Question about Canon FAX-JX200
The ink lamp flashes even though it is a new - Canon FAX-JX200
2 Suggested Answers
SOURCE: the ink lamp flashes even though it is a new
the ink lamp flashes even though it is a new cartridge and is prining fine how can i stop it flashing
Posted on May 07, 2010
Black ink alone not printing
what brand ink? does the printer utility software on thecomputer tell you anyhthing about the ink? are the ink lights flashing even though the cartridge is in? If so it's probably a bad cart
Aug 29, 2012 | Epson Stylus C79 InkJet Printer
Shows code U165
This section explains the way to confirm the ink status and the procedure to replace ink tanks. When ink runs out or other errors occur, an error message is displayed on the LCD to inform you of the error. See "An Error Message Is Displayed on the LCD".
When printing from your computer, error messages appear on your computer screen as well.
NOTE
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder.
The machine will not print if an ink tank is installed in the incorrect position.
With the LCD of this MachineMake sure that the machine is turned on, then press the COPY, FAX, SCAN, or MEMORY CARD button. The current ink level will be displayed on the LCD for a few seconds.
g0011480_tcm14-605381.png(A) Confirm whether any symbols are displayed here.
g0011482_tcm14-605375.pngColor or black ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011483_tcm14-605376.pngColor or black ink may have run out. See"An Error Message Is Displayed on the LCD".
REFERENCE
The ink status information is also displayed on the screen that appears during printing.
An error message may be displayed on the LCD during printing.
g0011494_tcm14-605377.pngMachine detected ink out condition. See "An Error Message Is Displayed on the LCD" and take appropriate action.
(B) Empty ink tank.With the Ink LampsYou can confirm the status of each ink tank by the ink lamps. Open the Scanning Unit (Printer Cover) of the machine to confirm how the ink lamps light or flash.
  • Ink lamp is on
The ink tank is correctly set and there is enough ink remaining to print.
  • Ink lamp is flashing
Flashing slowly (at around 3-second intervals)
Ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.
Flashing quickly (at around 1-second intervals)
The ink tank is inserted in the wrong position or it is empty. Ensure that the ink tank is in the correct position as directed by the label on the Print Head Holder. If the position is correct and its lamp flashes, it is empty. Replace it with a new one.
  • Ink lamp is off
The ink tank is not set properly or the function for detecting the remaining ink level is disabled.
If the ink tank is not set properly, press the g0009324_tcm14-605384.png mark on the ink tank until the tank clicks into place. If it does not click into place, make sure that the orange protective cap has been removed from the bottom of the ink tank.
If the function for detecting the remaining ink level is disabled, replace the ink tank with anew one. See "Replacing Ink Tanks".
If the lamps are still off after reinserting the ink tanks, there has been an error and the
machine cannot print. Check the error message displayed on the LCD. See "An Error
Getting the Clear Ink Status InformationClear ink is used only when printing on plain paper.
When Plain paper (Cassette) is selected for Media type and printing begins when clear ink (PGI-9Clear) is low, a message will be displayed in the LCD.
g0011497_tcm14-605385.png(A) Confirm whether a symbol is displayed here.
g0011502_tcm14-605378.pngThe clear ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011503_tcm14-605379.pngThe clear ink tank is empty. See ""The clear ink tank is empty. Replacing the ink tank is recommended." U045" and take appropriate action.
NOTE
  • The ink status information is also displayed on the screen that appears during printing.
  • Clear ink is used only when printing on plain paper. Therefore, it is possible to print on photo paper, or any type of paper other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
The following error message will be displayed on the LCD when the clear ink has run out during printing on plain paper.
g0011506_tcm14-605380.pngRefer to "Replacing Ink Tanks"If you continue printing under the clear ink out condition, see ""The clear Ink has run out. Replace the ink tank." U165/U166" and take appropriate action.When the clear ink hasrun out, printing on plain paper from the Cassette is not possible. The fax, which is received under the clear ink out condition, will be stored in memory.
NOTE
It is possible to print on photo paper, or any media type other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
Oct 01, 2011 | Canon PIXMA MX340 Wireless Office...
The ink lamp flashes even though it is a new cartridge and is prining fine how can i stop it flashing
Feb 27, 2010 | Canon FAX-JX200
MY ALARM ON MY MP210 IS ON AN MY COLOR INK FLASHES WHAT DO I DO
Check the status of each cartride by using the ink lamp.
You have 3 lamps
(A) Alarm lamp
(B) Black ink lamp
(C) Color ink lamp
Make sure that the LED is on standby mode.
a) If the ink lamp lights.
Cause : Ink is low.
Action :You can continue printing for a while, but we recommend you have a new FINE cartridge available.
b) The Alarm Lamp lights and the ink lamp flashes .
* If "E, 1, 3 " is displayed on the LED, ink has run out.
Cause : Ink level cannot be detected.
Action : Ink may have run out.
The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected.
If you want to continue printing without this function, press Stop/Resset buttonfor atleast 5 seconds.
Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities.
* If E,1, 6" is displayed on the LED,
Cause : Ink has run out.
Action. Rreplace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress, you want to continue printing, press the Stop/Reset button for atleast 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
c) Only the ink lamp flashes
Cause : The function for detecting the remaining in level is disabled.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 04, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Both Ink Lights Keep Flashing
You might have a printhead problem. Call 1.800.421.6699 to get a new one.
Feb 26, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
The lamp continues to flash red lights for power and lamp
I have the same problem as posted too, ordered 3 new lamps and they all still do the same thing. I`m starting to think its the projector that has a problem. Anyone got a solution other then keep buying new lamps and try getting it to work... I mean, after 3, how bad lucky can you be that they are all bad lamps...
Dec 04, 2008 | ViewSonic PJ500 Multimedia Projector
CANON 1P4200 PRINTER
I would try a new ink tank. They do go bad even though they have ink in them.
Mar 21, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Sanning problems for printer PIXMA MP 160
some printers can detect that the cartridges are refilled based ona barcode or scanning of the cartridges. Does this Cannon have ink tanks or ink cartridges. If it has intakes then the print head needs to be cleaned wth rubbing alcohol and a q-tip. If they are cartridges then it would be good just to buy the original cartidges. As far as the scanning goes this can be a direct connection to the printer going through maintenance. If it continues to not scan then you may need to uninstall the scanner. see if the scanner shows up in your scanners area. if not then it will need to be re-installed.
Feb 13, 2008 | Computers & Internet
Lamp
red light indicates lamp is expired. even though you get temporary light, the lamp is shot. Try BULBMAN.COM for a new lamp.
Sep 25, 2007 | Toshiba TDP-S20U Multimedia Projector
Inaccurate error message
According to Canon's website:
Details Print Friendly Version Issue: ERROR LCD: More than one ink tank of the following color is installed U071
Solution: Replace defective ink tank (MP500 / MP800)
Replacing An Ink Tank Use the following procedure to replace empty ink tanks or when an ink tank error appears.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.).
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Press the ink tank's tab (1), then remove it from the slot (2).
  5. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    Note: Tear the orange tape carefully along the dotted line. If the orange tape remains, printing problems may occur.
    <4> Tape is completely removed.
    <5> Tape remains. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    Caution: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  6. Insert ink tanks into the print head.
    Note: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  7. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  8. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
  • On: The printer is ready to print.
  • Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
  • Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
  • Off: An error has occurred and the printer is not ready to print.
Aug 14, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon FAX-JX200 Logo
22 people viewed this question
old marine
old marine
