Question about KitchenAid KFP740/KFP750/KFPW760 Food Processor
The handler gets dirty inside and there is no way to clean it. I am trying to get instruction hor disassembly the handler
  • 11,896 Answers
Use vinegar.
Posted on May 07, 2010
How do I remove the center post to clean it?
Google Mfg, model possibly year and your problem. You will probably get a number of suggestions. Otherwise, I'd email MFG customer service. They may like to know their instructions are not clear (and need to revise the book)
May 14, 2015 | Food Processors
My bowl will not turn by itself anymore on my Oster Regency. How can i fix this problem?
Unplug electricity cord from wall and disassemble bowl carefully. Clean dirts on moving parts. Be careful not to leave any liquid on any piece.
If motor output shaft rusted; use some rust remover on piece of cloth and clean it. Be carefull; don't use too much rust remover and don't let it go into motor to prevent electrical shock. Try to turn output shaft by hand. If it turns easly assemble everything back again. If it doesn't turn that means; motor might has some issues. There is no way to fix it but changing motor with a new exact one.
Nov 19, 2014 | Food Processors
Salton quick mill disassembly
last four digits of phone
Jun 20, 2013 | Food Processors
My magic bullet won't press down. It stays stuck and I cannot get the cup to push down onto the turning mechanism that is totally intact. It seems the side 3 pieces will not move downward when the cup is...
Had the same problem - it wouldn't press down. The little white plastic things inside of the base that go up and down when the cup is pushed down, were stuck. I think that something leaked into them so they wouldn't slide easily. I wiped out the inside of the base with a damp cloth and then I put a drop or two of WD40 at the top of the white plastic pieces and rubbed it up and down the length of all 3 of the white plastic pieces (this being done with the base lying on its side so the WD40 doesn't drip down into the mechanism). Then, with base upright, I used a screwdriver to try to manually push the white plastic pieces down. It worked. Of course before doing any of this - be sure the thing is unplugged (duh!).
Mar 18, 2010 | As Seen On TV Magic Bullet Food Processor
Some coffe got down in the base of my magic bullet. What do I do?
For a Step-by-Step instructional PDF on how to disassemble, clean and reassemble your Magic Bullet send an email request to: Tinker@TinkersWorkshop.com.
Jan 01, 2010 | As Seen On TV Magic Bullet Food Processor
Need to clean inside of handle on KitchenAid food processor
The plastic for the work bowl / handle is molded and one piece and cannot be disassembled. My best recommendation is to call Kitchenaid customer service to see what recommendations they have. Within one year warranty, they may replace the work bowl at no cost.
Their toll-free number is: 1-800-541-6390.
Jun 28, 2009 | KitchenAid KFP750 Food Processor
How to clean the handle of the 11 cup processor?
Try putting in the dishwasher, if you dont have one, try letting it soak in very hot water to sterilize it.
Jun 15, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Have trouble getting it to start
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Mar 04, 2009 | KitchenAid KFC3300 Mini Chopper 3 Cups...
Operating switch
You could try a shot of contact cleaner inside the guts of the switch. Perhaps over time some sticky residue has built up causing the switch to become frozen. Unplug the unit, spray inside the guts of the switch, work the switch back and forth. repeat unit the switch loosens up. BE SURE to use a contact cleaner that won"t damage plastics, will say on label!
Jan 09, 2009 | Food Processors
KitchenAid KFP740/KFP750/KFPW760 Food Processor Logo
475 people viewed this question
Top KitchenAid Food Processors Experts
Shehu Pro
Shehu Pro
Ted Maxwell
ray gallant
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
