Question about Dishwashers
TRITON Trance electric shower
I have a triton trance shower unit (approx 1 yr old) which recently tripped for no apparent reason. since then the water runs luke warm on the normally hot setting and there is no obvious signs of a drop in water pressure. I assumed that the isolation switch (pull cord) was damaged so i have changed which has had no affect on the tempreture. The shower is still hot but only on the highest setting with limited water coming out.
Any suggestions?
  • b001 Mar 09, 2009
    I have the same problem, the low pressure light is on, when this happens.
    My unit is new.
    However this is in the dishwasher section
  • Anonymous Mar 09, 2009
    I have a Triton Trance shower and have the exact same problem , it tripped out, then when power is put back on it does not heat the water properly. This happend before to a Triton Trance i had previously , i replaced it with the Trance i have now for ease of intallation. In both cases the showers are only about 18 months old. I will now be going to another maker to replace it.
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Posted on Mar 09, 2010
My Triton shower Eco Excite 8.5kW keeps tripping fuse when turned on !!
Could be a pump jam, do you have hard water ? Could be scale build up.
Is the shower head blocked ? Unscrew just the head (leaving the hose line attached to shower) and try again. If that is the blockage, then clean it with descaler.
Also check you have a good pressure on your water supply going in the Triton. Low pressure can set off safety switches. Again, check for blockages.
Check also for breaks in wiring and check there is no water ingress at any and all connections.
Is it an old unit ? Is it serviced regularly ? .......finally....
are all the settings set to MAX ? if so then use lowest setting first.
If it works then move settings up gradually until it trips.
Any filters need to be checked if possible.
Good luck Red.
Jul 16, 2016 | Home
I have a triton trance 2nd generation electic shower that is a couple of years old when you turn the flow on it comes out red hot but as you increase the flow it gets colder as flow is increased what is...
Is it possible to have plumber come inspect? Warranty from purchase place? Since you don't sound you put it in I'm guessing a plumber did? It would've been new to him for the most part and he may have hooked something up wrong? You CAN DIY but realize that we're talking electric AND plumbing here. I'm thinking since it heats up the electric is fine. But check your man's work to see if it's got the 30-45A fuse on a dedicated circuit.
Steps
1.While out ay elect. box turn OFF by removing fuse or switching to OFF. Test unit that it only runs cold water.
2. Find shut off for water. Sometimes you have to shut off whole house! Hopefully somebody added a shutoff. Look on backside of shower for a 1'x1' hatch covering with a cold and hot valve. Turn water off. Test unit to see if it runs.
3. Now use the manual below and get in there and see if its hooked up right. Go slow and take your time. Retrace the install instructions.
Best wishes. Wear nitrile gloves for peace of mind!
DON'T do it if you're not aware of the electrocution issue. Water all over your bathroom (loo?) is one thing, a 230v shock is another!
http://www.tritonshowers.co.uk/media/640966/trance.pdf
Jan 11, 2015 | Home
Triton cara shower has power and water to it but nothing comes out
CHECK YOUR POWER SUPPLY BOX MAKE CERTAIN THAT IT IS INDEED ON IF SO IT MAY BE A BAD CIRCUIT BRAKER MAY NEED TO REPLACE IT.
Apr 15, 2014 | Camp Chef Triton Hot Water Shower Heater
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
Why is my triton shower tripping electric shower casing feels hot(on top) too
According to me, you should contact to a professional that really helps you to get rid of this major problem. A professional can easily identify the problem regarding the triton shower.
Apr 17, 2012 | Home
Turned on a triton trance electric shower it was working ok then it stopped coming out of the shower head and coming out of the overflow pipe at the bottom of the shower unit
The overflow pipe is a pressure relief device which is a small rubber ball that get's ejected when the water pressure inside the shower is too high. You will need to get a spare part to replace this. These generally operate because the showerhose is in poor condition and has collapsed internally, or the showerhead has become clogged up so check these things first.
Good luck.
Sep 21, 2009 | Kitchen Appliances - Others
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
Dec 01, 2008 | Home
Dishwashers Logo
1,668 people viewed this question
Top Dishwashers Experts
