Question about Fuji FP-988D 19" Flat Panel LCD Monitor
Not working My monitor won't turn on..
    Champion:
  • 293 Answers
Hey... friend,
If your monitor have no screen or died in 3 second... Then it's seems your inverter that is burnt out... Need to replaced or repaired...go to this site @ www.3rd-rocks.com They can repaired it for you.
Posted on Jun 23, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 121 Answers
It could be possible that the pwr cord might have gone bad. change it .
before doing that try disconnecting the pwr cord from the back of monitor and hold the pwr button for 30 sec. connect the pwr cord properly and then restart the comp. if this does not work then check with other pwr outlet. if this doesnot work then replace the monitor its a problem with the monitor and needs to be replaced// nothing is wrong with the computer//
Posted on May 07, 2010
Hp pro book turns on but screen won't work
Did you try connecting it to an external monitor? Then try software updates and see if you can roll back the driver for the monitor or the computer to when it worked right.
Mar 16, 2013 | Computers & Internet
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
Monitor won't go on
What to you mean by Monitor won't go on? Are you saying the power on the monitor will not turn on? Are you saying the Monitor is on, but there is nothing showing on the screen? Also it would help if we know what kind of computer and what operating system.
Mar 22, 2012 | HP G60-235DX Notebook
Monitor won't go on
Mar 22, 2012 | HP Pavilion G60-235DX notebook
Vsonic flat screen monitor need blink codes
hi do you mean you are asking for the blinking codes on your viewsonic pc monitor?. usually lcd monitor for pc has no blinking codes, if your monitor just only a blinking indicator and won't turn on, you must check first the source from your pc if their is a signal to turn on the monitor. if just blinking only then won't turn on you must check the power supply of the monitor usually the main cause is bulging capacitor. just replace it with the same value and rating thanks for consulting the fixya good luck.
Feb 26, 2012 | Computers & Internet
AL 1706 troubleshouting monitor wont turn on green
If your monitor shows a yellow light and it won't turn green, the problem most likely lies with the computer. If your computer is not sending a signal to the monitor, then you have a computer problem. One way to test this is to turn the monitor off and the computer off, too.
Turn the monitor on and if it is working, it should display a message telling you that there is no signal. If you see that message, you can assume the monitor is working. If you do see it, now turn on the computer and see if the message changes.
If you turn the monitor on and you get no message, you can assume the problem lies with the monitor itself.
If you have access to another monitor, hook that one up to test the computer output.
You can now either get the monitor fixed or the computer fixed, depending on which one is bad.
May 31, 2011 | Acer Computers & Internet
When i turn on my pc, the cpu works perfectly while the monitor "syncmaster591s"....when i turn on the monitor the light (green) beside the button of the monitor is blinking
Try a different monitor...if the different one won't come up then the prob is your video card in the computer...if it does work then the monitor is defective...it would probably be cheaper to get a new monitor than to have the syncmaster fixed
Apr 27, 2011 | Computers & Internet
Monitor won,t turn on light just flashes
check your connections to your computer, test it on another, if it works your video cards bad if not need to buy a new one..
Apr 15, 2011 | BenQ 22" G2200w LCD Monitor
The OSD screen is up and won`t dissengage(after trying the 10 second hold down) , also the video display say`s switch the cable leads , I don`t understand. The menu,+,-, auto buttons won`t work. What might...
try powering off your monitor and disconnect the cable at both ends. switch the ends if that doesn't work try another cable.then turn the monitor back on see if the osd menu went away.
Mar 23, 2010 | HP RY117AA w2408 24" Widescreen LCD
COMPUTER WON,T YURN ON
first of all,is your power cable properly connected to your system unit.if it is not,connect it properly and turn the system unit on again
secondly,make sure your signal cable from the monitor to the system unit is properly connected
after following these instructions,reboot your computer again.
thank you for consulting fixya with your problems
Feb 14, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Fuji FP-988D 19" Flat Panel LCD Monitor Logo
108 people viewed this question
Top Fuji Computers & Internet Experts
Computer Links
Victorman
Victorman
robert
Are you a Fuji Computer and Internet Expert? Answer questions, earn points and help others
