I need the unlock code for a region: 3 DVD. The actual disc not the player itself (If the latter matters, I have a Toshiba: Model #: MD20Q42, and I also have a Symphonic Model #: SC724DF. Can someone PLEASE help me!
  • 11,896 Answers
You can get it here:
http://www.dvdexploder.com/multihacks
Posted on May 07, 2010
How do I unlock region codes on a Toshiba SE-R0220 DVD/VCR player? I've tried many codes for other toshiba DVD players but none of them work :(
The Toshiba SE-R0220 is the REMOTE model number not the DVD/VCR model number!
You need to find hacked firmware for the DVD/VCR model number you have that releases the region settings.
Write it to a CD RW or DVD RW disc and follow the instructions for updating the firmware.
There is a chance that the firmware will not update correctly and you'll be left with a DVD part of the system that doesn't work.
Nov 03, 2016 | Toshiba Televison & Video
I have a Toshiba DVD player SD290EKB and would like to play Region 2 discs. How can I change region.
Toshiba SD290EKB
REGION UNLOCK CODE
When i bought this it said multi-region but its not. To unlock it to play all regions turn on the dvd player open the disc tray and then enter 98790. It will now change to region 0 making it able to watch all regions.
Hope that helps.
Nov 17, 2010 | Toshiba Televison & Video
Wont play DVD movie
I have seen this before with some rental DVDs. If you can play the other discs that you have without problem, then the issue is with this disc. Whether or not it is actually a region 2 discs or if it is just defective would be debateable but moot.
If you have the same problem with all of your discs, then the problem is in the set. There just might be a firmware upgrade available for this set to correct that problem, if it is not the disc itself. Contact customer service at 800-631-3811 and they should be able to help with a firmware issue.
The Wing Guy
Mar 25, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Toshiba hd ep 30kb
All HD discs are region free but the standard dvds are mostly region coded.
Jul 23, 2008 | Toshiba HD-A30 HD-DVD Player
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Unlock code for Toshiba SD-270EKB
dvd model SD-270EKB
1.power on dvd
2.open disk tray
3.while tray is open press 98790
the last number zero represents all regions unlocked.
Apr 06, 2008 | Televison & Video
UNLOCK CODE TOSHIBA DVD PLAYERS
unlock code TOSHIBA D-VR7KC
Dec 26, 2007 | Televison & Video
DVD unlock code/regional unlock code
icon_minipost.gifRegion code hack posted by knightlanguages, January 23 2008:
(1)Power on
(2)Press open on the DVD player to open drive cover
(3)On the remote control
(a)press SETUP button
(b)press right arrow key 3 times,
(the preference page will show up)
(c)press 9653
(d)Use the up and down key to select Region
(Select Region 0 for all regions)
(e)press SETUP again to save choices and exit
Your Audiovox D1917 is now region free!
Also works for Proline DVDP 920W
Nov 30, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
