resistance from the door springs.there should be a notch n the bottom of the hinge this should slot over the oven frame.if this does not solve the problem then the springs have probably gone on the hinges and will need to replace both hinge assemblies
Jul 11, 2008 | Smeg Kitchen Ranges
Whirlpool g2p dwi
either the latch thats on the door is bad,,or the catch on the tub is out of line,,,now if the dishwasher door drops hard and wont stay up ..you need new door spring and the weight makes it pop[ open..
Feb 17, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Smeg Fab 32 door problem
Remove the lower hinge on the fridge door and pack out using a piece of cardboard resrcew the hinge onto the door, this will resolve the problem Regards Advisor Smeg Agent
Jun 08, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Smeg DWI614 Built-in Dishwasher Logo
46 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
