Question about GE 24 in. Profile PDW9280JSS Built-in Dishwasher
My GE PDW9280 dishwasher wont start - GE 24 in. Profile PDW9280JSS Built-in Dishwasher
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: GE DISHWASHER PROFILE PDW9280 WILL NOT DRAIN LAST
Hi.
Check that the drain hose is set at the correct height, as specified in the manual. Otherwise machine will not drain correctly.
Check that drain lines are clear.
Check Part # 328 VALVE FLAPPER, and Part # 505 SUMP INLET , Sump filter and parts (see diagram).
If there is no problem with parts above, and pump is new, then the control module must be tested reading volts at pump. For safety reasons the test is better done by a technician.
Posted on Apr 27, 2011
Ge dishwasher pdw9280n00ss
It is probably getting energized through a direct short. Normally this would trip the breaker but sometimes installers take shortcuts and don't properly ground the the unit. Find the correct breaker in the main panel and turn it off (double check with your VOM). then pull off the lower cover below the door. you should see where the romex cable enters a small junction box. pull the cover off and pull out the wires and see if you find any nicks in any of the wires. while the wires are pulled out and not touching the j-box turn the breaker back on. see if you get any voltage on the inside metal case. if not then you know the source of the problem. if you still see a voltage check the motor and see if the outside of the motor case has any voltage on it. if yes then the wiring to the motor or the motor itself is faulty. Without looking at it my first guess is a hot or neutral wire is in direct contact with the metal frame. Keep in mind neutral wires can carry returning current on them and thus can shock you as well.
Apr 20, 2014 | GE Dishwashers
Tip
Cant start my dishwasher.
When press stbut wont start my different lights turn on start.
on Jan 14, 2008 | GE GSD5620DBB Dishwasher
It is not very unusual to find 120V on the door panel. The voltage is fed straight to the control board from the mains from which it gets distributed to different components like door switch, detergent detector, motors and pumps. The layout is shown on this schematic
http://www.appliancepartspros.com/escutcheon-door-assembly-parts-for-ge-pdw9280n00ss.html
It is likely the door switch connection is leaking. You will need to take the multimeter (on ohms setting) and carefully measure the points on different components on the disassembled door panel for short to the panel body. Make sure the dishwasher is disconnected from the mains power.
Ge profile dishwasher wont drain. i have already replaced the drain motor. Why wont it drain completely
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 12, 2010 | GE Dishwashers
Ge dishwaser will run but wont spray any water
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 05, 2010 | GE Dishwashers
Ge profile dishwasher panel won't turn on
out of the blue my GE Profile dishwasher would not turn on. I turned the circuit breaker off for 5 seconds then on and it worked! fixed! saved $200!!!
Dec 31, 2008 | GE Profile PDW8000G Built-in Dishwasher
Built in ge dishwasher push button
Mine is doing the same thing. I just removed the motor & it is definitely where the smell is coming from. Mine is about 3 years old.
Aug 09, 2008 | GE Dishwashers
GE 24 in. Profile PDW9280JSS Built-in Dishwasher Logo
124 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
