Question about Brother DCP-7020 All-In-One Laser Printer
My Brother DCP 7020 won't stop flashing close back door
    Brigadier General:
  • 10,406 Answers
There's a micro-switch that "trips" when the door is opened/closed. It's not sending a "closed" signal to the printer. Clean the switch, with a blast of compressed air. Check that a small "finger" is going-in to the slot, to "trip" the sensor, as the door is closing.
Posted on May 07, 2010
BACK COVER OPEN
The back cover sensor is detecting the back door is opened. Open and close the back door firmly to fix this message.
Aug 22, 2012 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 Paper Jam, we keep having the paper jam at the paper exit at the top/back of machine. I've examined closely from front, back, bottom, even removing a few easily removed parts, but can...
This is caused by dirty exit roller. As this machine is a pain to dismantle I suggest that you try and clean these rollers ( 3 or 4 rubber small ) as they rotate. Opening and closing the front door will keep rotating them for you. Use a damp wrm water lint free cloth. I use a compound named Print Clean but metho can be used also.
May 11, 2011 | Brother DCP-7020 All-In-One Laser Printer
Dcp 7020 "Back Cover Open" lights up even after it
Try doing a power reset.
Turn off the printer/Unplug it for a few minutes/Plug it back in/Turn it back on.
Jan 11, 2011 | Brother DCP-7020 All-In-One Laser Printer
The Brother DCP 7020 printer displays error
back cover door switch is displace so it called back cover open.
Oct 12, 2009 | Brother DCP-7020 All-In-One Laser Printer
Back door open alert
Twist the printer so that you can see the back of the printer.
Near the bottom, there is a door that swings down.
Swing it down and it will open (get familiar with it). Then close it. There is a magnetic catch.
Oct 05, 2009 | Brother DCP-7020 All-In-One Laser Printer
Brother dcp-7020 printer shows error back door open.
open the front door then pull away your ink cartridge then clean dust or blur from ink cartridge position then refix ink cartridge again.
Mar 21, 2009 | Brother DCP-7020 All-In-One Laser Printer
Back Door Open on Brother DCP-7020 printer
I opened the back panel and yanked out the piece of paper that was apparently halfway through the machine. Message dissapeared, printer warmed up and I could print again. This would appear to be a poorly designed error messaging system that wasn't properly tested.
Oct 23, 2008 | Brother DCP-7020 All-In-One Laser Printer
Help
one ot the doors, most likely the one on the right is not closed, there is a sensor switch there it is not being activated, make sure all levers are in he correct positions so the doors can close evenly.
Jul 23, 2008 | Brother DCP 7010 Multifunction Laser...
Brother dcp 7020 says toner end life
unplug plug it back in, did you remove the protective cover and clean coria wire?
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000065/faq000065_018.html?reg=us&c=us&lang=en&prod=dcp7020_us
Dec 20, 2007 | Brother DCP-7020 All-In-One Laser Printer
Back cover error on LCD won't go away
This is most likely caused by the back cover switch. It is either broken or the lever on the back cover is broken off.
Sep 14, 2007 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
200 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
