Question about Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television
After replacing a bulb, when power on, it flash first green and goes to flash red continue to flashes red about 5 flash each time what should i do?
  • 178 Answers
5 is a lamp driver fault, could be a poorly seated bulb or a bad ballast. Usaly it is a bad ballast. Previous bulb failure could have dammaged the balast.
Posted on May 07, 2010
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
I have an optima hd180 that will not power up. The projector was indicating a bad bulb, so I replaced that with a new one. Now it still will not power up and the fan does not come on either.
Problem w/ OEM bulb, it causes a lot of issues from my experience. Your ballast might have gone bad, hopefully it's just that. Check the voltage output of the ballast, make sure you're getting the proper amount.
Aug 14, 2015 | Office Equipment & Supplies
Tv dont power on green light flash then turns off red lights blinks 5 times
Had that problem and replace the lamp twice, I finally replaced the optic block.
It is quite involved to replace, if not technical get professional help.
Mar 21, 2014 | Sony KDS-60A2020 60" HDTV
Sony Wega kdf50we655 replaced bulb lights flashes green five times then goes red what's the issue?
the 5 blinks is indicating the lamp driver (ballast) has failed. You can get the replacement ballast for your model at the top of the following page
http://tvcircuitboards.com/sony_projection__dlp_circuit_boards
They can also assist with installation information,
Jan 02, 2013 | LG RU-52SZ51D 52" Rear Projection...
Red light blinks 5 times and wont power on. Is not the bulb
error code is model specific---some it means lamp door issue and others something else.
Oct 31, 2012 | Sony Televison & Video
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
Hi, About 3-4 weeks ago I replaced the bulb on my
I am having the same problem as mg2low. I changed the lamp, but my Sony KF60WE610 still will not turn on. It flashes green several times then it begins to flash red. Can you recommend some trouble-shooting for me? Thanks, Richard
Sep 05, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Just replaced lamp. when plugged in, power light
hello make sure the lamp is fitted securely and the lamp cover aswell
regards
shaun
Jan 16, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Blinking green light and clicking noise AFTER bulb replacement
do this. press and hold device and menu button on set for 5 seconds. this will retrieve a 2 digit error code .. the led will flash the first digit and pause the flash second digit. This unit is known to have capacitor problems on the power board. getting to these capacitors involves taking alot apart. let me know error codes and we can continue troubleshooting
Jan 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television Logo
181 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
