Question about Mtd 22" Yard Machine Push Mower
Will start and run but rough idle.new plug,oil,draines tanked of gas,cleaned carbuerator.believe magneeto may have been moved.is there a gap setting for this.sounds like spark not right
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
5000 gap feeler gage
Posted on Sep 13, 2013
  • 61 Answers
Spark gap would be .010 for magneeto
Posted on May 09, 2010
Engine snug to turn. not froze up completely. Overfull oil level.
Drain the gas, then drain the oil. Now refill the oil to the correct amount/height. Remove the spark plug and rinse/clean it in some gas. If there is any build up, scrape it out and make sure the gap is correct. Spin the engine a couple of times to actuate everything. If you see any oil at the spark plug hole, spray a small amount of gas through the spark plug hole and spin the engine to distribute the gas. Reinstall the spark plug and put some gas in the tank. Remove the air cleaner, place your hand over the carb throat and spin the engine a couple of times. You will partially flood the engine, but this will thin any oil left in the cylinder and intake/exhaust ports. Replace the air cleaner and try to start the engine as you normally would. You should have compression by now and the engine should be trying to run. If it feels like it is still flooded, remove the spark plug again and spin the engine a couple of times with the throttle in the off position. Reinstall the spark plug after a few minutes and try to start the engine normally. It should run. It will probably be a bit rough and smoke, but this should pass once the oil burns away. If the engine still runs rough after the smoke clears, clean the spark plug again as it may be fouled.
May 18, 2016 | Briggs & Stratton 550 Series Vertical...
Won't crank have cleaned carburetor changed spark plug drained gas and put fresh had it cranking at one point and could ride it but it would not idle
Will it start with starter fluid? If it will run with starter fluid then u need to rrebuild the carburator (yes again) sound like the needle is sticking or clogged
Oct 22, 2012 | Toys
Craftsman 32cc weed trimmer will not stay running when trigger depressed after start & warmup ... Bad gas? Plug gap? Choke adjustment? Suggestions?
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Plug gap should be 0.020". Bad fuel usually means poor starting and idling as well as poor high speed running. Try setting the H jet needle CCW somewhat to increase fuel input to the engine. It should 4-stroke lightly at speed, then 2-stroke immediately when the line is cutting. Be sure to use a modern synthetic saw oil in the fuel (available at home centers, hardware stores, and saw dealers) and be sure to shake the container thoroughly just before filling the tank each time to prevent oil starvation. Hope this helps!
Jan 03, 2011 | Garden
Motor will start on choke setting and then it immediately dies when moving the choke lever to the run position. Cleaned carb, new plug new air cleaner and checked all linkages. the motor has new oil and...
You say you cleaned the carb. If you did that by spraying cleaner in through the choke, that's good, but it doesn't get to the root of the problem. The problem is getting the gas into the carb. Try this. drain the gas. Put a small amount of carb cleaner and gas in the tank (about 1:1) Start it up, but don't run it dry. Let it sit for an hour. Then start it up and run the tank dry. Then try just a little gas to see if that fixed it. If not, repeat. Good luck Al K
Dec 23, 2010 | Honda Garden
Back fires and rough engine
Drain your fuel tank first. Then mix 50/50 parts mixing oil and fresh gas. Put fresh gas into the saw as well as putting in a new spark plug and start it up. Stale gas (gas that has sat in the tank or gas jug for an extended period of time), bad gas or water in the gas will cause it to rough idle and back fire.
Nov 14, 2010 | Garden
John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Apr 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Rough start, won't stay running. Got bad gas at
Drain the tank of the old fuel completely, try to drain the fuel lines as best you can. Whilst the tank is empty, if you can remove the fuel pump and clean out the filter for debris or gunk. Pull out the spark plugs and see if they have fouled, don't try cleaning them just replace. I have found once a plug is fouled, it is best to just bite the bullit and buy new ones as issues can happen again.
Nov 24, 2009 | 2005 Suzuki Boulevard C90T
Husqvarna chain saw works great until its shut off then it wont start again
A couple of suggestions:
How old is the gas in the tank? If it has sat for a year in the tank or the can, the gas won't burn as easily because of octane breakdown. Mix in newly bought gas (with oil of course).
Pull the spark plug(s) and check the spark gap referring to your manual. If the gap is too wide, you'll have a hard time starting it.
It's also a good idea to check how dirty your spark plugs are, and clean if necessary.
Depending on the age of the saw, if it's 35 years old or more, you may have to put less 2-cycle oil into your mix. The ratio has changed for all 2 cycle engines if they're approximately 35 years or older. Instead of 30 to 1 it's now 50 to 1.
Sep 21, 2009 | Garden
My bike is running rough and hesitating.
I think you will either have to dismantle the carb and clean the floats and jets. Or you need new filter that is inside the gas tank.
Aug 07, 2009 | 2001 Yamaha V Star Classic
Mtd 22" Yard Machine Push Mower Logo
305 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
