Question about Craftsman 25cc Gas Line Trimmer
What is carburator ajustment screw setting
What is carburetor adjustment screw setting after bottoming out
    Scholar:
  • 47 Answers
Just about any 2-cycle can be started by bottoming out the pins fully. (All in, clockwise rotation) Then, back them out 2 and a half turns. Remember, this will get it to start! Getting it to RUN will take some tweaking. If it idles, no worries, the idle is just there to keep it warm. Concentrate on fiddling with your high speed screw after the engine has idled up to operating temp for at least 3 minutes, and when placed into LOAD. NEVER adjust by sound or feel with NO LOAD. Too easy to get them too lean and pop their little heads off. ;D
Posted on May 09, 2010
Can't start chainsaw
Walter:
gently run the fuel and air mixture screws on the carburetor all the way closed (clockwise).then turn them out one and a quarter turns each. That setting should allow the saw to start if you are getting fuel to the carburetor. Once the saw starts, make fine adjustments to the fuel/air mixture screws until the saw runs to your satisfaction.
Jul 13, 2013 | Craftsman sears 18" Chain Saw Chain (...
Carburator and idle problem
Believe it or not you just said the solution to your own problem manufacturers specs requires for any adjustments to engine idle or other carburator adjustments to be preformed while the engine is idling and at normal operating temp in plain english let the car warm up then make your idle and mixture adjustments if this doesnt solve it i would check the auto choke and make sure it is opening at normal operating temp hope this helps good luck
Sep 01, 2008 | 1984 Toyota Tercel
Honda 25 cc 4 cycle mini tiller how to adjust carburator
With one screw you can adjust the idle speed, and with the second, located under the carburetor you can adjust the running or load speed.
Mar 22, 2013 | Honda 25cc 4-cycle Mini Tiller
Need to know all the ajustments on my mikuni hsr 42 motorcycle carburetor
Hi Marksnyder24, for more information about your question please visit the websites below. Good luck and have nice day.
Harley Davidson CV Carburator rebuild and float adjustment ep 18 eng Roma...
Sep 19, 2011 | Harley Davidson FLHR-FLHRI Road king...
I just put on a new rebuilt carburator on my 460 v8 1987 xlt 250 ford truck 4 WH. drive. its a motorcraft stock holley. I cant seem to find a way to ajust it. Wont run smooth or idle? It was set up for...
You have two setting screws on front of carb, You start off by adjusting all the way to the left, Then back off 3/4 turn to both setting screws, Then you have to set your air fuel mixture by just slowly turn your setting clock wise do so until vibration go away. Sorry there is no easy way to explain, Good luck to you,
Apr 03, 2011 | Ford F-250 Cars & Trucks
I am looking the idle adjustment screw on my 1971 350 cu. in. El Camino Carburator
Remove the air cleaner to access the carburetor.
Note the right side of the carburetor where the accelerator cable is connected.
The cable is connected to the accelerator cam which is stopped by the idle set screw.
The Idle adjustment screw head is pushing down on a spring, which should help Identify the correct adjustment screw.
Be careful not to adjust the smaller mixture screws, unless you have a vacuum gage.
If your Idle is too high you may get after run or knocking. I would set the timing then adjust the idle afterwards.
I hope this helps out since I do not know if the carburetor is stock or not.
Jul 28, 2010 | Chevrolet El Camino Cars & Trucks
How can you adjust the carburetor on a 1987 GMC safari van V-6
If the carburator has never been rebuilt, or the plugs that were installed at the factory have never been removed, you need to remove those plugs, there is one for each idle mixture screw, at the front of the base plate on the bottom of the carburator, 1 for the TPS adjustment on the driver side front of the carburator, and one for the mixture control solenoid on top of the carburator, in the middle, towards the front.
May 22, 2010 | 1987 GMC Safari
Can't adjust carburator.
look on the carburetor. there will be 2 screws right beside eachother. one is an idle jet and the other is the main jet. if you want faster or slower idle speeds, adjust idle jet. if you want more power, adjust the main jet. you have to get them set just right . they might smoke a little bit because you are throwing more fuel to it which means you are getting a richer mix
May 12, 2010 | Homelite Mighty Lite Lawn Trimmer
Need help on tuning my 2003 Honda crf150 carburetor. My ques is when the bike is started and you rap the throttle it has a slight bog when I rev it. Is there any adjustments on the carburetor?
yes there should be one adjusting screw normally it is a flat head screw driver with a spring around it adjust in to lean fuel mixture and out to enrich fuel mixture should be located near bottom of carburator
Jun 12, 2009 | 2005 Honda CRF 150 F
Craftsman 25cc Gas Line Trimmer Logo
476 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
